Р2204
Owidij
Автомобиль: Wrangler
Сегодня в Автолайте выполнил реколл J30, теперь сидит ошибка. И не стирается. Что это может значить? Я не про расшифровку. Откуда она взялась?
SAFETY RECALL J30
REPROGRAM CCN - TRANSMISSION FLUID TEMPERATURE WARNING
Dear: (Name)
This notice is sent to you in accordance with the requirements of the National Traffic and Motor Vehicle Safety
Act.
Chrysler has decided that a defect, which relates to motor vehicle safety, exists in some 2008 model year
Jeep® Wrangler vehicles.
The problem is... The transmission fluid in your vehicle (VIN: xxxxxxxxxxxxxxxxx) may overheat
under certain driving conditions. Continuous operation under these conditions
may cause the transmission fluid to boil over and come in contact with hot engine
or exhaust components. This could cause an underhood fire without warning.
What your dealer
will do...
Chrysler will repair your vehicle free of charge (parts and labor). To do this, your
dealer will reprogram the Cabin Compartment Node (CCN) module to add a
transmission temperature warning feature to the vehicle. An Owner’s manual addendum
will also be provided on the operation and function of this new feature. The work will
take about 1/2 hour to complete. However, additional time may be necessary depending
on service schedules.
What you must
do to ensure your
safety...
Simply contact your dealer right away to schedule a service appointment.
The addendum on the back of this letter supplements your Owner Manual. Please
place this letter in the Owner’s Manual of your vehicle for reference by you or
future owners.
If you need help... If you have questions or concerns which your dealer is unable to resolve, please contact
Chrysler at 1-800-853-1403.
Please help us update our records by filling out the attached prepaid postcard, if any of the conditions listed on
the card apply to you or your vehicle. You may also update this information on the web at
CCCCCCCCCCCCCCCCCCCCCCCCCC
If you have already experienced this condition and have paid to have it repaired, you may send your original
receipts and/or other adequate proof of payment to the following address for reimbursement: Chrysler Recall
Customer Assistance, P.O. Box 21-8007, Auburn Hills, MI 48321-8007, Attention: Reimbursement.
If your dealer fails or is unable to remedy this defect without charge and within a reasonable time, you may
submit a written complaint to the Administrator, National Highway Traffic Safety Administration, 1200 New
Jersey Ave., S.E., Washington, DC 20590, or call the toll-free Vehicle Safety Hotline at 1-888-327-4236 (TTY
1-800-424-9153), or go to http://www.safercar.gov.
We're sorry for any inconvenience, but we are sincerely concerned about your safety. Thank you for your
attention to this important matter.
Customer Services Field Operations
Chrysler Group LLC
Notification Code J30
Note to lessors receiving this recall: Federal regulation requires that you forward this recall notice to the lessee within 10 days.
OWNER’S MANUAL ADDENDUM
“HOTOIL” Transmission Temperature Warning Message
The “HOTOIL” cluster message accompanied with a continuous audible chime indicates that there is excessive
transmission fluid temperature that might occur with severe usage such as trailer towing. It may also occur
when operating the vehicle in a high torque converter slip condition, such as 4-wheel-drive operation
(e.g., snow plowing, off- road operation). If this “HOTOIL” message accompanied with a continuous chime
comes on, stop the vehicle and run the engine at idle or faster, with the transmission in NEUTRAL until the
light turns off.
CAUTION!
Continuous driving with the Transmission Temperature “HOTOIL” Warning message illuminated will
eventually cause severe transmission damage or transmission failure.
WARNING!
Continued operation with the Transmission Temperature “HOTOIL” Warning message illuminated
could cause the fluid to boil over, come in contact with hot engine or exhaust components causing a fire
that may result in personal injury.
Disabling Electronic Stability Program (ESP) for Modified Vehicles (4WD Models Only)
Vehicles modified with larger tires and/or suspension lifts may experience early ESP activations as compared
to a non-modified production vehicle depending on lift size, tire size, suspension changes and/or driving habits.
