Память сидений!
Автомобиль: WK
Ребята как правильно пользоваться памятью?)) В какой последовательности что нажимать?))
Автомобиль: Land Rover Discovery 2
Выставил сиденье, нажал на set (S, на wj будет моргать) и выбрал цифры
20
Автомобиль: Jeep GC WH 4.7 2005 - был.... Jeep GC WH 5.7 2006 - был...
есть описание настроек на английском, но я пока что с этим не разобрался
DRIVER MEMORY SYSTEM — IF EQUIPPED
Once programmed, the memory buttons 1 and 2 on the
driver’s door panel can be used to recall the driver’s seat,
driver’s outside mirror, adjustable brake and accelerator
pedals, and radio station preset settings. Your Remote
Keyless Entry transmitters can also be programmed to recall
the same positions when the “Unlock” button is pressed.
Your vehicle may have been delivered with two Remote
Keyless Entry transmitters. One or both transmitters can
be linked to either memory position. The memory system
can accommodate up to four transmitters, each one
linked to either of the two memory positions.
Setting Memory Positions and Linking Remote
Keyless Entry Transmitter to Memory
NOTE: Each time the SET (S) button and a numbered
button (1 or 2) are pressed, you erase the memory settings
for that button and store a new one.
1. Insert the ignition key and turn the ignition switch to
the ON position.
2. Press the driver door memory button number 1 if you
are setting the memory for driver 1, or button number 2
if you are setting the memory for driver 2. The system
will recall any stored settings. Wait for the system to
complete the memory recall before continuing to step 3.
3. Adjust the driver’s seat, recliner, and driver’s side
view mirror to the desired positions.
4. Adjust the brake and accelerator pedals to the desired
positions.
5. Turn on the radio and set the radio station presets (up
to 10 AM and 10 FM stations can be set).
6. Turn the ignition switch to the OFF position and
remove the key.
7. Press and release the SET (S) button located on the
driver’s door.
8. Within 5 seconds, press and release memory button 1
or 2 on the driver’s door. The next step must be performed
within 5 seconds if you desire to also use a
Remote Keyless Entry transmitter to recall memory positions.
9. Press and release the “Lock” button on one of the
transmitters.
10. Insert the ignition key and turn the ignition switch to
the ON position.
11. Select Remote Linked to Memory in the Electronic
Vehicle Information Center (EVIC) and enter Yes or
select Use Factory Settings from the EVIC and enter
Yes. Refer to “Customer Programmable Features” in the
Electronic Vehicle Information Center (EVIC) section for
more information.
12. Repeat the above steps to set the next memory
position using the other numbered memory button or to
link another Remote Keyless Entry transmitter to
memory.
Memory Position Recall
NOTE: The vehicle must be in Park to recall memory
positions. If a recall is attempted when the vehicle is not
in Park, a message will be displayed in the Electronic
Vehicle Information Center (EVIC).
To recall the memory settings for driver one, press
memory button number 1 on the driver’s door or the
“Unlock” button on the Remote Keyless Entry transmitter
linked to memory position 1.
To recall the memory setting for driver two, press
memory button number 2 on the driver’s door or the
linked to memory position 2.
A recall can be cancelled by pressing any of the memory
buttons on the drivers door during a recall (S, 1, or 2).
When a recall is cancelled, the driver’s seat, driver’s
mirror, and the pedals stop moving. A delay of one
second will occur before another recall can be selected.
To Disable A Transmitter Linked to Memory
1. Turn the ignition switch to the OFF position and
remove the key.
2. Press and release memory button number 1. The
system will recall any memory settings stored in position
1. Wait for the system to complete the memory recall
3. Press and release the memory SET (S) button located
4. Within 5 seconds, press and release memory button 1
5. Within 5 seconds, press and release the “Unlock”
button on the Remote Keyless Entry transmitter.
To disable another transmitter linked to either memory
position, repeat steps 1-5 for each transmitter.
NOTE: Once programmed, all transmitters linked to
memory can be easily enabled or disabled at one time.
Refer to Remote Linked to Memory under Customer
Programmable Features in the Electronic Vehicle Information
Center (EVIC) for more information.
из другого руководства:
MEMORY SYSTEM PROGRAMMING
The Memory Seat Module (MSM) interfaces with the Remote Keyless Entry (RKE) system via the Controller Area
Network (CAN) bus. The proper procedure of setting and recalling a memory position using the RKE is as follows:
1. Press and release memory switch 1 or 2 to recall memory position 1or 2.
2. Adjust the seat, recliner, adjustable pedal position, set radio station presets, set HVAC temperature preset, and
the side view mirrors to the desired position.
3. Press momentarily and release memory switch S.
4. Within five seconds, press momentarily and release memory switch 1 or 2.
5. To link the RKE transmitter: within ten seconds, press and release the “LOCK” button on one of the RKE transmitters
To program the second driver’s position, repeat the above procedure using memory switch 2. The second RKE
transmitter can be programmed in the same fashion as indicated in step 5 Step 5.
NOTE: The module will abort a recall if the transmission is moved out of park or if any seat movement is
activated whether manually or by memory recall. The module will also abort a recall if any movement of the
adjustable pedals is detected.
To recall either of the programmed positions momentarily press and release either memory selector switch 1 or 2.
If using RKE, just press and release the “UNLOCK” button on the proper transmitter for either position 1 or 2.
A recall is possible any time the vehicle transmission is in PARK and the seatbelt is unbuckled. This condition is
monitored by the MSM.
Так по важным пунктам
Запоминаются: сидушки, педали, зеркала, радио станции.
