Активация штатного автозапуска WK2
2012
6 минут назад, Giraffe сказал:
Вообще- то должно быть 15 минут, и возможны 2 подхода.
В третий раз не заведется, надо перезапускать мотор из машины.
И на форуме об этом читал, и на своей проверял... два раза по 10 минут. 🤷‍♂️
Автомобиль: Liberty 2.0 CRD
RAM 2500 6.7 тоже дизель
Я, наверное, сольюсь.
Потому что в прошлом споре по этому поводу, я выиграл коньяк у коллеги из Амурска. 😆
REMOTE STARTING SYSTEM
The Remote Starting System allows the vehicle to be started up to 300 feet (91 meters) away from the vehicle using the remote keyless entry key fob which is part of your ignition key. In order to remote start your vehicle, the hood, liftgate, and all of the doors must be closed. To remotely start your vehicle, press the “Remote Start” button twice within 5 seconds. To indicate that the vehicle is about to start, the parking lights will flash and the horn will sound briefly. Once the vehicle has started, the engine will run for 15 minutes. To cancel remote start, press the “Remote Start” button once. To enter the vehicle while the engine is running during a remote start, you must first unlock the vehicle using the “Unlock” button on the key fob. After the vehicle is unlocked, you have 60 seconds to enter the vehicle, insert the key into the ignition, and move it to the RUN position. Otherwise, the engine will cancel remote start and automatically turn off. Remote start will also cancel if any of the following occur:
  • If the engine stalls or RPM exceeds 2500.
  • Any engine warning lamps come on.
  • The hood is opened.
  • The hazard switch is pressed.
  • The transmission is moved out of P (Park).
  • The brake pedal is pressed.
The vehicle can be started remotely up to a maximum of two times. The vehicle is also allowed a maximum of one failed start. This can occur when the remote start sequence was initiated but cancelled before the engine begins to crank or the engine stopped cranking without starting. After either of these conditions, or if the Vehicle Theft Alarm is alarming, or if the PANIC button was pressed, the vehicle must be reset by inserting a valid key into the ignition and moving it to the RUN position, then back to LOCK.
Автомобиль: WK2 3.6 2011
Активировал альфой автозапуск по методике из прикрепленных сообщений. Всё работает. Из дома хорошо, авто под окном стоит. А на работе стоянка в метрах 200 с кучей помех. Ну и Сибирь, морозы, ограничение по прогреву два раза очень мало. Поэтому куплен обходчик айдаталинк и маячок старлайн для его запуска. Буду с телефона управлять и по шине данные снимать о состоянии авто.
Автомобиль: Гранд Чероки Лимитед 3
0 дизель 2013 г.в.
В 19.11.2022 в 19:27, Giraffe сказал:
@Pablusha  @demon969
Если вообще без сканера, периметр посмотрите.
Красная лампа иммобилайзера первые 16 секунд после закрытия должна часто моргать.
В это время машина проверяет, закрыты ли у нее капот, двери, багажник.
Если все ОК, то дальше лампа будет моргать реже- это машина стоит в охране.
А вот если во время осмотра что- то не закрыто, лампа будет ГОРЕТЬ НЕПРИРЫВНО.
Откуда я это знаю?
Читал много, пришлось.
Не благодарите.
а на ларедо дизельном это реализуемо?
Думаю, да. Принципы управления одни и те же.
Автомобиль: Jeep wk2
В общем поделюсь ещё инфой, я тут ранее писал что, машина на тёплую автозапуск пускает нормально, а на холодную запускает и глохнет, и начинает орать сигнализация, проблема была в аккумуляторе, аидать из за просадки, стоял от старого хозяина кислотник обычный 100, поставил новый агм и проблема пропала, просадки нету, автозапуск работает в штатном режиме.
-25 с ветром, джип стоит 12 часов на улице, запускается с полпинка утром.
Автомобиль: Jeep Grand Cherokee wk2 2012
Всех приветствую. Установили дистанционный запуск в Форисе СПб. Всю тему не осилил, так что прошу прощения за простой вопрос.
Где взять подпятник под кнопку на брелоке?! Он так и называется?
Прочитал, что можно кусочек фольги использовать, я так понял, что там нужно замыкание круглой контактной площадки и контакта в ее центре. Это верно? Но хотелось бы без такого колхоза…
5 минут назад, Trepand сказал:
Купить на али корпуса брелков с нужными кнопками и пиктограммами и переставить в них свои внутренности.
2 часа назад, Trepand сказал:
в магазине чип и дип покупаете кнопочку, разбирате и извлекаете оттуда пятачок... фото кнопочки поищу
Искать по словосочетанию " тактовый выключатель".
Расковыриваете ножичком, внутри нужная Вам мембрана.
Такие кнопки видел, даже дома валялись, дети выломали откуда-то. спасибо!
@Trepand старый пульт разбери и среж оттуда, если нужна высокая, если низкая то пульты от магнитол и тому подобные, тонкие которые.
Автомобиль: Jeep Grand Cherokee TrailHawk 18
А нельзя как-то сделать 3 запуск , а не 2 раза чтобы заводилась? Кто-то заморачивался на большее число запусков?
Автомобиль: Jeep Grand Cherokee WK2 3.6 Overland
2015
2 часа назад, Legoz сказал:
Штатный ДЗ никак. Вариант, поставить сигнализацию с дистанционным запуском.
Сига с автозапуском тоже стоит, это не решает вопрос , 2 раза заводит пр температуре , на третий запуск ругается , на приборке пишет заведите с ключа .. Вот и думаю как бы на 3-4 запуска сделать
2015
@Legoz я думал сигнализация подключена с обходчиком иммо. У вас же она управляет штатным ДЗ, что круто. А можете написать в какая модель сиги?
Pandect 3190, установлена в 2018 году еще.. На Тойота Прадо работает автозапуск хоть 100 раз ...
Изменено пользователем Legoz
Автомобиль: Jeep Grand Cherokee wk2 2017 limited
Ребят, помогите советом.
Альфа ОбД с всем известного сайта.
Пин вытянул с помл6 крайслер пин пуллер за 30$.
А прописать ключ не получается,пишет такую ошибку.
Screenshot_20230119_170927_com.AlfaOBD.AlfaOBD_1.thumb.jpg.b87b9fa832e0540a0868cbf49a187e37.jpg
Может быть надо что то в альфе исправить?
