Расшифровка VIN
Автомобиль: Grand Cherokee WJ 4л 1999
up6 -Благодарю!
  • Ответов 2,4 тыс
  • Sergey_B
    125
  • Arny-xxl
    74
  • rakitsky
    30
Добрый вечер всем! Расшифруйте пожалуйста ВИН 1C4RJFJM8EC224762! Интересует дата выпуска и комплектация! Заранее спасибо.
Year/Model: 2014 JEEP GRAND CHEROKEE SUMMIT 4X4 SPORT
Last Odometer: 0 kilometers on
Body Style: WKJT74
Engine: EXF-3.0L V6 Turbo Diesel Engine
Transmission: Odometer Type: kilometers
Color 1: PW7-Bright White Clear Coat
Color 2: QW7-Bright White Clear Coat
Build Date: 16 Июнь 2013 г. - собрана
продана в Таллине
опции
AAUS Summit Edition Group APAS Monotone Paint AWSS Smoker's Group
BHCS Rain Brake Support BHDS Ready Alert Braking BNBS Electronic Stability Control
BNGS Hill Start Assist BNHS Hill Descent Control BNRS Four Wheel Traction Control
BNTS Trailer Sway Damping CAJS Ventilated Front Seats CBDS Active Head Restraints
CCAS Under Seat Lighting CFNS Rear 60/40 Folding Seat CF4S Child Seat Upper Tether Anchorages
CGSS Supplemental Side Air Bags CGUS Child Seat Anchor System-LATCH Ready CGYS Drvr Inflatable Knee-Bolster Air Bag
CG3S Advanced Multistage Front Air Bags** CG6S Center Rear 3-Point Seat Belt CJ1S Supplemental Frt Seat Side Air Bags
CKDS Floor Carpet CKRS Cargo Net CKTS Cargo Tie Down Loops
CLHS Cargo Trim Panel w/Storage Net CLZS Luxury Front/Rear Floor Mats w/Logo CSCS Cargo Compartment Cover
CSRS Passenger Assist Handles CTCS Luxury Door Trim Panel CUFS Full Length Floor Console
CUNS Overhead Console CVWS Leather Wrapped Shift Knob CWPS Illuminated Cupholders
CXES Elec. Steering Column Shaft Lock DJCS 195MM Front Axle DKAS Quadra-Trac II ® 4WD System
DLKS 3.45 Rear Axle Ratio DS7S Conventional Differential Frt Axle GAPS Laminated Front Door Glass
GBBS Tinted Windshield Glass GCBS Front Door Tinted Glass GFAS Rear Window Defroster
GNCS Sun Visors w/Illum Vanity Mirrors GN5S RR View Auto Dim Mirror w/Microphone GWJS Dual-Pane Panoramic Sunroof
GXDS Remote Proximity Keyless Entry GXMS Remote Keyless Entry GXXS Sentry Key Theft Deterrent System
GX4S Keyless Enter-N-Go GYCS Power Folding Multi-Function Mirrors HAFS Air Cond ATC w/Dual Zone Control
HGAS Hood Insulation HGPS Premium Insulation Group JAJS Premium Instrument Cluster w/Tach
JDJS 240 KPH Primary Speedometer JHBS Rear Window Wiper/Washer JHCS Rain Sensitive Windshield Wipers
JJBS Dual Note Electric Horns JJMS Auxiliary 12-Volt Rear Power Outlet JKPS 12V Auxiliary Power Outlet
JKYS Power Accessory Delay JMAS Air Filtering JPBS Power Locks
JPMS Heated Front Seats JPZS Heated Second Row Seats JP3S Pwr Front Windows, 1-Touch,Up Down
JRCS Power Liftgate JRNS Pwr Driver/Pass 4-Way Lumbar Adjust JT2S Pwr 8-Way Drvr Mem 8-Way Pass Seats
LACS Illuminated Entry LAXS Front Passenger Seat Belt Alert LAYS LED Tail Lamps
LAZS Vehicle Information Center LBCS Glove Box Lamp LBRS Front Rear Interior LED Lamps
LCBS Door Courtesy Lamps LCRS Interior Removable/Rechargeable Lamp LEWS Radio/Driver Seat/Mirrors Memory
LMGS Automatic Headlamps LMQS Adaptive Bi-Xenon HID Headlamps LMSS Auto High Beam Headlamp Control
LMZS LED Daytime Running Headlamps LNNS Premium Fog Lamps LPGS Rear Fog Lamps
LSDS Deluxe Security Alarm LSES Enhanced Accident Response System MCXS Body Color Fascias w/Bright Insert
MDAS Front License Plate Bracket MJFS Sill Molding MMPS Bright Day Light Opening Moldings
MNCS Bright Door Handles MNPS Bright License Plate Brow MVBS Grand Cherokee Badge
MVCS Jeep Badge MWTS 4X4 Badge MW1S Bright Side Roof Rails
MXRS Integrated Liftgate Rear Spoiler NA1S Export Emissions NF4S 24.6 Gallon Fuel Tank
NHSS Heated Steering Wheel QW7S Bright White Clear Coat RCAS 19 SPKRS High Perf Audio
RHCS Body Color Shark Fin Antenna RSQS Uconnect Voice Command w/Bluetooth RSXS Remote USB Port
RS1S Remote SD Card Slot RS4S Dual Remote USB Port - Charge Only SBAS Power Rack and Pinion Steering
SCWS Wood/Leather Wrapped Steering Wheel SERS Quadra-Lift Air Suspension SUBS Power Tilt/Telescope Steering Column
TBBS Full Size Spare Tire XABS Selec-Terrain System XACS ParkView Rear Back-up Camera
XAGS ParkSense FT/RR Park Assist System XANS Blind Spot and Cross Path Detection XA8S Non Adjustable Pedals
XBQS Steering Wheel Mounted Shift Control XGMS Tire Pressure Monitoring Display XJAS Power Locking Fuel Filler Door
