Jeep Grand Cherokee Service manual
Автомобиль: 2011 Jeep Grand Cherokee WK2 5.7l Hemi
I have a WK2 that has a cam follower chewing into a lobe on my cam shaft. I need the service repair manual
Mps
540
Автомобиль: WK2
@Rixzle you need 24 new hydraulic lifters 05184332AA and 24 rocker arms 05184296AH. It's important to buy AH version. Only original parts. If cam follower chewed only side parts of lobe, you can use old camshaft, because working surface of lobe is still smooth. Here is the article, that will help you to understand all the process.
You can buy one day online subscription and save every document you need. It's possible to change all the parts without special tools if you are not a novice. Good luck!
    Kyco4ek Cblpa
    Kyco4ek Cblpa
      sanityclause  »  TRS Motors
      я че коменты убрали ?
    • КОГ52
      КОГ52  »  up6
      · 11 ответов