Хочется уже все же довести дело до конца)
2012
16 минут назад, Stepanyuk92 сказал:
Два поста сверху закреплены... всё делаете как там написано?
2015
@Stepanyuk92 пробуйте это, не премиум. В последних версиях Альфы только так.
50 минут назад, Pablusha сказал:
Да, конечно. Уже и на драйве статьи штудировал и тут прочитал все.
11 минут назад, Amelnik сказал:
Это не для "бесключевого доступа",а у меня соответственно есть бесключевой доступ.
Но через часок спущусь к машине и попробую..а вдруг как говорится. Но все пишут надо именно премиум система
Изменено пользователем Stepanyuk92
2015
3 минуты назад, Stepanyuk92 сказал:
А вы все же попробуйте, ключ привяжется и все будет работать. Написал же про версии Альфы, раньше было премиум... Проверено на нескольких машинах.
Изменено пользователем Amelnik
Хорошо! Заранее благодарен даже просто за вариант решения проблемы) или сегодня поздно,или завтра отпишусь о результате.
2 часа назад, Amelnik сказал:
Короче,Вы оказались совершенно правы. Ключ привязался и все работает как нужно,а том числе и бесключевой доступ. Радости полные штаны и дело не в экономии 100$,а в том что все же довел дело до конца,хотя в этом я не сказал бы что разбираюсь. На самом деле не сложно. Ваш совет был решающий. С меня вкусное пиво или квас,вдруг когда то где то пересечёмся!) В жизни всякое бывает. Ну а пока ещё раз большое, человеческое с п а с и б о!
P.S добавлю на драйве в своей статье)
2015
По сигнализации Starline, к сожалению они признали "Заявленный функционал прошивки CAN может различаться или отсутствовать для автомобилей данной марки и модели в зависимости от его года выпуска, модельной партии, комплектации."  Короче управление штатным дистанционным запуском не работает. Может у кого то и сойдутся звезды и заработает, пока таких не встречал.
Но можно использовать обычный способ дистанционного запуска от сигнализации, плюсы тоже есть, к примеру, неограниченное кол-во запусков и время работы. Использование гибкой логики от Starline. А вот безопасность от угона под сомнением.
Монтаж по карте и прошивка от Jeep Grand Cherokee 2018-2023, не от 2014-2017, на ней обхода нет (подключения только по шинам CAN A, CAN B, LIN)
В основных настройках сигнализации:
- Управление запуском по CAN-LIN.
- Обход по CAN-LIN.
Для активации функции необходимо пройти процедуру обучения:
Перед началом удалить батарейку из ключа. Для включения зажигания нажимать торцом разобранного ключа кнопку Start-Stop.
1. Выполнить вход в режим обучения путем нажатия сервисной кнопки 14 раз.
2. Включить зажигание не позднее 5 сек.
3. Выключить зажигание.
4. Второй раз включить зажигание.
5. Дождаться подтверждающего двойного звукового сигнала об успешном завершении.
6. Активировать функцию с помощью сервиса CopyKey.
7. Вставляем батарейку в ключ, запускаем двигатель посредством сигнализации.
6. Глушим двигатель с сигнализации.
После этой процедуры дистанционный (авто) запуск работает без ключей в салоне. Никаких обходчиков типа Fortin и тд. не нужно.
  • 8 месяцев спустя...
Автомобиль: Grand Cherokee 2012
GC 2012 г. Дизель. Заводится со штатного автозапуска. Сажусь в машину, нажимаю кнопку Start, машина глохнет. Вопрос, как снять с охраны и продолжить движения без повторного запуска из машины.
на дизеле никак, насколько я помню, лет 10 назад бились над этой темой
Автомобиль: .Jeep Grand Cherokee WK2 рест 3.0 ecodiesel
14 часов назад, Buzador сказал:
 может это только на доресте так?
у меня на рестайлинге никаких проблем- открыл дверь. сел, нажал кнопку Start, заработала вся приборная панель , скорость включил на Д и поехал
Изменено пользователем brat-kondrat
Автомобиль: JEEP Grand Cherokee WK2 2014г 3.6 overland
@up6 Спасибо за пин, все четко подошло! Вчера пришел ключ все привязалось, автозапуск пашет.
  • Кто в онлайне   0 пользователей, 0 анонимных, 101 гость (Посмотреть всех)
    1. Надежный список онлайн-казино (Online Casino ) на реальные деньги в 2025 году.
      Рейтинг лучших онлайн казино 2025. Играйте в лучшие казино, ТОП-10 список: честные и надежные, с бонусом на первый депозит.
      Самый лучший список онлайн кaзино (online casino) на реальные деньги в 2025 году.
      Болливуд – Проверенные временем слоты с приветственным бонусом 400%+100FS
      Gold Casino — это ваш портал в будущее азартных игр. Новое GOLD Casino официальный сайт - Приветственный Бонус +150% и 2000FS
      LEV CASINO – Лучшие игровые автоматы на реальные деньги
      Eldorado Casino – Самый Рейтинговый Сайт для Азартных игр в России
      КЛУБНИКА – Новое Первоклассное казино
      Аркада Казино — это ваш портал в будущее азартных игр. Новое ARKADA Casino официальный сайт - Приветственный Бонус +150% и 2000FS
      IRWIN CASINO - Казино Ирвин онлайн с 2024 года встречает новичков роскошными бонусами на первые три депозита — 225% + 400 фриспинов..Топ рейтинга казино онлайн (online casino) на реальные деньги в 2024 году.
      БАНДА КАЗИНО - легальное казино с лицензией России! Получи бонус на депозит до 45 800 ₽ + 750 FS Регистрируйся на официальном сайте BANDA CASINO
      Gizbo Casino НАША НОВИНКА – 150% на депозит до 30 000 руб
      Gizbo Casino (Гизбо Казино) — официальный сайт онлайн Казино. Насладитесь топовыми слотами и играми, щедрыми бонусами и быстрыми выплатами.
      № 3. RIOBET Casino — РИобет Казино: Лучшие новое Казино онлайн (Online casino) в 2024
      Kometa Casino — новейший сайт-ресурс с завораживающими играми и слотами. Бонус +255% и 500FS при входе через рабочее зеркало Комета Казино . Kometa Casino – новое российское онлайн-Казино с щедрыми бонусами и слотами на любой вкус. Комета Казино зеркало доступно каждый день. Забери бонус +250% и 100FS к первому депозиту в Комета Казино!