XJMS Capless Fuel Filler XK9S Passive Pedestrian Protection XPFS Protective Coating and Remover
X8US Rear Fascias Parts Module X8WS Front Fascias Parts Module X8YS Headliner Parts Module
X8ZS Seat Parts Module X81S Instrument Panel Parts Module X82S Door Parts Module
X83S Front End Parts Module X84S Front Suspension Parts Module X85S Rear Suspension Parts Module
X88S Tire Wheel Parts Module X89S Front Suspension Damper Parts Module X91S Rear Suspension Damper Parts Module
YABS Build To Export Mkt. Specifications Z6KS GVW Rating - 6500# 1AHS EMEA Region ROW
106S Zone 06-Export 5I4S Four Wheel Drive (4WD)/(4X4) 5I8S Left Hand Drive (LHD)
5KSS Price Class T 5LBS 2014 Vehicle Specifications 5YCS WK/6042 Vehicle Family
594S Vehicle Order Tracking
Optional Equipment
Code Description Code Description Code Description
*HL Leather Trimmed Bucket Seats -X9 Black ABBA European Equipment Group
ADGP Advanced Technology Group AHCP Trailer Tow Prep Group AWBP Quadra-Drive II ® 4WD System
AWT Performance Handling Group BAJP 220 Amp Alternator BCFP 800 Amp Maintenance Free Battery
BGGP Advanced Brake Assist BR1P Anti-Lock 4-Wheel Disc Brakes CJ2P Supp. Side Curtain Frt/Rr Air Bags
CUKP Removable Ash Tray CX8P CORA Tire Press Monitoring Sensor C1CP #3 Seat Foam Cushion
DBAC All Automatic Transmissions DFD 8-Spd Auto 8HP70 Trans (Buy) DR1P 230MM Rear Axle
DSFP Elec LTD Slip Differential Rr Axle EXF 3.0L V6 Turbo Diesel Engine GEG Deep Tint Sunscreen Glass
GNZP Auto Dim Exterior Driver Mirror JHSP Headlamp Washer JJAP Cigar Lighter
JKJP Automatic Headlamp Leveling System JLNP GPS Navigation JLPP GPS Antenna Input
LEBP Ext. Mirrors w/Supplemental Signals LECP Exterior Mirrors Courtesy Lamps LEMP Exterior Mirrors w/Memory
LEPP Body Color Exterior Mirrors LERP Power Folding Mirrors LEUP Auto Dim Exterior Passenger Mirror
LSRP Forward Collision Warning Plus MF1P Body Color Grille w/Chrome Inserts MZRP 3.0L Diesel Badge
MZ4P Overland Summit Badge NBCP Euro Stage 5 Emissions w/EOBD 5 NELP Dual Bright Exhaust Tips
NHAP Engine Oil Cooler NHJP Exterior Mirrors w/Heating Element NHRP Passive Speed Limiting Device
NH1P Enhanced Adaptive Cruise Control NMCP Heavy Duty Engine Cooling PW7 Bright White Clear Coat
RDHP 825 Watt Amplifier RDKP Phase Diversity Antenna RDZP Steering Wheel Mounted Audio Ctrls
RFLP 8.4 Touch Screen Display RG4 Uconnect 8.4N MW/LW/DAB/BT/NAV RH1 Single Disc Remote CD Player
RSGP Digital Multimedia Broadcast RS9P Digital Audio Broadcasting R04P All VP4 Radios
SDEP Sport Suspension TX9P 265/50R20 BSW 3 Season Perf Tires TZCP Continental Brand Tires
WLBP Steel Spare Wheel WLZC All Aluminum Wheels WSCP 20X8.0 Aluminum Polished Wheels
XBNP Tip Start XDAP Leather Wrapped I/P Center Armrest XD4P Diesel Particulate Filter (DPF)
XEVP Tow Eye Brackets XL3P Russian (Cyrillic) Language XRBP Integrated Voice Command w/Bluetooth
XTDP Silver Anodized Interior Accents XXEP Electro-Hydraulic Power Steering YHTA 3.2 Additional Gallons of Diesel
ZKAP Spring - Left Front ZKRP Spring - Left Rear ZYAP Spring - Right Front
ZYRP Spring - Right Rear 0GBA FAM: WK TRACKING: 30221J13 MY:2014 0GEA FAM: WK TRACKING: 30228J18 MY:2014
0GJA FAM: WK TRACKING: 30306J20 MY:2014 0G4A FAM: WK TRACKING: 30528J30 MY:2014 2TRA Customer Preferred Package 2TR
22R Customer Preferred Package 22R 3D2A Intl. Price Protection B 3HGA Coso Wt. D.M.
3HMA Coso Spbr Not Required 3HQA Market Homologation 3HWA Export Ocean Freight
3HZA Export Insurance 4ALA 1NTL 37 DAY SCHEDULE 4HC Special Scheduling Condition III
4XTA Delete Domestic Warranty Manual 4YBA Export Option Requirements 6CTP Certificate of Conformance
6EMP European E Mark Label 6MPP Manufacturer Body Plate 8B6A Estonia Country Code
8EAP FIAT EMEA Distribution Tracking 882P Central/Eastern Europe Region Group 895A EMEA Region (Europe)
30
Автомобиль: 2014 Grand Cherokee Summit
3.0 CRD. Ниссан Кашкай 2014 года.
up6 ! Большое Спасибо! :respect:
19
Автомобиль: WH
Ребят, а пробейте Винку, очень надо :)
1J4FX58S1RC237045
VIN: 1J4FX58S1RC237045
1: Built By Chrysler Corporation
J: Jeep
4: Multipurpose Passenger Vehicle
F: 4001 - 5000# (1815 - 2267 KG) GVWR - HYD BR.
X: Grand Cherokee 4x2 (Left Hand Drive)
5: Grand Cherokee Laredo
8: Sport Utility (4 door)
S: 4.0L I-6 Gasoline (MPI) -Unleaded- (ERH)
1: Check Digit
R: 1994
C: Jefferson North Assy. (Detroit Mi.)