Может быть запрограммировано на два пульта, тоесть открывая каждым будут режимы 1 или 2.
как то геморно имхо smile
1. воткните ключь и включите зажигание
2. Нажмите нужную кнопку, 1 или 2 (в зависимости от желания)
Подождать чуть чуть Програмируется
3. Отрегулировать все что надо, сидушки, зеркала
4. теперь отрегулируйте педальный узел
5. включите и настройте радиостанции
6. Поверните ключ зажигания в положение OFF и вытащите ключ
7. Нажмите и отпустите кнопку SET (S) кнопку, расположенную на водителя дверь.
8. В течение 5 секунд нажмите и отпустите кнопку памяти 1
или 2 на двери водителя. Следующим шагом должно быть выполнено
в течение других 5 секунд, если Вы хотите использовать
с ДУ передатчика эти позиции памяти.
9. Нажмите и отпустите кнопку "Lock" на один из
передатчиков.
10. Вставьте ключ зажигания и поверните ключ зажигания
11. Выбирите Remote Linked to Memory в бортовом кумпутере сверху и выберите YES (все что дальше не понял нехрена, но смысл в том что можете не делать линковки ключа к этим настройкам выбрав и подтвердив Use Factory Settings)
12. Повторите все это для второго брелка
Ну в общем как то так smile Гермно однако smile
Кстати на WJ есть такое примечание:
Вы можете вызвать автоматические регулировки, только если рычаг селектора автоматической коробки передач находится в положении P (Стоянка) и не пристегнут ремень безопасности на месте водителя.
65
Автомобиль: WK
Bloody, Про ремень безопасности и тута чет то ругается!)) Черт, как все сложно!))
Ну я думаю получится smile Я вот тоже снимал обшивку и пристегнул ремень за кресло, и думаю почему не работает :))))
65
Автомобиль: WK
Bloody, А еще эти кнопки реально в неправильном месте расположены!) Как не сиди , задеваешь их коленом!) И постоянно че то пишет на компе!))))
Ну видимо потому так и геморойно, у меня на wj просто выстроил все что надо, нажал set и цифру, и все
65
Автомобиль: WK
Bloody, Буду пробовать!)) Нужно инструкцию прям переписать!)) А лучше распечатать и повесить рядомм!)))ЫЫ)))
  • Кто в онлайне   7 пользователей, 0 анонимных, 114 гостей (Посмотреть всех)
    • Dim2013
    • Musafer
    • 777karo
    • Nickita
    • santab
    • Aleksandr60
    • C070CC
    1. Compass с тряской мотора и ватным рулём
      Jeep Compass (MP) 2019 года с мотором 2.4 MultiAir приехал с двумя жалобами сразу: трясёт на холостых и руль стал тяжёлым, машина запаздывает на повороте. Симптомы из разных систем, поэтому в ТРС-Моторс разбирали их параллельно — часть по подвеске, часть по обслуживанию двигателя.
      Подключили wiTECH, опросили блоки: по двигателю чисто, ни пропусков, ни сбитых адаптаций. Это сразу убрало из версий пробитую катушку или мёртвую форсунку по конкретному цилиндру — там код вылезает быстро.
      Люфт в рулевых наконечниках и трещины в сайлентблоках
      Покачали колесо в горизонтальной плоскости и нашли люфт в рулевых наконечниках, тяги под замену. Передние нижние рычаги проверили следом: сайлентблоки с глубокими трещинами, материал расслоился и посадочные места уже не держат рычаг в правильном положении.
      Отсюда и тяжёлая, неточная реакция руля: рычаг гуляет, машина отрабатывает поворот с задержкой.
      Почему 2.4 MultiAir трясёт без ошибок в ECU
      MultiAir управляет впускными клапанами гидравликой вместо привычного распредвала: фазы и подъём задаёт масляное давление через электрогидравлический модуль над головкой. Такая схема чувствительна к качеству смеси, и на грязном дросселе с изношенными свечами горение гуляет от цикла к циклу.
      ECU пишет пропуски только тогда, когда их доля превышает заводской порог. На этих свечах и загрязнённом дросселе нестабильность уже есть, а до порога не дотягивает: симптом налицо, кода нет. Частая картина на 2.4 MultiAir в Compass и Renegade, поэтому первым шагом меняют свечи и чистят заслонку.
      Чем закончили ремонт Compass
      Рулевые тяги заменили обе сразу, чтобы после сход-развала не возвращаться за второй стороной. Сайлентблоки передних нижних рычагов поставили новые, затем машину загнали на стенд развал-схождения: со снятыми тягами углы заведомо сбиты, без регулировки выпускать нельзя.
      По мотору поставили комплект свечей и почистили дроссельную заслонку. На MultiAir это базовое обслуживание, которое чаще всего и пропускают.
      Что замечать владельцам Compass до критической стадии
      Руль стал ватным и машина запаздывает на повороте — смотрите рулевые наконечники и сайлентблоки передних рычагов. На Compass MP резина в передней подвеске сыплется от реагентов уже после нескольких зим, раньше регламента.
      Лёгкая дрожь на холостых без ошибок на приборке — повод проверить свечи и дроссель, а не катушки: катушки на 2.4 MultiAir обычно ходят дольше свечей, и без явных пропусков по цилиндру менять их рано. Если добавился свист с впуска или плавают холостые, проверяют датчик положения дросселя и патрубки. Та же логика работает на Jeep Renegade и Dodge Dart с этим же мотором.
    3. Графит
      • 100470