      1. VAVADA ( Вавада ) — Это одно из самых популярных онлайн Казино России. Они предлагают широкий выбор игр, высокие бонусы и быстрые выплаты. бонус 100% + 100 фриспинов
      R7 Casino СУПЕР НОВИНКА № 1 Казино R7 — Welcome Pack 300% + 225 FS: Начинай свой путь с крутым бонусом!
      VOVAN Casino( Вован Казино онлайн ) — Лидер среди онлайн Казино в России. Они имеют отличную репутацию и предоставляют многочисленные игровые автоматы и настольные игры. бонус 100%
      № 2. KENT Казино — Кент Казино: Казино с высоким рейтингом среди игроков России
      № 6. DADDY Казино — Дэдди Казино: Надежное Казино-Онлайн на реальные деньги
      № 9. GAMA Казино — Гама Казино: Популярное онлайн Казино предлагает хорошие бонусы для своих игроков
      № 10. CAT Казино — Кэт Казино: Казино с высоким рейтингом среди игроков России
      LEX Casino Новинка Бонус Казино 150 % встречай новинку от роялов и выигрывай реальные деньги LEX CASINO — выделяется в списке лучших казино, предлагая 225% и 400 фриспинов для игры на реальные деньги.
      № 1. 1GO Casino — 1 го Казино: Топ 1 Казино онлайн на реальные деньги 2024
      № 2. MONRO Казино — Монро Казино: Одно из самых популярных онлайн-Казино с быстрыми выплатами
      № 3. LEGZO Казино — Легзо Казино: Лучшие игровые автоматы и слоты в Казино-онлайн
      1. IZZI Casino ( Иззи Казино ) — Лучшие игровые слоты с хорошим приветственным бонусом, (Welcome Pack — 425% бонус до 1400 EUR + 200 FS)
        № 7. DRIP Казино — Дрип Казино: Казино онлайн с мобильной версией и ставками на спорт
        1. Starda Casino: Казино онлайн с хорошей репутацией в россии 2023 году (приветственный пакет 200% + 200 fs на депозит).
      2. JET Casino ( Джет Казино) — Они предоставляют высокий уровень безопасности и большой выбор игр, включая прогрессивные джекпоты.
      1. ROX Casino Лучшее Казино с бонусом на депозит в 200% и 150ФС
      2. FRESH Casino Самое свежее Казино с бонусом 200%
      3. SOL Casino Топ Казино на реальные деньги с бонусом на депозит 300%
      № 4. RAMENBET — Рамен бет: Казино с лучшими бонусами а также с бездепозитным бонусом
      AUF CASINO это: 3000+ лучших слотов, RTP 97+% 150% бонус к депозиту ✓ 24/7 поддержка!
      POPERLO CasinoНовинка Поперло Казино — На первый депозит игрокам доступен бонус 200% до 50 000 рублей
      Самый лучший список онлайн Казино (online Casino) на реальные деньги в 2024 году. Вашему вниманию топ рейтинг онлайн Казино на реальные деньги. Премиум список
      1. PLAY FORTUNA ( Плей Фортуна ) — Они предлагают большой выбор слотов от ведущих провайдеров и щедрые бонусы для новых игроков.
      2. 1WIN Casino( Ван вин Казино) — Это одна из самых надежных площадок для азартных игр в России. Они предлагают большой выбор слотов, а также живые дилеры для настольных игр.
      3. NewRetroCasino — надежное Казино с быстрыми выплатами и высоким уровнем обслуживания Новое Казино с высокими шансами на выигрыш.
      4. BOOI Casino ( Буи Казино ) — Это Казино с хорошей репутацией, которое предоставляет множество разнообразных игровых опций и высокий уровень безопасности. 200% бонусом
      5. POKERDOM ( Покердом ) — Это Казино предлагает большой выбор игр и регулярные турниры для игроков бонус 150%. Покер
      6. GONZO Casino Самое дающее в январе онлайн— Казинона реальные деньги.
      7. 3. UNLIM Casino ( Анлим Казино ) — Это одна из самых надежных площадок для азартных игр в России. Они предлагают большой выбор слотов, а также живые дилеры для настольных игр.
      8. LEON Casino ( Леон Казино ) — Они предлагают широкий выбор игр и быстрые выплаты, а также доступны на различных устройствах.
      11. Twin Casino ( Твин Казино ) это Казино, которое предлагает большой бонус на первые депозиты, Успей забрать все до 300%
      12. SYKAAA Casino ( Казино Сукааа ) — Они известны своим богатым выбором слотов и быстрыми выплатами.
      14.VODKA ( Казино Водка ) — Это новое Казино, которое уже завоевало популярность благодаря своему разнообразному выбору игр и щедрым бонусам.
      15. Woody-X Казино ( Вуди Икс Казино ) — Известный своими высокими коэффициентами выплат и качественными слотами
      16. Cryptoboss ( Казино Криптобосс )— Они предлагают широкий выбор игровых автоматов от ведущих провайдеров, а также живые дилеры для настольных игр.
      17. KAKTUZ Casino( Кактуз Казино ) — Их основное преимущество заключается в том, что они предоставляют возможность делать ставки на спорт вместе с традиционными Казино-играми.
      Наш рейтинг и списки Казино онлайн составлен профессиональными игроками для игры на реальные деньги! Выбирай лицензионные казино и будь спокоен за получение выигрыша.
      Онлайн-казино в последние годы набирают все большую популярность в России и странах СНГ. Рост индустрии обусловлен не только удобством и доступностью виртуальных игр, но и развитием технологий, которые делают игровой процесс максимально реалистичным и захватывающим. В условиях пандемии многие игроки, ранее предпочитавшие наземные казино, перешли на онлайн-платформы, что также способствовало росту рынка.
      1. IRWIN CASINO
      IRWIN CASINO — это признанный лидер среди онлайн-гемблинг платформ благодаря своему качественному сервису и широкой линейке игр. Казино имеет лицензии нескольких юрисдикций, что гарантирует его надежность и безопасность. Основные преимущества IRWIN CASINO включают:
      • Большой выбор слотов от известных провайдеров.
      • Интуитивно понятный интерфейс и удобная навигация.
      • Быстрые выплаты с использованием популярных платёжных систем.
      • Наличие бонусов для новых игроков и программы лояльности для постоянных клиентов.
