Как узнать тип АКПП и год
eliseenko1982
По ВИНу должна быть:545RFE
1: Manufactured By DaimlerChrysler Corporation
J: Jeep
4: Multipurpose Passenger Vehicle w/out Side Air Bags
G: 5001-6000# (2268-2721 KG) GVWR & Hyd. Brakes
L: Liberty/Cherokee Left Hand Drive (4x4) Less "ABB"
5: Liberty LTD (US, Can, Mex)(Cherokee LTD BUX)
8: Hatchback/Tall/Sport/Quad Cab
5: 2.8L I4 CYL Turbo Diesel
7: Check digit
5: 2005 Model Year
W: Toledo North Assembly
Код модели кузова: KJJP74
Двигатель: ENR 2.8L 4 Cyl Turbo Diesel Engine
Коробка передач: DGE All 5-Speed Automatic Transmissions
Модельный год: 2005
Дата производства: 03.02.2005
*L7:  Cloth Low-Back Bucket Seats
-J3:  Khaki
132S: Zone 32-New York
1AAS: U.S. Dealer Retail
22F:  Customer Preferred Package 22F
2TFA: Customer Preferred Package 2TF
594S: Vehicle Order Tracking
5I4S: Four Wheel Drive (4WD)/(4X4)
5I8S: Left Hand Drive (LHD)
5YAS: KJ-Vehicle Family
5ZCS: Price Class P
630S: New Hampshire State Code
6USS: Label - U.S. Specifications
930S: New Hampshire State Code
A46P: 2.8LTD Eng(ENR)/5Spd A/T 545RFE(DGQ)
AHMS: Convenience Group I
AHT:  Trailer Tow Group
AJBS: Security Group
AJPS: Power Convenience Group
APAS: Monotone Paint
BAZS: 136 Amp Alternator
BCVP: 700 Amp Maintenance Free Battery
BRYP: Anti-Lock 4-Wheel Disc Brakes
CBFS: Premium Door Trim Panel
CF5S: Rear 65/35 Folding Split Seat
CG3S: Advanced Multistage Front Air Bags**
CGUS: Child Seat Anchor System-LATCH Ready
CK3S: Plastic Swing Gate Trim Panel
CKCP: Floor Carpet
CKNS: Cargo Compartment Carpet
CKTS: Cargo Tie Down Loops
CLES: Front & Rear Floor Mats
CLHP: Cargo Trim Panel w/Storage Net
CSAS: Spare Tire Cover
CSCS: Cargo Compartment Cover
CSRS: Passenger Assist Handles
CSWS: Driver Assist Handle
CUFS: Full Length Floor Console
DGES: All 5-Speed Automatic Transmissions
DGQ:  5-Spd Automatic 545RFE Transmission
DHAP: Lock-Up Torque Converter
DHPP: Selec-Trac Full Time 4WD System
DJJS: Dana 30/186MM Front Axle
DMES: 3.73 Axle Ratio
DRAS: Corporate 8.25 Rear Axle
ENR:  2.8L 4 Cyl Turbo Diesel Engine
GBBS: Tinted Windshield Glass
GCBS: Front Door Tinted Glass
GEGS: Deep Tint Sunscreen Glass
GEKS: Flipper Swing Gate Glass
GFAS: Rear Window Defroster
GNAS: Rear View Day/Night Mirror
GNCP: Sun Visors w/Illum Vanity Mirrors
GT9S: Power Mirrors, Fold-Away
GVBC: All Vehicles W/Power Mirrors
GXMP: Remote Keyless Entry
GXXP: Sentry Key Theft Deterrent System
HAAS: Air Conditioning
I89S: Route 89 - CSX, Selkirk, NY
JA2S: Instrument Cluster w/Tach
JCBS: 120 MPH Primary Speedometer
JHAS: Var Intermittent Windshield Wipers
JHBS: Rear Window Wiper/Washer
JJBS: Dual Note Electric Horns
JJJS: 12V Auxiliary Power Outlet
JJMP: Auxiliary 12-Volt Rear Power Outlet
JKYS: Power Accessory Delay
JPHP: Speed Sensitive Power Locks
JPSS: Power 6-Way Driver Seat
JPYS: Pwr Windows, Front 1-Touch Down
K5MS: STRIPE/BADGE/MOLDING COLOR
LABS: Tire Pressure Monitoring Warning LP
LACP: Illuminated Entry
LBBP: Courtesy Lamps
LCDP: Map/Dome Reading Lamps
LDBP: Cargo Compartment Lamp
LHDS: Headlamp Off Time Delay
LMAS: Halogen Headlamps
LNJS: Fog Lamps
LPSS: CHMSL Lamp
LSAP: Security Alarm
LSES: Enhanced Accident Response System
MDAS: Front License Plate Bracket
MFZS: Bright Grille
MJBS: Chrome Bodyside Molding
MLAS: Body Color Fascias
MSUS: Limited Edition Badge
MT2S: Trail Rated Badge
MVCS: Jeep Badge
MVDS: 4X4 Badge
MW1S: Bright Side Roof Rails
MZRP: Common Rail Diesel Badge
NAA:  Federal Emissions
NB1P: Federal Tier 2, Bin 10 Emissions
NFPS: 20.5 Gallon Fuel Tank
NHKP: Engine Block Heater
NHMS: Speed Control
PJT:  Dk. Khaki Pearl Coat
QJTS: Dk. Khaki Pearl Coat
RAAC: All Radio Equipped Vehicles
RBKS: AM/FM Compact Disc Radio w/Chgr Ctrl
RCGS: 6 Speakers
RDDS: Fixed Long Mast Antenna
SBAS: Power Rack and Pinion Steering
SCGS: Leather Wrapped Steering Wheel
SDAS: Normal Duty Suspension
SUAS: Tilt Steering Column
TBBS: Full Size Spare Tire
TBRS: Outside Tire Carrier
TR7P: P225/75R16 OWL All Season Tires
TZAP: Goodyear Brand Tires
WKBS: Matching Spare Wheel
WLDP: 16X7.0 Lux Aluminum Wheels
