Продам CRH550 LOCKPICK
vladk
Автомобиль: WK2 2012 3.0 Overland
Продам комплект CRH550 LOCKPICK с инструкцией по установке (см. фото).
Комплект пролежал несколько лет в шкафу и ни разу не использовался.
Цена - 15 т.р.
39
- Activate video out with audio in all capable Apple products and display it on the front screen.
- Activate the iPod OUT function in the iPhone/iTouch/iPad devices (also 6th Gen Nano) for amazing integration.
- Search Playlists, Artists, Albums Songs, Genres, Composers one at a time or alphabetically for long lists.
- Display Album Art, time graphs and more from your favorite songs..
- Play movies from your iPod/iPhone/iTouch/iPad on your radio screen.
- Stream NETFLIX movies and TV shows from your iPhone or iPad directly to your radio.
- Touch screen operation plus steering wheel controls for all functions.
- Automatically activates the camera input on all Mygig radios as well as the VES and the Sat TV mode.
- The interface allows manual and automatic activation of front/rear/left/right cameras and provides standard video inputs for each as well as providing camera power connections.
- AUX inputs for video and audio are also included allowing connections from any type of multimedia device to display on the front screen and the audio to be heard through the sound system.
- Provide outputs for audio and video to external screens or headrests. The output is fully dual zone allowing independent viewing of video and audio from any of the connected sources regardless of what is being viewed on the the front screen.
- Unlock the factory DVD player for use anytime.
- USB upgradeable to keep it current with Lockpick advances and vehicle changes.
- PLUG AND PLAY INSTALLATION - SIMPLE - NO WIRING, SOLDERING OR TAPS - JUST PLUG IT IN!
493
7 2007
MB G300 TD 97г
Jeep GC WJ Lim 2001
Jeep Cherokee KJ 2006
Ford Explorer 4.0 2003
Jeep GC ZJ 1995.
классная штука! а что это?)
Изменено пользователем Gooodwin
39
7 часов назад, Gooodwin сказал:
В свое время обсуждали:
39
10 000 руб.
Автомобиль: Крайслер Гранд Вояджер
Заинтересовало предложение.
  • Кто в онлайне   6 пользователей, 0 анонимных, 139 гостей (Посмотреть всех)
    • Pag80
    • santab
    • solsws
    • AS8
    • Piters
    1. Илья_СХ27
    2. Графит
      • 85644
    3. Grand Cherokee WL с мотором 3.6 приехал на большое ТО
      Машину купили без внятной истории обслуживания и сразу пригнали в ТРС-Моторс с простой задачей: обновить все технические жидкости. Пробег 101 тысяча, мотор 3.6 Pentastar.
      Раз историю предыдущего владельца проверить нельзя, поменяли всё разом: масло в двигателе, переднем и заднем редукторах, раздатке и АКПП, плюс антифриз. Заодно заглянули в свечи и проверили блоки управления, и там нашлись позиции, которые лучше закрыть в этот же визит.
      Зазор на свечах ушёл за допуск, а вспомогательная батарея села
      Свечи к этому пробегу были в плохом состоянии. На первом и четвёртом цилиндрах зазор дорос до 1.4 мм при допуске 1.1 мм. Зазор растёт по мере выгорания электродов: чем он больше, тем труднее искре пробить промежуток. Отсюда пропуски и неровная работа, особенно на холодном пуске. Свечи заменили.
      Отдельно сыпал ошибками аккумулятор системы старт-стоп. Эта батарея работает независимо от основной и питает потребители при повторном пуске двигателя после остановки на светофоре. Запуски она отрабатывает постоянно, поэтому исчерпывает ресурс раньше основного аккумулятора. К сотне тысяч она своё отработала, поставили новую.
      Прошивки блоков на WL и замена масла по узлам
      Прошивки на WL заливаются только дилерским сканером. Штатное крайслеровское оборудование на новых машинах с шиной CAN FD при подключении просто требует MDP и дальше не пускает: ни ошибку прочитать, ни прошить. Через MDP обновили блоки управления.
      Полную замену жидкостей при покупке делаем не просто так. Масло в редукторах, раздатке и коробке могло не меняться ни разу, а накопившаяся в нём металлическая фракция ускоряет износ. Проще обновить всё сразу и дальше вести машину по нормальному регламенту.
      После новой вспомогательной батареи ошибки по старт-стопу ушли, свечи свежие, жидкости обновлены по всем узлам, блоки прошиты. Машину отдали владельцу.
      На что смотреть на Grand Cherokee 3.6 к сотне тысяч
      Неровная работа на холодном пуске и пропуски — повод проверить свечи. Их ресурс на 3.6 около 80 тысяч, к сотне зазор уходит за допуск. На покупаемой машине с пробегом под 100 тысяч свечи стоит смотреть в первую очередь.
      Ошибки по аккумулятору на приборке после пары лет работы старт-стопа означают, что вспомогательная батарея на исходе. При покупке с неизвестной историей не верьте формулировке «масло залито на весь срок»: масло в АКПП по нашему регламенту меняется каждые 60 тысяч, иначе срок службы коротким. Заодно проверьте масло в редукторах и раздатке — на больших пробегах оно темнеет и набирает металлическую фракцию.
      Если к этому добавляется вой из редукторов под нагрузкой или вибрация на разгоне, причина уже в другом узле и требует отдельной диагностики.