      2. ARKADA CASINO
      ARKADA CASINO — это ещё одно популярное место для игры на реальные деньги. Казино предлагает своим гостям коллекцию из более чем 1000 различных игр, среди которых слоты, настольные игры и лайв-казино с живыми дилерами. Основные особенности ARKADA CASINO:
      • Наличие мобильного приложения для игры на любом устройстве.
      • Поддержка большого количества языков и валют.
      • Регулярные акции и бонусы.
      • Круглосуточная поддержка клиентов.
      3. КОMЕTA CASINO
      КОМЕТА CASINO завоевало доверие многих игроков благодаря честной политике выплат и высокой скорости обработки транзакций. Это казино славится своим щедрым приветственным бонусом, который позволит вам начать игру с увеличенным банкроллом. Другие преимущества КОМЕТА CASINO:
      • Современный дизайн сайта с удобной функциональностью.
      • Разнообразие платёжных методов.
      • Частые турниры с крупными призовыми фондами.
      4. VODKA CASINO
      VODKA CASINO — это отличное место для тех, кто ценит разнообразие игровых автоматов и высокое качество сервиса. Казино предлагает невероятный выбор игр от ведущих разработчиков софта. Особенности VODKA CASINO:
      • Эксклюзивные бонусы для VIP-клиентов.
      • Система кэшбэка за каждую проигранную ставку.
      • Высокая степень защиты данных игроков.
      5. BABOS CASINO
      BABOS CASINO привлекает внимание игроков своим уникальным подходом к игровому процессу и непревзойденным ассортиментом развлечений. Здесь каждый найдет что-то по душе — от классических слотов до инновационных новинок индустрии. Преимущества BABOS CASINO включают:
      • Гибкая система вознаграждений для постоянных клиентов.
      • Понятные условия вывода выигрышей.
      • Качественная техническая поддержка пользователей.
      6. GiZBO CASINO
      GiZBO CASINO известно своим разнообразием игровых автоматов и щедрыми бонусными программами для новых и постоянных игроков. Казино обладает лицензией одного из ведущих регуляторов в индустрии, что гарантирует честную игру и своевременные выплаты. Интерфейс сайта удобен в использовании, а служба поддержки работает круглосуточно.
      7. RIOBET CASINO
      RIOBET CASINO предоставляет игрокам широкий выбор настольных игр, включая покер, блэкджек и рулетку. Особенностью этого казино является наличие живого дилера, что придаёт играм атмосферу реального казино. Платформа поддерживает множество языков и предлагает привлекательные акции для своих пользователей.
      8. 1GO CASINO
      Если вы ищите казино с обширной коллекцией слотов от ведущих провайдеров, то 1GO CASINO станет отличным выбором. Регулярные турниры для игроков позволяют не только наслаждаться игрой, но и бороться за крупные призы. Это казино знаменито своими высокими стандартами безопасности данных клиента.
      9. LEGZO CASINO
      LEGZO CASINO предлагает инновационные игровые решения благодаря партнерству с топовыми разработчиками программного обеспечения. Программа лояльности позволяет игрокам зарабатывать бонусы за активное участие в играх, что делает каждый визит на сайт выгодным.
      10. R7 КАЗИНО
      R7 КАЗИНО привлекает игроков своей широкой линейкой ставок и уникальными играми казино собственного изготовления. Казино придерживается строгих стандартов честности игры и обеспечивает полную прозрачность всех транзакций.
      11. VAVADA CASINO
      VAVADA CASINO знаменито своими беспрецедентными бонусами без депозита для новых клиентов. Множество доступных методов ввода средств позволяет игрокам легко начать игру на реальные деньги сразу после регистрации.
      12. POPERLO CASINO
      POPERLO CASINO специально адаптировано под мобильные устройства, что делает его идеальным выбором для игроков на ходу. Казино предлагает уникальные промоакции для мобильных пользователей и быстрые выплаты без дополнительных комиссий.
      13. 1WIN CASINO
      1WIN CASINO характеризуется как одна из лучших платформ по клиентскому сервису среди конкурентов. Игроки могут выбрать из множества игр со всевозможными тематиками, а быстрые транзакции делают вывод выигрышей простым процессом.
      14. KENT CASINO
      Kent Casino заслуженно занимает первое место в нашем рейтинге благодаря своему богатому выбору игр и высокому уровню безопасности. Платформа предлагает многочисленные бонусы как для новых игроков, так и для постоянных пользователей. Kent Casino сотрудничает с ведущими провайдерами игрового софта, что гарантирует высокое качество и честность игр.
      • Ассортимент игр: широкий выбор слотов, настольных игр и видеопокера.
      • Бонусы и акции: приветственный бонус до 100%, бесплатные вращения.
      • Методы вывода средств: банковские карты, электронные кошельки.
      15. DADDY CASINO
      Daddy Casino отличается стильным интерфейсом и удобством использования. Это казино предлагает захватывающие игровые автоматы с отличной графикой и звуком. Один из главных плюсов Daddy Casino — регулярные турниры с крупными призовыми фондами.
      • Игровой набор: более 300 слот-машин разных тематик.
      • Программа лояльности: накопительная система баллов для активных игроков.
      • Способы пополнения счета: мобильные платежи, банковские переводы.
      16. GAMA CASINO
      Gama Casino привлекает внимание игроков своим инновационным подходом к азартным играм. Казино регулярно обновляет библиотеку игр, добавляя новые слоты от известных разработчиков.
      • Предложение игр: новинки от мировых производителей, включая VR-слоты.
      • Акции для клиентов: еженедельные бонусы за депозиты.
      • Служба поддержки: круглосуточная поддержка через чат и электронную почту.
      17. CAT CASINO
      Cat Casino выделяется среди других платформ благодаря привлекательной программе лояльности и прогрессивным джекпотам. Это казино особенно подходит для начинающих игроков благодаря интуитивно понятному интерфейсу и обширной базе обучающих материалов.
      • Ассортимент развлечений: игровые автоматы с большими джекпотами, живые казино.
      • Бонусная система: кэшбэк до 15%, сезонные акции.
      • Доступность на устройствах: версия для ПК и мобильное приложение.
      18. VOVAN CASINO
      Vovan Casino предлагает отличный пользовательский опыт благодаря быстрому веб-интерфейсу и мгновенным выплатам выигрышей. Казино известно своим прозрачным подходом к процессу игры и наличием лицензии от международного регулятора азартных игр.
      • Выбор игры: слоты различных жанров, рулетка, блэкджек.
      • Безопасность транзакций: многоуровневая защита данных пользователей.