Body Model Code: ZJTL74
Engine: ERH 4.0L I6 Power Tech Engine
Transmission: DGK 4-Spd. Automatic 42RE Transmission
Vehicle Build Date: Saturday, January 22, 1994
*TL: Lux Leather Trimmed Bucket Seats
-FF: Dark/Medium Driftwood
166: Zone 66-Orlando
1AA: U.S. Dealer Retail
26E: Customer Preferred Package 26E
2TE: Customer Preferred Package 2TE
3VR: Customer Preferred Discount
610: Florida State Code
910: Florida State Code
ADB: Protection Group
ADC: Convenience Group
AFF: Luxury Group
AHC: Trailer Tow Group
APA: Monotone Paint
ARN: Laredo Decor Group
AWH: Power Equipment Group
BAR: 90 Amp Alternator
BCE: 600 Amp Maintenance Free Battery
BGK: 4-Wheel Anti-Lock Brakes
CAC: Low Back Bucket Seats
CFN: Rear 60/40 Folding Seat
CGT: Driver Air Bag Only
CKD: Floor Carpet
CKN: Cargo Compartment Carpet
CKR: Cargo Net
CKT: Cargo Tie Down Loops
CKV: MOPAR Third Row Cargo Bins w/Table
CLE: Front & Rear Floor Mats
CSA: Spare Tire Cover
CSC: Cargo Compartment Cover
CSR: Passenger Assist Handles
CUF: Full Length Floor Console
CUN: Overhead Console
DGB: All 4-Speed Automatic Transmissions
DGK: 4-Spd. Automatic 42RE Transmission
DHA: Lock-Up Torque Converter
DME: 3.73 Rear Axle Ratio
DRM: Dana 35C/194MM Rear Axle
ERH: 4.0L I6 Power Tech Engine
GBB: Tinted Windshield Glass
GCB: Front Door Tinted Glass
GED: Tinted Rr Drs/Qtr/Liftgate Glass
GFA: Rear Window Defroster
GNC: Sun Visors w/Illum Vanity Mirrors
GNK: Rear View Auto Dim Mirror
GRK: Left Power Mirror
GSK: Right Power Mirror
GTK: Power Mirrors
GVB: All Vehicles W/Power Mirrors
GXM: Remote Keyless Entry
HAA: Air Conditioning
HGA: Hood Insulation
HGD: Deluxe Insulation Group
JAY: Instrument Cluster w/Tach
JCD: 100 MPH Primary Speedometer
JHA: Var Intermittent Windshield Wipers
JHB: Rear Window Wiper/Washer
JJA: Cigar Lighter
JJB: Dual Note Electric Horns
JKA: Locking Glove Box
JKD: Remote Fuel Door Release
JPA: Power Windows
JPB: Power Locks
JPT: Power Front Driver/Passenger Seats
K4A: STRIPE/BADGE/MOLDING/COLOR
K5A: STRIPE/BADGE/MOLDING/COLOR
KGE: DK QUARTZ MET C/C - DIM. GRAPHIC -
KTB: BRIDGEWATER BLUE P/C - BADGE - CHRY
LAG: Warning Chime
LAZ: Vehicle Information Center
LBB: Courtesy Lamps
LBC: Glove Box Lamp
LBD: Ash Tray Lamp
LDA: Underhood Lamp
LDB: Cargo Compartment Lamp
LET: Traveler/Mini Trip Computer
LMG: Automatic Headlamps
LPS: CHMSL Lamp
MDA: Front License Plate Bracket
MFZ: Bright Grille
MHA: Black Windshield Moldings
MWG: Roof Rack
NAA: Federal Emissions
NF5: Fuel Tank - 23 Gallon
NHM: Speed Control
NMC: Heavy Duty Engine Cooling
PW7: Bright White Clear Coat
QW7: Bright White Clear Coat
RAA: All Radio Equipped Vehicles
RAS: AM/FM Cassette Radio
RCD: 4 Speakers
SBA: Power Rack and Pinion Steering
SCG: Leather Wrapped Steering Wheel
SDA: Normal Duty Suspension
SUA: Tilt Steering Column
TBG: Compact Spare Tire
TBL: Inside Mounted Spare Tire
TRT: P225/75R15 OWL All Season Tires
TZA: Goodyear Brand Tires
WJ6: 15X7.0 Sport Aluminum Wheels
WLZ: All Aluminum Wheels
YAA: Build To U.S. Mkt. Specifications
YGG: 9 Additional Gallons of Gas
Z1A: GVW/Payload Rating
ZFL: Spring - Left Front
ZJS: Spring - Left Rear
ZTK: Spring - Right Front
ZWS: RIGHT REAR SPRING
А расшифруйте 1J8H3E8M38Y134392 , пожалуйста.
VIN: 1J8H3E8M38Y134392
1: Manufactured by DaimlerChrysler Corporation
J: Jeep
8: Multipurpose Passenger Vehicle With Side Air Bags
H: 6001-7000# (2722-3175 KG) GVWR & Hyd Brakes
3: Commander (LHD)(4x4)
E: 5 Speed Automatic
8: Sport Utility 4 Door
M: 3.0L V6 CYL Turbo Diesel EXL
3: Check Digit
8: 2008
Y: Chrysler Steyr Assembly
Body Model Code: XHJP74
Engine: EXL 3.0L V6 Turbo Diesel Engine
Transmission: DGU 5-Spd Auto W5J400 Transmission
Vehicle Build Date: Thursday, August 21, 2008
*SL: Leather Trimmed Bucket Seats
-J1: Dk Khaki/Lt Graystone
106: Zone 06-Export
1AU: Export Homologated
27G: Customer Preferred Package 27G
2TG: Customer Preferred Package 2TG
3D2: Intl. Price Protection B
3HG: Coso Wt. & D.M.
