Как снять кнопку старт/стоп (Рестайл)
Цитрамон
Автомобиль: Jeep Grand Cherokee 3.0 CRD
Здравствуйте!
Подскажите пожалуйста, как на Рестайле снять кнопку старт/стоп?
И нужно ли прописывать/программировать новую?
У меня был гайд сохранен ещё давно. Но я его потерял. Помню лишь, что нужно отстегнуть центральную консоль.
5 659
Зачем кнопку трогаешь?
Basil
321
прям ножницами ее выковыриваете с хрустом.....
снимается просто.
но,Глеб,вашей беде оно не поможет.дело не в ней
вот ,как и положено злобному Тролю, я Вам почитать принес:
The ignition system operation begins when an owner approaches the vehicle with a FOB with Integrated Key (FOBIK) somewhere on their person or belongings, i.e., in their gym bag. When the owner touches the handle to pull the door open, door handle electronics signal the RFHM with a “request to open”. The RFHM uses all of the 5 LF (low frequency) antennas to communicate with the FOB. Once located, the FOB’s rс:esponse is evaluated by the RFHM to determine if the person pulling on the door handle is in fact the owner. This process completes ‘FOB authentication’.
Once authentication is successfully completed, the RFHM requests the Body Control Module (BCM) to unlock the affected door. Once the doors unlock, the owner is then free to continue pulling the door handle in an attempt to enter their vehicle. This process of opening the door without actively using a FOBIK or key is called ‘passive entry’. This vehicle when activating the passive entry switch activates the door unlock motor only.
After the vehicle’s owner is buckled, he/she pushes the KIN’s SSB (Keyless Ignition Node’s Start/Stop Button) while pushing the brake pedal as if braking while coming to a stoplight. (For manual transmission vehicles the clutch pedal is depressed instead of the brake pedal to initiate a start procedure). Before the vehicle is allowed to start, another ‘FOB authentication’ cycle must be completed. Once successfully completed, the RFHM next sends the BCM the ignition switch position, which equates to a ‘request to start’ command. The process of starting a vehicle without the act of using a bladed key or FOBIK is called ‘Keyless Go’.
The passive entry works when the FOBIK can be located outside the vehicle using the LF antennas. Keyless go operates when the RFHM can locate the FOBIK inside the vehicle. Please refer to the owner’s manual for more information on authentication zones.
After putting the vehicle into park, pushing the KIN’s SSB allows the vehicle’s engine to be shut off. In an emergency, pressing the SSB continuously for 2 seconds or repeatedly (one hit every 30- 500msec) shuts off the engine.
Изменено пользователем Basil
Basil
321
Basil
321
там шина ...надо бы ее как то смоделировать
205
Красную хочу)
Basil
321
если на массу замкнуть,то будет и красной попервости.)))
не надо ее снимать.а уж разбирать тем более.
в ней ничего нет.  пружина,паук и непонятная деталь. в ней нет ничего интересного.
205
6 минут назад, Basil сказал:
Я наверное недостаточно объяснил.
Я хочу красную кнопку, как на СРТ. Хотел бы поменять свою чёрную, на красную. Не разбирая механизм, а заменив его целиком.
Basil
321
4 минуты назад, Цитрамон сказал:
А!!!!
:lol2::lol2:я то думал!!!!!Извиняюсь,решил,что стартер Вас доканал до крайности и вы решились на крайние меры.
привозите,пропишем. на край,кнопку переставим
уже везем... готовьте прописывающее устройство...
5 659
а что там прописывать??
не знаешь? а вот знающие люди знают... прописывают кнопки на раз-два
146
6 2012 г
Есть вариант замены цвета кнопки абсолютно безопасный для неё болезной, и автомобиля в том числе. И очень очень бюджетный по деньгам и времени. Берём 3-5 грамм Красной краски, Кисточку, и вуаля! Кнопка Красная! Если надоест красный цвет, тем же способом перекрашиваем в любой другой желаемый :D:D
  • Кто в онлайне   0 пользователей, 0 анонимных, 136 гостей (Посмотреть всех)
    1. Графит
      • 7
      • 803