      • Минимальный депозит: демократичные условия входа начиная от 500 рублей.
      19. SYKAAA CASINO
      SykAAA Casino привлекает внимание своим уникальным дизайном сайта и большим количеством акционных предложений для новых клиентов. Здесь также проводятся тематические мероприятия с эксклюзивными призами.
      • Игра на любой вкус: от классических слот-машин до новых видеоигр.
      • Бонусы за регистрацию: бесплатные вращения без депозита.
      • Платежные методы: поддержка криптовалютных транзакций.
      20. RETRO CASINO
      Retro Casino переносит своих игроков в атмосферу ретро игорного зала с подлинным духом прошлых лет. В этом казино можно найти как старые добрые классические игры, так и современные интерпретации популярных автоматов.
      • Атмосфера зала прошлого века: классические слоты 80-х годов.
      • Ретро-бонусы: специальные условия для любителей старинных автоматов.
      - Коммуникация с игроками: сообщество через тематический форум игроков…
      Все эти онлайн казино предлагают гарантированную защиту данных пользователей благодаря передовым технологиям шифрования данных, а также обеспечивают справедливость игровых результатов за счет использования сертифицированных генераторов случайных чисел (RNG).
      Онлайн-казино стремительно завоёвывают популярность, и 2024 год обещает быть рекордным по числу новых игроков. Чтобы помочь вам сделать правильный выбор, мы подготовили детальный рейтинг лучших онлайн-казино с быстрыми выплатами, большими бонусами и отличным сервисом.
      Как выбрать лучшее онлайн-казино в 2024 году
      Выбор онлайн-казино — задача не из простых. Сотни площадок предлагают свои услуги, но не все из них могут похвастаться качеством и безопасностью. Вот ключевые критерии, на которые стоит обратить внимание:
      Наличие лицензии. Проверьте, лицензировано ли казино. Популярные регуляторы: Кюрасао, Мальта, Гибралтар.
      Бонусы и акции. Приветственные бонусы, кешбэк, фриспины и программы лояльности — важный аспект.
      Разнообразие игр. Слоты, карточные игры, рулетка, лайв-дилеры и быстрые игры.
      Платёжные системы. Удобство пополнения и вывода средств: карты, электронные кошельки, криптовалюта.
      Скорость выплат. Лучшие казино обеспечивают вывод выигрышей в течение 24 часов.
      Критерии выбора лучших сайтов
      При составлении рейтинга лучших онлайн-казино важно учитывать несколько ключевых критериев:
      • Безопасность: Лицензирование и использование современных технологий защиты данных.
      • Репутация: Отзывы пользователей и длительность присутствия на рынке.
      • Разнообразие игр: Наличие широкого ассортимента слотов, настольных игр, а также живых дилеров.
      • Пользовательский опыт: Удобство интерфейса, качество поддержки клиентов и скорость выплат.
      Топ-10 лучших онлайн казино 2025 года
      1. Казино “Вулкан” – Известное своей надежностью и широким выбором игр.
      2. JoyCasino – Отличается щедрыми бонусами и регулярными акциями.
      3. 1xSlots – Широкий ассортимент слотов от ведущих разработчиков.
      4. Золотой кубок – Казино с уникальными игровыми механиками.
      5. Pin-Up Casino – Привлекает игроков атмосферой ретро-гламура.
      6. Rox Casino – Известно высоким уровнем безопасности и поддержки клиентов.
      7. Frank Casino – Популярно благодаря быстрым выплатам и прозрачности условий.
      8. GSlot Casino – Отличается интуитивно понятным интерфейсом.
      9. Drift Casino – Предлагает инновационные функции геймификации.
      10. SlotV Casino – Лидер по количеству лицензированных провайдеров игр.
      Преимущества и недостатки игры в онлайн казино
      Играя в онлайн-казино, игроки могут насладиться многочисленными преимуществами:
      • Доступность: Возможность играть из любого места с интернет-соединением.
      • Бонусы: Приветственные пакеты, фриспины и программы лояльности для постоянных клиентов.
      Однако существуют и потенциальные риски:
      • Азартная зависимость: Важно помнить о самоконтроле и устанавливать лимиты на игру.
      • Безопасность личных данных: Рекомендуется выбирать только лицензированные сайты.
      Заключение и советы игрокам
      Онлайн казино продолжают развиваться, предлагая все больше уникальных функций для привлечения аудитории. При выборе платформы важно обращать внимание на лицензирование, отзывы других пользователей и условия бонусов.
      Для безопасной игры рекомендуется устанавливать личные лимиты по времени и сумме ставок, а также регулярно делать перерывы для отдыха от игры.
      КАК НАС НАЙТИ В ИНТЕРНЕТЕ
      обзор и рейтинг казино
      рейтинг казино на реальные деньги
      официальные казино в россии
      мобильное казино
      какое онлайн казино на сегодняшний день является самым честным
      официальные казино онлайн рейтинг
      казино в котором реально можно выиграть деньги и вывести
      топ 10 казино на деньги
      онлайн казино отзывы реальные
      какие казино реально выплачивают выигрыши в россии отзывы
      казино в которых реально можно выиграть деньги и вывести их на карточку без депозита
      в каком казино реально выиграть и вывести деньги
      казино онлайн с выводом реальных денег
      бесплатные лотереи онлайн с реальными выигрышами и выводом денег
      1000 рублей за регистрацию вывод сразу без вложений в казино
      казино где реально можно выиграть
      где можно выиграть реальные деньги
      игровые автоматы где реально можно выиграть и вывести деньги
      игровые автоматы играть на деньги с выводом на карту
    2. Надежный список онлайн-казино (Online Casino) на реальные деньги в  2025 году.
      Рейтинг лучших ТОП 10+ онлайн Казино ( Casino Online ) для игры на реальные деньги по выплатам. Официальный рейтинг Казино с игрой на деньги в России и Снг представляет платформы, с которых деньги выводятся быстро и с минимальной комиссией.
      Наши обзоры и рейтинги помогут вам выбрать лучшие сайты казино с реальными деньгами с хорошей репутацией в России, Украины ,Казахстана и Беларуси в 2025 году, чтобы у игроков был доступ к самым лучшим онлайн-развлечениям.