3HQ: Market Homologation
3HW: Export Ocean Freight
3HZ: Export Insurance
4AL: 1NTL 37 DAY SCHEDULE
4HC: Special Scheduling Condition III
4XT: Delete Domestic Warranty Manual
4YB: Export Option Requirements
594: Vehicle Order Tracking
5I4: Four Wheel Drive (4WD)/(4X4)
5I8: Left Hand Drive (LHD)
5IE: XH-Vehicle Family
5RE: Add Light Group
5ZC: Price Class P
6CU: Non Certificate of Conformance Veh
6EM: Label - European E Mark
6MP: Plate - Manufacturer
882: Central/Eastern Europe Region Group
895: European Region
8FE: Russia Country Code
ABB: European Equipment Group
ADL: Skid Plate Group
APA: Monotone Paint
AWB: Quadra-Drive 4WD System
AWL: Off Road Group
AWS: Smoker's Group
BAD: 180 Amp Alternator
BCF: 800 Amp Maintenance Free Battery
BGE: Brake Assist
BNB: Electronic Stability Program
BNG: Hill Start Assist
BNH: Hill Descent Control
BNR: Four Wheel Traction Control
BRY: Anti-Lock 4-Wheel Disc Brakes
CBF: Premium Door Trim Panel
CDU: Manual Driver & Pass Lumbar Adjust
CDZ: Premium Two-Tone Seat Accents
CF1: 2nd Row 40/20/40 Fold & Tumble Seat
CF4: Child Seat Upper Tether Anchorages
CFP: 3rd Row Seat
CG1: Next Gen Multistage Front Air Bags**
CG6: Center Rear 3-Point Seat Belt
CGS: Supplemental Side Air Bags
CGU: Child Seat Anchor System-LATCH Ready
CHB: Cloth Covered Headliner
CJ5: Supp. Side Curtain All Rows Air Bags
CKD: Floor Carpet
CLH: Cargo Trim Panel w/Storage Net
CST: Exterior Assist Handle
CSV: Interior Assist Handles
CXE: Elec. Steering Column Shaft Lock
DGU: 5-Spd Auto W5J400 Transmission
DHX: Quadra-Trac II Full-Time,Active 4WD
DJA: 200MM Front Axle
DMD: 3.55 Axle Ratio
DRS: 213MM Rear Axle
DSF: Elec LTD Slip Differential Rr Axle
DSG: Elec LTD Slip Differential Frt Axle
EXL: 3.0L V6 Turbo Diesel Engine
GEP: Flipper Liftgate Glass
GU5: Power Folding Multi-Function Mirrors
GXX: Sentry Key Theft Deterrent System
HAF: Air Cond ATC w/Dual Zone Control
HBB: Rear Air Conditioning w/Heater
HGB: Dash Liner Insulation
HGF: Floor Tunnel Insulation
JAP: Instrument Panel
JDH: 230 KPH Primary Speedometer
JHC: Rain Sensitive Windshield Wipers
JJM: Auxiliary 12-Volt Rear Power Outlet
JKL: Headlamp Leveling System
JKP: 12V Auxiliary Power Outlet
JKY: Power Accessory Delay
JP3: Pwr Front Windows, 1-Touch,Up & Down
JPB: Power Locks
JPK: Pwr 8-Way Drvr Mem 4-Way Pass Seats
JPM: Heated Front Seats
K5Z: STRIPE/BADGE/MOLDING/COLOR
K6X: Spripe/Molding/Badge
LAC: Illuminated Entry
LAG: Warning Chime
LBB: Courtesy Lamps
LBC: Glove Box Lamp
LCE: Rear Courtesy/Reading Lamps
LEM: Exterior Mirrors w/Memory
LEW: Radio/Driver Seat/Mirrors Memory
LMJ: Halogen ECE Headlamps
LNJ: Fog Lamps
LPE: Cargo Lamp
LPG: Rear Fog Lamps
LPS: CHMSL Lamp
LSD: Deluxe Security Alarm
LSE: Enhanced Accident Response System
MCY: Body Color Fascias w/Bright Insert
MFZ: Bright Grille
MJB: Chrome Bodyside Molding
MMG: Belt Moldings
MNK: Body Color Door Handles
MNP: Bright License Plate Brow
MVA: Limited Badge
MVC: Jeep Badge
MW1: Bright Side Roof Rails
MZR: Common Rail Diesel Badge
NA1: Export Emissions
NB3: Euro Stage III Emission Vehicle
NFB: 22 Gallon Fuel Tank
NHF: Power Steering Cooler
NHJ: Exterior Mirrors w/Heating Element
NHM: Speed Control
NMH: Hydraulic Engine Cooling
NZH: High Output Engine Controller
PXR: Brilliant Black Crystal Pearl Coat
QXR: Brilliant Black Crystal Pearl Coat
RCG: 6 Speakers
RDL: Integrated in Rear Window Antenna
RDZ: Steering Wheel Mounted Audio Ctrls
REZ: MW/FM/DVD/HDD/MP3/Rr Camera Radio
SCV: Leather Wrapped Steering Wheel
SUD: Tilt/Telescope Steering Column
TBB: Full Size Spare Tire
TVX: 245/65R17 BSW All Season Tires
WF1: 17" Steel Spare Wheel
WF6: 17" Aluminum Wheels
XAG: ParkSense FT/RR Park Assist System
XAM: Power Adjustable Pedals w/Memory
XBN: Tip Start
XEE: Fuel Tank Skid Plate Shield
XEF: Transfer Case Skid Plate Shield
XEU: Front Suspension Skid Plate
XEV: Tow Eye Brackets
XGM: Tire Pressure Monitoring Display
XJH: Locking Fuel Filler Cap
XL3: Russian Language
YAB: Build To Export Mkt. Specifications
YHT: 3.2 Additional Gallons of Diesel
Z6E: GVW Rating - 5700
ZBV: Spring - Left Rear
ZDJ: Spring - Left Front
ZPU: Spring - Right Rear
ZSG: Spring - Right Front
Подыскиваю машину в Европе.
Очень прошу пробить VIN 1J8H3E8M89Y502275(в первую очередь точная дата выпуска и комплектация)
Заранее спасибо.
VIN: 1J8H3E8M89Y502275
1: Manufactured by Chrysler LLC.