WLZC: All Aluminum Wheels
XCAS: Occupant Classification System
XFJP: Class III Receiver Hitch
XFKP: 7 Pin Wiring Harness
XFLP: 7 to 4 Pin Wiring Adaptor
XGGS: Grocery Bag Hooks
XJFS: Tethered Fuel Filler Cap
XPFS: Protective Coating and Remover
YAAS: Build To U S Market Specifications
YG3A: 3.5 Additional Gallons of Diesel
Z5EP: Payload Rating - 1350#
ZCKP: Spring - Left Front
ZCVP: Spring - Left Rear
ZRKP: Spring - Right Front
ZRVP: Spring - Right Rear
  • Кто в онлайне   9 пользователей, 0 анонимных, 127 гостей (Посмотреть всех)
    • brat-kondrat
    • Иван Мишкин
    • LonesomeDove
    • Nordicus
    • Schv
    • sladder
    • Andrey 23rus
    1. Владельцы Jeep Grand Cherokee после рестайлинга 2014 года часто обращаются в наш сервис TRS Motors с жалобами на характерный щелчок при открытии двери. Особенно заметен этот звук на середине хода двери, когда она открыта примерно под углом 45 градусов. Проблема не просто раздражает владельцев, но и может указывать на начинающиеся проблемы с дверной группой. В ходе диагностики мы выяснили, что причина кроется в ограничителе нижней петли двери, который со временем изнашивается и перестает выполнять свои функции должным образом.
      Почему возникает щелчок при открытии двери
      Механизм ограничителя двери в Jeep Grand Cherokee представляет собой сложный узел, который подвергается постоянным нагрузкам. При каждом открытии двери этот элемент испытывает серьезное давление, особенно если автомобиль эксплуатируется в условиях перепадов температур. Со временем пластиковые компоненты изнашиваются, металлические части теряют смазку, и появляется характерный щелчок. Важно понимать, что это не просто косметическая проблема - продолжающаяся эксплуатация с неисправным ограничителем может привести к перекосу двери и повреждению других элементов дверной группы.
      Эффективное решение проблемы
      После многолетнего опыта работы с Jeep Grand Cherokee мы в TRS Motors пришли к выводу, что единственным надежным решением является полная замена ограничителя нижней петли двери. Попытки ремонта или смазки существующего механизма дают лишь временный эффект и не решают проблему кардинально. Замена петли позволяет полностью устранить щелчок и восстановить плавность хода двери. Особенно важно учитывать, что часто требуется замена сразу нескольких петель, так как износ обычно происходит равномерно на всех дверях автомобиля.
      Профилактика и рекомендации
      Чтобы избежать подобных проблем в будущем, мы рекомендуем владельцам Jeep Grand Cherokee регулярно проверять состояние дверных петель во время планового технического обслуживания. Особое внимание следует уделять этому узлу при подготовке к зимнему сезону, когда перепады температур особенно сильно влияют на пластиковые и металлические компоненты. Также важно избегать резкого открытия дверей, особенно в мороз, когда материалы становятся более хрупкими. Эти простые меры помогут продлить срок службы дверных механизмов и сохранить комфорт эксплуатации вашего автомобиля.
      Закатываем автомобиль в цех.
    3. 5 мая 2025 года в Италии был представлен долгожданный Jeep Compass 2026 — кроссовер третьего поколения, который обещает стать новым эталоном в сегменте компактных SUV. Построенный на современной платформе STLA Medium от Stellantis, новый Compass стал крупнее, технологичнее и разнообразнее в плане силовых агрегатов. Рассказываем, что известно о дате выхода, двигателях, трансмиссиях, комплектациях, системах полного привода и конкурентах.
      Дата выхода
      Сегмент и конкуренты
      Платформа и размеры
      Двигатели и силовые агрегаты
      Европа
      1. Мягкий гибрид (e-Hybrid):
        • Мощность: 145 л.с.
        • Привод: Передний (FWD).
        • Мощность: 195 л.с.
        • Привод: Полный (AWD).
      США и Северная Америка
      Коробка передач
      Системы полного привода
      Комплектации
      Оснащение и технологии
      Экстерьер
      Интерьер
      • Сенсорный экран 16 дюймов.
      Безопасность и технологии
      Итог