      На всех сайтах казино действует промокод BONUSFS
      ПОЛНЫЙ РЕЙТИНГ КАЗИНО С БОНУСАМИ  ТОП 120 ЖМИ ТУТ https://t.me/megawintv/1578
      Arkada Casino Казино Аркада — новое онлайн-казино с приветственным бонусом до 15 000 рублей и выбором более 7000 слотов и игровых автоматов. Официальный промокод для регистрации BONUSFS
      IRWIN CASINO - Казино Ирвин онлайн с 2025 года встречает новичков роскошными бонусами на первые три депозита — 225% + 400 фриспинов по промокоду BONUSFS .Топ рейтинга казино онлайн (online casino) на реальные деньги в 2025 году.
      Vavada casino  -Vavada Casino (Вавада Казино) — это официальный сайт онлайн-казино, предлагающий широкий выбор лучших игровых слотов. Исследуйте захватывающие игры, получайте щедрые бездепозитные бонусы и наслаждайтесь моментальными выплатами!
      BANDA CASINO— сайт-ресурс с завораживающими игровыми слотами. Бонус +300% и 100 фриспинов при входе по промокоду BONUSFS через рабочее зеркало банда  Казино .  Banda Casino – топ российское онлайн-казино с бездепозитными  бонусами и слотами на любой вкус. Банда казино зеркало доступно каждый день. Забери бонус +250% и 100FS к первому депозиту в Банда Казино!
      BABOSS KAZINO(Бабосс Казино) Официальный сайт казино Baboss Casino работает с 2025 года и получил лицензию Кюрасао. Бонус +500% и 350 фриспинов по промокоду BONUSFS .  Baboss Casino –самое выигрышное казино в интернете и топ онлайн казино на реальные деньги по выплатам.
      PINCO CASINO — сайт с дающими игровыми слотами. Бонус +150% и 250 фриспинов  по промокоду VINBONUS через рабочее зеркало пинко  Казино .  Pinco Casino – топ казино с бездепозитными  бонусами и слотами на любой вкус. Pinco казино зеркало доступно каждый день. Забери бонус +150% и 250FS к  депозиту в Пинко Казино!
      HONEYMONEY НОВИНКА декабря 2025 . Удобные платежи: СБП, карты, Piastrix, криптовалюты. Для новых игроков действуют сладкие велком-паки для золотых выигрышей: 375% до ₽90 000 + 150 ФС
      Gizbo Casino СУПЕР НОВИНКА № 1 Казино gizbo — Welcome Pack 300% + 100 FS: Начинай свой путь с крутым бездеп бонусом по промокоду BONUSFS ! Лучшие игровые автоматы на реальные деньги
      № 2. LEX казино— Лекс Казино: Надежное Казино-Онлайн на реальные деньги по промокоду BONUSFS Лучшее казино России в целом
      № 2++. PIN-UP Kz — ПИНАП Казино: Надежное Казино Казахстана Онлайн на реальные деньги по промокоду VINBONUS Лучшее казино в Казахстане в целом.
      № 3. DRIP КАЗИНО— Дрип Казино: Популярное онлайн Казино предлагает хорошие бонусы и фриспины для своих игроков по промокоду BONUSFS Новое Первоклассное казино
      № 4. Starda казино — Старда Казино: Казино с высоким рейтингом среди игроков России и СНГ по промокоду BONUSFS .ТОП Азартных игр в России
      № 5. 1GO CASINO Новинка Бонус Казино 150 % встречай новинку с лучшими игровыми слотами онлайн и выигрывай реальные деньги по промокоду BONUSFS. Самый Высокий - Приветственный бонус
      № 1.  KOMETA казино —  Комета  Казино: Топ 1 Казино онлайн на реальные деньги 2025 без пополнения по промокоду BONUSFS. Отличные Мобильные слоты
      № 2. R7 казино — Р7 Казино: Одно из самых лучших онлайн-Казино с быстрыми выплатами в игровых слотах. Лучший сайт для Азартных игр в целом
      № 3. KENT казино — Кент Казино: Лучшие игровые слоты на деньги и слоты в Казино-онлайн 2025
      MONRO КАЗИНО (Монро Казино ) — Лучшие игровые автоматы с хорошим приветственным бонусом, (Welcome Pack — 325% бонус до 1200 EUR + 100 FS) по промокоду BONUSFS
      IZZI казино: Казино онлайн с хорошей репутацией в России 2024 году (приветственный пакет 100% + 100 FS на депозит по промокоду BONUSFS )
      № 4.  VOLNA казино— Волна Казино: Казино онлайн с мобильной версией и ставками на спорт (игры на деньги).
      2.  LEGZO казино ( ЛЕГЗО Казино ) — Они предоставляют высокий уровень безопасности и большой выбор игр, включая прогрессивные джекпоты с игровыми слотами онлайн на деньги
      FRESH казино - Лучшее Казино с бонусом на депозит в 200% и 100ФС по промокоду BONUSFS
      ROX КАЗИНО - Самое свежее Казино с бонусом 200% по промокоду BONUSFS
      GAMA казино – новое российское онлайн-казино с щедрыми бонусами и слотами на любой вкус. ГАМА казино зеркало доступно каждый день. Забери бонус +250% и 100FS к первому депозиту в GAMA Казино по промокоду BONUSFS !
      Vovan Casino ( Вован Казино онлайн ) — Лидер среди онлайн Казино в России и Снг. Они имеют отличную репутацию и предоставляют многочисленные игровые автоматы и настольные игры. бонус 200%.Фриспины при регистрации
      № 4.  RIOBET Casino — Риобет Казино: Лучшие новое Казино онлайн в 2025
      № 5.  RAMENBET Casino — Раменбет: Казино с лучшими бонусами а также с бездепозитным бонусом 2025
      Лучший список онлайн-казино на реальные деньги в 2025 году
      Мы рады представить вам ТОП-рейтинг онлайн-казино для игры на реальные деньги в 2025 году. Ознакомьтесь с нашим обновленным списком лучших платформ, где вы сможете насладиться захватывающими играми и выгодными предложениями!
      7KCASINO это лучшее казино: ! 2000+ лучших слотов, ! RTP 98+% ! 200% бонус к депозиту ✓ 24/7 поддержка!
      POPERLO Casino Новинка Поперло Казино — На первый депозит игрокам доступен бонус 200% до 10 000 рублей
      1WIN Casino ( Ван вин Казино) — Это одна из самых надежных площадок для азартных игр в России и СНГ. Они предлагают большой выбор слотов, а также живые дилеры для настольных игр и фриспины по промокоду BONUSFS .
      6.VODKA ( Казино Водка ) — Это новое Казино, которое уже завоевало популярность благодаря своему разнообразному выбору игр и щедрым бонусам.