J: Jeep
8: Check Digit
9: 2009
Body Model Code: XHJS74
Vehicle Build Date: Monday, September 15, 2008
*RL: Leather Trimmed Bucket Seats
-D1: Dk Slate Gray/Lt Graystone
106: Zone 06-Export
27K: Customer Preferred Package 27K
2TK: Customer Preferred Package 2TK
45B: Chyrsler Old NSC Stock Tracking
4DW: Chyrsler Old NSC Stock Warranty
5RH: Toluca 2-DR Launch
5ZD: Price Class S
6CT: Certificate of Conformance
878: Western Europe Region Group
8EW: Norway Country Code
APA: Monotone Paint
AWS: Smoker's Group
AYC: Executive Group
BGE: Brake Assist
BNT: Trailer Sway Damping
CFP: 3rd Row Seat
CKD: Floor Carpet
CKR: Cargo Net
CLX: Luxury Front & Rear Floor Mats
CS5: Platinum Exterior Assist Handles
CTK: Leather Wrapped Door Panels
GEG: Deep Tint Sunscreen Glass
GN5: RR View Auto Dim Mirror w/Microphone
GWF: Power Sunroof w/CommandView
JHS: Headlamp Washer
JKJ: Automatic Headlamp Leveling System
JPB: Power Locks
JPZ: Heated Second Row Seats
JRC: Power Liftgate
K6J: No Description Available
LAG: Warning Chime
LBB: Courtesy Lamps
LBC: Glove Box Lamp
LEP: Body Color Exterior Mirrors
LMP: High Intensity Discharge Headlamps
LNJ: Fog Lamps
LPE: Cargo Lamp
LPG: Rear Fog Lamps
LPS: CHMSL Lamp
LSB: Security Alarm
MC3: Platinum Fascias
MFH: Platinum Grille
MMG: Belt Moldings
MNF: Platinum Side Roof Rails
MNH: Satin Door Handles
MNT: Platinum License Plate Brow
MTG: Platinum Bodyside Molding
MVC: Jeep Badge
MWF: Adjustable Roof Rail Crossbars
MZM: Overland Badge
NB4: Euro Stage IV Emission Vehicle
NHM: Speed Control
PGJ: Jeep Green Met. Clear Coat
QGJ: Jeep Green Met. Clear Coat
RC6: 6 Boston Acoustics Speakers
REW: MW/FM CD MP3 Nav Radio (Euro)
RSQ: UConnect Hands-Free Communication
SCW: Wood/Leather Wrapped Steering Wheel
TBW: Full Size Matching Whl Spare Tire
TUU: 245/60R18 BSW AS Perf Tires
WPB: 18X8.0 Aluminum Wheels
XAC: ParkView Rear Back-up Camera
XBN: Tip Start
XD4: Diesel Particulate Filter (DPF)
XDA: Leather Wrapped Interior Items
XER: Towing Ball Hitch For Trailer
XEY: Trailer Tow Wiring Harness
XLF: Danish Language
XSC: Bright Interior Accents
ZBW: Spring - Left Rear
ZDH: Spring - Left Front
ZPV: Spring - Right Rear
38
Автомобиль: Соммander 3.0 crd
Commander 3.0 CRD
ps-store Большое Спасибо!!!!
178
Автомобиль: WJ 4
7 99г
был WH 3
0 2006 limited
был WG 2.7 2002 limited
Пробейте плиз 1j8g2e8a24y141557
19
Автомобиль: WH
VIN: 1J8G2E8A24Y141557
J: Jeep
8: Multipurpose Pass Vehicle With Side Air Bags "CGS"
G: 5001-6000#(2268-2721 kg) GVWR & Hyd. Brake
2: Jeep Grand Cherokee (European)
E:
8: Quad Cab (Full Rear Doors)/Sport Utility 4 Dr.
A: 2.7L I4 CYL 20V Turbo Diesel Direct Injection(ENF)
2: Check Digit
4: 2004
Body Model Code: WGJS74
Engine: ENF Engine - 2.7L 5Cyl 20V T/Diesel DI
Transmission: DGE Transmission - All 5-Speed Automatic
Vehicle Build Date: Friday, January 16, 2004
*UL: Seats - Prem Leather Low-Back Bucket
-DB: Dk/Lt Slate Grey
0BG: Cn 50530-Lo2 Mga 0Bg (Out End
0BK: Pcn 66110-702 A Mga 0Bk
0BN: FAM: TJ TRACK PLAN: BUX-56B MODEL YR:
106: Zone 06-Export
4AL: 1Ntl 37 Day Schedule
5IA: Overseas Families
5IH: WG-Vehicle Family
8CJ: Germany Country Code
A79: 2.7LTD Eng(ENF)/5Spd A/T W5A580(DGJ)
ABE: Export Equipment Group
AFF: Luxury Group
APA: Monotone Paint
AWS: Smoker's Group
BAZ: Alternator - 136 Amp
BCV: Battery - 700 Amp Maintenance Free
BRY: Brakes - Anti-Lock 4-Wheel Disc
CAC: Seats - Low Back Bucket
CBW: Door Trim Panel - Highland Vinyl
CFN: Seat - Rear 60/40 Folding
CG1: Air Bags-Front,Next Gen,Multistage**
CGS: Air Bags - Side, Supplemental
CJ2: Air Bag-Side Window Curtain,Frt & Rr
CKD: Carpet - Floor
CKN: Carpet - Cargo Compartment
CKR: Cargo Net
CLE: Floor Mats - Front & Rear
CLG: Cargo Storage - Covered
CLP: Scuff Pads - Door Sill
CSC: Cover - Cargo Compartment
CSR: Assist Handles - Passenger
CUD: Console - Mini Overhead
CUF: Console - Full Length Floor
CV4: Ash Tray
DGE: Transmission - All 5-Speed Automatic
DGJ: Transmission-5-Spd. Automatic,W5A580
DHA: Torque Converter - Lock-Up
DHQ: Quadra-Trac II-On Demand 4WD System
DJJ: Axle - Front, Dana 30/186MM
DMD: Axle Ratio - 3.55
DRK: Axle - Rear, Dana 44/226MM
DSB: Axle - Vari-Lok Progressive,Front
DSC: Axle - Vari-Lok Progressive, Rear
ENF: Engine - 2.7L 5Cyl 20V T/Diesel DI
GBB: Windshield Glass - Tinted
GCB: Glass - Front Door Tinted
GEG: Glass - Deep Tint Sunscreen
GEP: Glass - Flipper Liftgate
GFA: Defroster - Rear Window
GNC: Sun Visors - Illum Vanity Mirrors
GNK: Mirror - Rear View, Auto Dim
GTG: Mirrors - Power Fold-Away
GWA: Sunroof - Power
GXM: Keyless Entry - Remote
HGA: Insulation - Hood
HGD: Insulation Group - Deluxe
JA6: Instr Cluster - Electroluminescent
JDH: Speedometer - 230 KPH Primary
JHB: Wiper/Washer - Rear Window
JHC: Windshield Wipers - Rain Sensitive
JJA: Lighter - Cigar
JJB: Horns - Electric, Dual Note
JJJ: Power Outlet - Auxiliary 12V
JKA: Glove Box - Locking
JKP: Power Outlet - Auxiliary 12V