If early ESP activations are experienced while driving a modified vehicle, the additional ability to permanently
turn off ESP is available. A steering wheel/ESP button maneuver must be performed to permanently disable
ESP and defeat the functionality of the ESP switch. Repeating the procedure will return the system to normal
ESP operation and restore ESP switch functionality allowing ESP “Partial” or “Off” modes.
WARNING!
With ESP in the permanent disable mode, enhanced vehicle stability offered by the ESP and Electronic
Roll Mitigation (ERM) systems is unavailable. In an emergency evasive maneuver, the ESP and ERM
systems will not engage to assist in maintaining stability. This disabled mode is intended for off-highway
or off-road use only. Vehicle modifications requiring the owner to configure the vehicle in the ESP
disabled mode will seriously affect the vehicle’s roadworthiness and safety and may lead to loss of
control and/or accident resulting in possible serious or fatal injuries.
The following procedure will disable (or re-enable) ESP functionality in the vehicle:
1. Shift the transfer case into the 4H range position.
2. Turn the steering wheel until it is centered and the wheels are pointed straight ahead.
3. Cycle the ignition key OFF to ON.
4. Wait approximately five seconds for the system bulb check.
5. Turn and hold the steering wheel one-half turn to the right (clockwise).
6. Press and hold the ESP OFF button for seven seconds.
7. Turn the steering wheel back to center, and turn and hold an additional one-half turn to the left
(counter clockwise).
8. Press and hold the ESP OFF button for seven seconds.
9. Turn the steering wheel back to center.
10. Press and hold the ESP OFF button for seven seconds.
11. Cycle the ignition key to OFF.
After performing the ESP disable procedure correctly, “ESP OFF” will be displayed in the odometer for
approximately 12 seconds each time the ignition is moved to ON. Repeating the ESP disable procedure will
re-enable normal ESP operation.
Изменено пользователем Owidij
vin???
20
1J4FAB4168L628915
На неделе буду звонить в Автолайт и разбираться. Только со временем весьма туго((. Поэтому и создал топик.
под Ваш ВИН Р2204 я не нашел... чем Вы ее считали?
240
Автомобиль: большой автопарк
Р2204
Что-то невнятное
20
Сорри! В потьмах перепутал! :o
B(BODY)2204
B2204-ECU CONFIGURATION MISMATCH
причина WIRELESS CONTROL MODULE (WCM)/SENTRY KEY REMOTE ENTRY MODULE (SKREEM)
можно попробовать сделать реконфигурацию авто - чтобы заново модули узнали друг друга в соответствии с ВИНом. Особой диагностики по ней нет, если не стирается, надо менять ИММо. С реколлом, ИМХО, не связано.
20
Спасибо, Андрей.
Автомобиль: Jeep JK
Что может работать не логично итд, какие последствия если не делать реконфигурацию авто - чтобы заново модули узнали друг друга в соответствии с ВИНом  - если оставить ошибку B2204
Cпасибо.
все что угодно, ехать будет, но косяки возможны разные
Автомобиль: Jeep JK
Смотрели эту ошибку через комп Лаунч дилерский,через прогу под Крайслер,запускали реконфигурацию,загорались все лампочки в комбинации приборов авто,ошибка и после всего это шаманства висит.
Мож,что-то не так делали -?
Изменено пользователем Борменталь
реконфигурацию может сделать только ОД - машина качает прошивки модулей с сервера Крайслера, для этого нужна авторизация - Лауч такого сделать не может, он не является дилерским сканером
Автомобиль: Jeep JK
Спасибо.
Поеду к дилеру,к какому и куда лучше - ?,чтоб общение было с пониманием и умением пользоваться оборудованием - а не как ....... на новые ворота.
п.4.9 Правил
Интересный вопрос, к кому нибудь из старых надо ехать. Или к конкретному человеку
  • Кто в онлайне   7 пользователей, 0 анонимных, 183 гостя (Посмотреть всех)
    • КОГ52
    • vrv377
    • Nervosi
    • JimmyT
    • sten740
    • Barnaulec
    • Vladislav grandcherokeeWJ
      Комплектации