      8. Cryptoboss ( Казино Криптобосс )— Они предлагают широкий выбор игровых автоматов от ведущих провайдеров, а также живые дилеры для настольных игр.
      9. KAKTUZ Casino ( Кактуз Казино ) — Их основное преимущество заключается в том, что они предоставляют возможность делать ставки на спорт вместе с традиционными Казино-играми.
      10. БОЛЛИВУД (Болливуд казино) Проверенные временем слоты с приветственным бонусом 400%+100FS
      11. Goldcasino  (Голд казино) это ваш портал в будущее азартных игр. Новое GOLD Casino официальный сайт - Приветственный Бонус +150% и 2000FS
      12. LEVCASINO (Лев казино)- Лучшие игровые автоматы на реальные деньги
      13. ELDORADO (Эльдорадо казино)- Самый Рейтинговый Сайт для Азартных игр в России и Казахстане
      14. CLUBNIKA (Клубника казино) - Самое выигрышное казино в интернете
      15. CATCASINO(КЭТ казино)- казино в которым реально можно выиграть деньги и вывести их на карточку
      16.DADDY - Регистрация с Бонусом 65000₽ + 150 FS! Заходи и выигрывай в Дадди Казино с бонусом на первый депозит!
      17.LEEBET -казино с бонусом за регистрацию 100 фриспинов.
      18.CAZINO-X- заслужило доверие многочисленных игроков благодаря своему официальному сайту, рабочему зеркалу и популярным слотам
      19.JOYCAZINO - преимуществом Joycasino является наличие мобильной версии сайта и приложений для iOS и Android, что позволяет играть в любимые игры даже в пути
      20.VIPCASINO - VIP Casino – это интернет-казино для Украины, вся информация на сайте подаётся на русском языке
      21.METELITSA - интернет-казино с хорошей репутацией по отзывам
      Надежный список онлайн-казино (Online Casino) на реальные деньги в 2024 - 2025 году.
      Начнем с описания уникальных особенностей каждого из сайтов в нашем списке Топ-10:
      Gama Casino — этот сайт предлагает своим пользователям привлекательную бонусную программу, включающую 300% к депозиту и 100 фриспинов. Уникальной чертой Gama Casino является эксклюзивная коллекция игровых автоматов, а также специальные промокоды, которые добавляют дополнительную ценность к опыту игры.
      LEGZO Casino — сайт, который заслуживает внимания благодаря своей репутации надежного партнера. В 2024 году они укрепляют свои позиции, предоставляя своим клиентам быстрые выплаты и честную игру, что делает их платформу одной из самых доверительных на рынке.
      CAT Casino — привлекает многочисленных пользователей своим впечатляющим бонусом в размере 200% и пакетом из 150 фриспинов. Игроки отмечают широкий выбор слотов от ведущих разработчиков, что значительно повышает увлекательность игрового процесса.
      STARDA Casino — зарекомендовало себя как надежная платформа, предлагающая разнообразные традиционные казино-игры, которые удовлетворяют различные предпочтения игроков. Это делает STARDA Casino привлекательным для широкой аудитории.
      FRESH Casino — получило признание за свою скорость выплат и положительные отзывы от пользователей. Это делает сайт отличным выбором для игроков, которые ценят оперативность и надежность.
      SOL Casino — платформа, придающая особое значение безопасности пользовательских данных. SOL Casino гарантирует комфорт и защиту каждому своему клиенту, что создает атмосферу уверенности и доверия на протяжении всего игрового процесса.
      Актуальность онлайн-казино в 2025 году продолжает расти, и выбор лучших платформ становится всё более важным для игроков.
      С ростом популярности онлайн-казино в 2025 году, этот сегмент индустрии развлечений продолжает набирать обороты благодаря сочетанию доступности и удобства. Главными факторами, способствующими притяжению новых клиентов, являются привлекательные бонусные предложения, ясность игровых правил и оперативная поддержка пользователей.
      Выбор надежного онлайн-казино для игры на реальные деньги требует внимательного подхода. Важно обратить внимание на несколько ключевых аспектов: наличие лицензии, положительные отзывы от игроков, разнообразие игр в каталоге, а также скорость и комфортность проведения финансовых операций.
      Таким образом, топ-10 легальных онлайн-казино 2025 года представляет собой разнообразие платформ, которые предлагают множество услуг для любителей азартных игр на реальные деньги. Эти казино создают безопасную и комфортную игровую среду, соответствуя современным требованиям индустрии развлечений и обеспечивая своим пользователям качественный опыт.
      ТОП НОВЫХ ЛУЧШИХ ОНЛАЙН-КАЗИНО 2025 ГОДА
      Бонусы и программа лояльности
      Бонусы играют важную роль в мире онлайн-казино, предоставляя игрокам различные поощрения и привилегии. Они могут принимать разные формы и варьироваться по количеству, включая приветственные бонусы за регистрацию и дополнительные награды за последующие депозиты. Одним из ключевых аспектов программы лояльности является наличие кешбека, который способствует возвращению части проигранных средств игрокам.
      На платформе онлайн-казино также критически важно наличие большого числа провайдеров и разнообразных игр, что позволяет игрокам находить именно те развлечения, которые им нравятся. Кроме того, удобные способы ввода и вывода средств, а также разумные лимиты на снятие выигрышей имеют огромное значение для общей удовлетворенности игроков.
      Давайте рассмотрим, какие казино вошли в ТОП на начало 2025 года и конец 2024.
      MONRO Casino (225% + 100 фриспинов) — это новое онлайн-казино с быстрыми выплатами, которое впервые вошло в наш рейтинг. Оно уже успело завоевать репутацию лучшего казино для игры на реальные деньги в 2025 году.
      DADDY Casino (200% на первый депозит + 100 фриспинов) занимает второе место. Это новый проект, который привлек внимание благодаря щедрым предложениям и 2000 рублей за регистрацию без депозита.
      DRIP Casino (225% + 325 фри-спинов) находится на третьем месте в нашем рейтинге. Это еще одно новое казино от Royal-Partners, предлагающее игрокам 1000 рублей за регистрацию.
      Gama Casino (425% + 200 фри-спинов) уверенно занимает четвертую позицию. Это казино стало лидером в России и известно своим высококачественным сервисом и масштабными бонусами. промокод BONUSFS
      LEGZO Casino — надежное и проверенное онлайн-казино, замыкающее пятерку лучших казино России в 2024 году.