JPB: Locks - Power
JPD: Windows - Power, Driver One-Touch
JTF: Seats - Power, 10-Way Heated, Memory
K4B: STRIPE/BADGE/MOLDING/COLOR
K9K: No Description Available
LAG: Warning Chime
LBB: Lamps - Courtesy
LBC: Lamp - Glove Box
LCB: Lamps - Door Courtesy
LCE: Lamps - Rear Courtesy/Reading
LDB: Lamp - Cargo Compartment
LEW: Memory - Radio/Driver Seat/Mirrors
LMJ: Headlamps - Halogen ECE
LNJ: Fog Lamps
LPS: Lamp - Center Hi-Mount Stop
LSA: Security Alarm
LSC: Security Alarm - Premium
MDA: Bracket - Front License Plate
MFQ: Grille - Chrome/Body Color w/Accent
MHA: Windshield Moldings - Black
MVB: Badge - Grand Cherokee, Bright
MVC: Badge - Jeep, Bright
MWG: Roof Rack
MZB: Badge - Quadra Drive
MZM: Badge - Overland
MZR: Badge - Common Rail Diesel, Bright
NA1: Emissions - Export
NFP: Fuel Tank - 20.5 Gallon
NHF: Cooler - Power Steering
NHM: Speed Control
NMH: Engine Cooling - Hydraulic
PB7: Patriot Blue Pearl Coat
QB7: Patriot Blue Pearl Coat
RB3: Radio - AM/FM CD, GPS Navigation
RCE: Speaker System - Infinity
RDL: Antenna - Integrated in Rear Window
RDP: CD Changer - 10-Disc, Remote
RDZ: Audio Ctrls-Steering Wheel Mounted
SBA: Steering - Power Rack and Pinion
SCW: Steering Wheel-Wood/Leather Wrapped
SDJ: Suspension - Firm
SUA: Steering Column - Tilt
TBL: Spare Tire - Inside Mount
TBW: Spare Tire- Full Size, Matching Whl
TSU: Tires - 235/65HR17 BSW Performance
WGG: Wheels -17 X 7.5 Aluminum,5 Spoke
WLZ: Wheels - All Aluminum
XEE: Skid Plate Shield - Fuel Tank
XEF: Skid Plate Shield - Transfer Case
XEU: Skid Plate - Front Suspension
XJH: Fuel Filler Cap - Locking
XLT: Language - German
Z6F: GVW Rating - 5525
ZLG: Spring - Left Front
ZLX: Spring - Left Rear
ZZG: Spring - Right Front
ZZX: Spring - Right Rear
178
Автомобиль: WJ 4
7 99г
был WH 3
0 2006 limited
@ps-store, спасибо. Даже посмотреть не успел. В пятницу появилась объява, договорился в субботу в обед подъехать, а машинку с утра уже забрали. :mad:
Пробейте плиз следующий вариант. 1j8g2e8a24y140635
Хозяин говорит что в мажоре покупал, может что интересное всплывет.
19
Автомобиль: WH
VIN: 1J8G2E8A24Y140635
J: Jeep
E:
2: Check Digit
4: 2004
Body Model Code: WGJP74
Vehicle Build Date: Thursday, February 12, 2004
*SL: Seats - Leather Low-Back Bucket
-DV: Dark Slate Gray
106: Zone 06-Export
4HA: Special Scheduling Condition I
AFF: Luxury Group
APA: Monotone Paint
AWS: Smoker's Group
CKD: Carpet - Floor
CV4: Ash Tray
GED: Glass - Tinted Rr Drs/Qtr/Liftgate
JHA: Windshield Wipers - Var Intermittent
JPB: Locks - Power
K4C: STRIPE/BADGE/MOLDING/COLOR
K5S: STRIPE/BADGE/MOLDING/COLOR
LAG: Warning Chime
LNJ: Fog Lamps
LSA: Security Alarm
MFW: Grille - Bright/Body Color
MVA: Badge - Limited, Bright
MWG: Roof Rack
NHM: Speed Control
PS2: Bright Silver Metallic Clear Coat
QS2: Bright Silver Metallic Clear Coat
RAD: Radio - AM/FM Cass/CD w/Changer Ctrl
SCL: Steering Wheel - Leather Wrapped
WGF: Wheels- 17 X 7.5 Alum,Sparkle,Accent
XL3: Language - Russian
ZZW: Spring - Right Rear
Year/Model: 2004 JEEP GND CHEROKEE PREM 4X4 SPORT UTIL
Last Odometer: 127 736 kilometers on 22 Март 2008 г.
Body Style: WGJP74
Engine: ENF-2.7L I5 20V T/Diesel DI Engine
Transmission: DGJ-5-Speed Auto W5A580 Transmission Odometer Type: kilometers
Color 1: PS2-Bright Silver Metallic Clear Coat
Color 2: QS2-Bright Silver Metallic Clear Coat
Build Date: 12 Февраль 2004 г. - собран
продан в Мэйджор Авто
первый владелец по имени Игорь
есть реколл на подогревы сидений
ABES Export Equipment Group ADBS Protection Group AFFS Luxury Group
APAS Monotone Paint AWSS Smoker's Group BAZS 136 Amp Alternator
BRYS Anti-Lock 4-Wheel Disc Brakes CACS Low Back Bucket Seats CBWS Highline Door Trim Panel
CFNS Rear 60/40 Folding Seat CGSS Supplemental Side Air Bags CG1S Next Gen Multistage Front Air Bags**
CKDS Floor Carpet CKNS Cargo Compartment Carpet CKTS Cargo Tie Down Loops
CLGS Covered Cargo Storage CLPS Driver Foot Rest CSRS Passenger Assist Handles
CUDS Mini Overhead Console CUFS Full Length Floor Console DGES All 5-Speed Automatic Transmissions
DHAS Lock-Up Torque Converter DJJS Dana 30/186MM Front Axle DRKS Dana 44/226MM Rear Axle
GBBS Tinted Windshield Glass GCBS Front Door Tinted Glass GEDS Tinted Rr Drs/Qtr/Liftgate Glass
GEPS Flipper Liftgate Glass GFAS Rear Window Defroster GNCS Sun Visors w/Illum Vanity Mirrors
GNKS Rear View Auto Dim Mirror GTGS Power Fold-Away Mirrors GXMS Remote Keyless Entry
HAFS Air Cond ATC w/Dual Zone Control HGAS Hood Insulation HGDS Deluxe Insulation Group
JAYS Instrument Cluster w/Tach JA6S Electroluminescent Instr Cluster JDHS 230 KPH Primary Speedometer
JHAS Var Intermittent Windshield Wipers JHBS Rear Window Wiper/Washer JJBS Dual Note Electric Horns
JKAS Glove Box JKPS 12V Auxiliary Power Outlet JKYS Power Accessory Delay
JPBS Power Locks JPDS Power Windows, Driver One-Touch K4CS BRT. SILVER MET. C/C - Cladding -