      Завершает наш список CAT Casino (375% + 150 фри-спинов), которое становится все более популярным среди игроков благодаря своим выгодным предложениям и впечатляющему выбору игр.  промокод BONUSFS
      Таким образом, в 2025 году на игроков ждут многие интересные возможности в мире онлайн-казино. Выбирайте казино по душе и наслаждайтесь увлекательными играми и щедрыми бонусами!
      КАЗИНО ГДЕ ИГРАТЬ НА ДЕНЬГИ ОНЛАЙН В 2025
      Каждый игрок, решивший попробовать себя в онлайн Казино, стремится найти не только увлекательные игры, но и надежную платформу для ставок. Основными критериями выбора являются лицензия, ассортимент игр, бонусы, качество обслуживания клиентов и удобство платежных операций.
      В 2025 году многие онлайн Казино на деньги предлагают обширный выбор слотов, настольных игр, игр с живыми дилерами и других развлечений от ведущих разработчиков игрового софта. Привлекательность таких сайтов усиливается прозрачными и быстрыми финансовыми операциями, а также высоким уровнем защиты личных данных игроков.
      ЛУЧШИЕ САЙТЫ КАЗИНО С ЛИЦЕНЗИЕЙ ДЛЯ ИГРОКОВ
      Лицензия является основным признаком надежности и безопасности казино. Она подтверждает, что платформа регулярно проходит проверки со стороны регулирующих органов, что гарантирует игрокам честность и прозрачность игровых процессов. Для игроков из России и стран СНГ наиболее распространены лицензии, выданные в  Кюрасао, Мальты, Великобритании и других авторитетных юрисдикциях.
      ТОП-10 КАЗИНО НА РЕАЛЬНЫЕ ДЕНЬГИ
      Чтобы упростить ваш выбор и сэкономить время, мы составили список онлайн-казино, на которые стоит обратить внимание в 2025 году:
      1. Казино X - это заведение славится своей обширной коллекцией игр и щедрыми бонусными предложениями.
      2. Банда - привлекает внимание игроков возможностью заработка на реальных ставках и постоянными интересными акциями.
      3. Вавада - предлагает широкий ассортимент слотов и настольных игр, отличающихся высокой графикой и увлекательным игровым процессом.
      4. КЕНТ Casino - располагает лицензией Мальты и предоставляет поддержку своим клиентам круглые сутки.
      5. Joy Casino - интерфейс этого казино отличается интуитивной простотой и удобством для пользователей.
      6. 1ГО Casino - обращает особое внимание на безопасность и приватность своих игроков, что делает его надежным выбором.
      7. КЕНТ Casino - настоящий рай для поклонников слотов и живых игр, предлагающий разнообразные развлечения.
      8. Иззи казино - активно оперирует на российском рынке и предлагает привлекательные условия для своих клиентов.
      9. Водка Casino - это заведение сочетает в себе как традиционные, так и современные игры, создавая уникальную атмосферу.
      10. Эльдорадо Casino - это имя давно зарекомендовало себя в индустрии и предлагает широкий ассортимент игр на любой вкус.
      Эти казино обеспечивают высокий уровень обслуживания и интересные возможности для азартных игроков в 2025 году.
      ВЫБОР ОНЛАЙН КАЗИНО
      При выборе онлайн-казино важно учитывать ваши личные предпочтения, чтобы обеспечить максимально комфортный игровой процесс. Обратите внимание на типы предлагаемых игр, наличие ваших любимых слотов и удобство интерфейса, а также на доступные методы внесения и вывода средств. Все эти факторы играют значительную роль в создании положительного опыта.
      Кроме этого, стоит ознакомиться с рейтингами казино, так как они часто отражают реальные отзывы и впечатления других игроков. Это поможет вам определить, какие заведения заслуживают доверия и имеют хорошую репутацию на рынке.
      В заключение, онлайн-игры в 2025 году открывают перед игроками из России и СНГ множество новых возможностей. Список лучших онлайн-казино позволит вам выбирать только те площадки, которые гарантируют честность и безопасность игрового процесса. Желаем вам удачи в ваших приключениях!
      На этом наш обзор и рейтинг лучших онлайн-казино для игры на реальные деньги подходит к концу. Мы представили ТОП новых казино 2025 года, каждое из которых отличается надежностью, опытом работы на рынке и положительными отзывами со стороны пользователей. Все эти заведения зарекомендовали себя как надежные и с ними не возникало проблем с выплатами!
      НАС НАХОДЯТ
      топ 10 лучших казино
      лучшие казино на 2025
      лучшие казино на реальные деньги
      лучшие сайты онлайн казино
      top casino online
      рейтинг лучших онлайн казино
      рейтинг лучших казино
      10 лучших казино онлайн
      популярные онлайн казино
      top 10 best online casinos
      best online casino for real money
      top 10 online casino sites
      топ 10 рейтинг лучших казино
      Проверенные онлайн казино с выводом денег
      Игры на деньги с выводом на карту без вложений
      Казино онлайн Росии
      Онлайн казино с выводом денег на карту
      Онлайн игры на деньги с выводом на карту
      лучшие онлайн-казино
      Онлайн казино без верификации
      топ казино в россии онлайн
      самые популярные казино в мире
      вавада казино официальный сайт
      казино в котором реально можно выиграть деньги и вывести скачать
      онлайн казино без вложений с выводом денег
      реально ли выиграть в казино вулкан в интернете отзывы проверенные
      бонусы казино без депозита
      бонусы казино бездеп
      в каком казино дают деньги за регистрацию без депозита
      бонусы казино за регистрацию
      бонусы без отыгрыша за регистрацию
      покупные бонусы в казино
      Бездепозитные бонусы казино
      Свежие бездепозитные бонусы казино за регистрацию
      Все казино с бонусом без депозита с выводом
      Бездепозитный бонус за простую регистрацию сразу на счет с выводом
      Лучшие бездепозитные бонусы казино
      1000 за регистрацию без депозита казино
      Казино с бонусом за регистрацию без депозита
      Бездепозитный бонус за регистрацию по номеру
    Vladimir Y
    Vladimir Y
  • Ремонт и обслуживание Jeep
    • Yurgen15
      Yurgen15  »  up6
      · 3 ответа
    • Jeep Spot
      Jeep Spot  »  AG
      Всем привет! 👋
    • ROKO
      ROKO  »  Лунный пчел