K5SS DEEP GRAY - Cladding LACS Illuminated Entry LAGS Warning Chime
LBBS Courtesy Lamps LBCS Glove Box Lamp LCBS Door Courtesy Lamps
LCES Rear Courtesy/Reading Lamps LDBS Cargo Compartment Lamp LEWS Radio/Driver Seat/Mirrors Memory
LMJS Halogen ECE Headlamps LNJS Fog Lamps LPSS CHMSL Lamp
LSAS Security Alarm MFWS Bright/Body Color Grille MHAS Black Windshield Moldings
MVAS Limited Badge MVBS Grand Cherokee Badge MVCS Jeep Badge
MWGS Roof Rack NA1S Export Emissions NFPS 20.5 Gallon Fuel Tank
NHMS Speed Control QS2S Bright Silver Metallic Clear Coat RCES Infinity Speakers
RDLS Integrated Window Antenna SBAS Power Steering SCLS Leather Wrapped Steering Wheel
SUAS Tilt Steering Column TBLS Inside Mounted Spare Tire TBWS Full Size Spare Tire w/Matching Whl
TSUS 235/65HR17 BSW Performance Tires WGFS 17X7.5 Alum,Sparkle,Accent Wheels XJHS Locking Fuel Filler Cap
YABS Build To Export Mkt. Specifications 1AUS Export Homologated 106S Zone 06-Export
5IAS Price Class E 5IHS WG-Vehicle Family 5I4S Four Wheel Drive (4WD)/(4X4)
5I8S Left Hand Drive (LHD) 594S Vehicle Order Tracking
Optional Equipment
*SL Leather Trimmed Bucket Seats -DV Dark Slate Gray ABBA European Equipment Group
ADL Skid Plate Group AWB Quadra-Drive II ® 4WD System A79P 2.7LTD Eng(ENF)/5Spd A/T W5A580(DGJ)
BCVP 700 Amp Maintenance Free Battery CJ2P Supp. Side Curtain Frt/Rr Air Bags CLEP Front Rear Floor Mats
CSCP Cargo Compartment Cover CV4P Front Ash Tray DGJ 5-Speed Auto W5A580 Transmission
DHQP Quadra-Trac II-On Demand 4WD System DMDP 3.55 Rear Axle Ratio DSBP Vari-Lok Progressive Front Axle
DSCP Vari-Lok Progressive Rear Axle ENF 2.7L I5 20V T/Diesel DI Engine GXXP Sentry Key Theft Deterrent System
JJAP Cigar Lighter JJJP 12V Auxiliary Power Outlet JKLP Headlamp Leveling System
JTF Power 10-Way Heated Memory Seats LAZP Vehicle Information Center LETP Traveler/Mini Trip Computer
MDAP Front License Plate Bracket MZBP Quadra Drive Badge MZRP Common Rail Diesel Badge
NB3P Euro Stage 3 Emission Vehicle NHFP Power Steering Cooler NMHP Hydraulic Engine Cooling
PS2 Bright Silver Metallic Clear Coat RAAC All Radio Equipped Vehicles RADA AM/FM Cass/CD Radio w/Changer Ctrl
RDZP Steering Wheel Mounted Audio Ctrls SDJP Firm Suspension TZAP Goodyear Brand Tires
WLZC All Aluminum Wheels XEEP Fuel Tank Skid Plate Shield XEFP Transfer Case Skid Plate Shield
XEUP Front Suspension Skid Plate XEVP Tow Eye Brackets XL3P Russian (Cyrillic) Language
YHTA 3.2 Additional Gallons of Diesel ZLGP Spring - Left Front ZLXP Spring - Left Rear
ZZGP Spring - Right Front ZZWP Spring - Right Rear Z6FP GVW Rating - 5525#
0BGA FAM:WG TRACKING: 30117J08AA MY:2004 0BKA FAM: WG TRACKING: 30403J20 MY:2004 2TGA Customer Preferred Package 2TG
27G Customer Preferred Package 27G 3D2A Intl. Price Protection B 3HGA Coso Wt. D.M.
3HQA Market Homologation 3HWA Export Ocean Freight 3HZA Export Insurance
4ALA 1NTL 37 DAY SCHEDULE 4HA Special Scheduling Condition I 4HC Special Scheduling Condition III
6EMP European E Mark Label 6MPP Manufacturer Body Plate 8FEA Russia Country Code
15
Автомобиль: Jeep Grand Cherokee WK 2 3.6л.
до этого Jeep Grand Cherokee WJ 4.0л. Limited
Добрый день! расшифруйте пожалуйста ВИН 1J8G2B8S44Y154558 Спасибо!!
Автомобиль: Grand Cheroke ZG 98 5.9 lim
Здравствуйте! Пробейте можалуйста ВИН если не трудно ,есть опасения что кривую приобрёл ((( 1J4GZ88Z2WC523879 :( :( :(
19
Автомобиль: WH
VIN: 1J8G2B8S44Y154558
J: Jeep
B:
S: 4.0L I6 CYL Gasoline (ERH)
4: Check Digit
4: 2004
Engine: ERH Engine - 4.0L Power Tech I-6
Transmission: DGK Transmission - 4-Spd. Automatic,42RE
Vehicle Build Date: Tuesday, June 29, 2004
106: Zone 06-Export
26G: Customer Preferred Package 26G
A24: 4.0L Engine(ERH)/4Spd Auto Trans(DGK
AFF: Luxury Group
APA: Monotone Paint
AWS: Smoker's Group
BC6: Battery - 625 Amp Maintenance Free
CKD: Carpet - Floor
CV4: Ash Tray
DGB: Transmission - 4-Speed Automatic
DGK: Transmission - 4-Spd. Automatic,42RE
DHF: Quadra-Trac II On Demand 4WD System
DME: Axle Ratio - 3.73
ERH: Engine - 4.0L Power Tech I-6
JPB: Locks - Power
K4Z: STRIPE/BADGE/MOLDING/COLOR
LAG: Warning Chime
LNJ: Fog Lamps
LSA: Security Alarm
MWG: Roof Rack
NHM: Speed Control
PMQ: Deep Lava Red Metallic
QMQ: Deep Lava Red Metallic
SDA: Suspension - Normal Duty
YHU: 3.2 Additional Gallons Of Gas
Z6D: GVW/Payload Rating
ZKG: Spring - Left Front
ZKY: Spring - Left Rear
ZYG: Spring - Right Front
ZYY: Spring - Right Rear
15
J: Jeep
B:
4: Check Digit
4: 2004
106: Zone 06-Export
AFF: Luxury Group
APA: Monotone Paint
AWS: Smoker's Group
CKD: Carpet - Floor
CV4: Ash Tray
JPB: Locks - Power
LAG: Warning Chime
LNJ: Fog Lamps
LSA: Security Alarm
MWG: Roof Rack
NHM: Speed Control
Спасибо большое !!! :drinks:
Автомобиль: Chevrolet Tahoe/УАЗ-3151
Добрый день! Подскажите, пожалуйста, решил вступить в ряды Jeep'еров, подобрал авто, а на проверке VIN выдает, что не сходится контрольная цифра.
О чем это может говорить и где можно пробить официально VIN?
Заранее большое спасибо!
На всякий случай VIN 1J8H3E8M37Y563340
105
Автомобиль: Jeep Grand Cherokee Limited
ZJ
4.0L
NV249
1994г.
Всем привет!
А можно и мой ВИН пробить?
1J4GZ78S2RC106295
Спасибо большое! :)
Добрый день! Подскажите, пожалуйста, решил вступить в ряды Jeep'еров, подобрал авто, а на проверке VIN выдает, что не сходится контрольная цифра. О чем это может говорить и где можно пробить официально VIN?Заранее большое спасибо!На всякий случай VIN 1J8H3E8M37Y563340
Снимаю свой вопрос, человек ошибся в цифре. VIN сошелся, хотя по некоторым параметрам все равно смущает, но это уже не важно, по другим обстоятельствам уже не получается взять авто на данный момент.
964
Автомобиль: Jeep ZJ 98 г. 5
9 л.
Лада-Веста 2017 г.
Андрей, а можно ещё всё из той же темы: 1J4GZ78Y6WY105475
Year/Model: 1998 JEEP GRAND CHEROKEE SPORT UTILITY
Body Style: ZGJL74
Engine: ELF-5.2L V8 MPI Engine
Transmission: DGW-4-Spd. Automatic 4RE Transmission
Build Date: 28 Ноябрь 1997 г.
продан в Катаре (я так понял)
первый юзер MR ALI FARAJ KHALID
есть реколл на фаркоп
опции
*CL: Leather Trimmed Bucket Seats
-T6: Saddle
106: ZONE 06-EXPORT
1AY: EXPORT
28K: Customer Preferred Package 28K
3D2: INTL. PRICE PROTECTION B
3HG: COSO WT. & D.M.
3HM: COSO SPBR NOT REQUIRED
3HQ: MARKET HOMOLOGATION
3HW: EXPORT OCEAN FREIGHT
3HZ: EXPORT INSURANCE
3VQ: Customer Preferred Discount
4YB: EXPORT OPTION REQUIREMENTS
5IA: OVERSEAS FAMILIES
6ME: LABEL - MIDDLE EAST SPECIFICATIONS
897: MIDDLE EAST REGION
8FA: QATAR COUNTRY CODE 644
A31: 5.2L ENG(ELF)/4SPD A/T 44RE(DGW)
ABD: Middle East Equipment Group
ADL: SKID PLATE GROUP
AFF: LUXURY GROUP
AHC: TRAILER TOW GROUP
APA: Monotone Paint
ARP: Limited Decor Group
AWE: Up Country Suspension Group
BA6: Alternator - 150 Amp
BRG: Anti-Lock 4-Wheel-Disc Brakes
CAC: SEATS - LOW BACK BUCKET
CFN: SEAT - REAR 60/40 FOLDING
CGW: Next Generation Front Air Bags**
CKD: CARPET - FLOOR
CKR: Cargo Net
CKT: CARGO TIE DOWN LOOPS
CUD: CONSOLE - MINI OVERHEAD
CXH: TRIM PARTS FOR 5.2 ENGINE
DGW: TRANSMISSION - 4-SPD. AUTOMATIC,44RE
DHR: Single Speed On Demand Transfer Case
DJJ: Dana 30/186MM Front Axle
DRK: Dana 44/226MM Rear Axle
DSA: Anti-Spin Differential Rear Axle
EAA: All Engines
ELF: 5.2L V8 MPI Engine
GEP: GLASS - FLIPPER LIFTGATE
GU3: MIRRORS - POWER,HEATED,MEMORY,F/AWAY
GWA: Power Sunroof
HAB: Air Conditioning w/Auto Temp Control
JAY: INSTRUMENT CLUSTER W/TACH
JDH: SPEEDOMETER - 230 KPH PRIMARY
JJA: Cigar Lighter
JPA: Power Windows
JPB: Power Locks
JPM: SEATS - HEATED FRONT
K4W: STRIPE/BADGE/MOLDING/COLOR
KEY: "LIMITED" GOLD STRAIGHT SHADE - STR
KRE: DK QUARTZ MET C/C - DECAL - LOW PRO
KSE: GOLD METALLIC - DIMENSIONAL GRAPHIC
KTE: STRIPE/BADGE/MOLDING/COLOR
KUE: No Description Available
KWE: No Description Available
LAG: Warning Chime
LAZ: VEHICLE INFORMATION CENTER
LBB: Courtesy Lamps
LBC: Glove Box Lamp
LBD: Ash Tray Lamp
LCB: Door Courtesy Lamps
LCD: Map/Dome Reading Lamps
LDA: Underhood Lamp
LEW: MEMORY - RADIO/DRIVER SEAT/MIRRORS
LNJ: Fog Lamps
LPG: Rear Fog Lamps
LPS: CHMSL Lamp
MFT: Body Color Grille
MWG: Roof Rack
NAB: Leaded Fuel Emissions
NF5: FUEL TANK - 23 GALLON
NHM: Speed Control
NMX: Engine Cooling - Maximum Duty
RBA: AM/FM Cass Radio w/Changer Control
RCG: 6 Speakers
RDC: Power Antenna
SDU: Heavy Duty Suspension w/Gas Shocks
TRB: TIRES - 225/70R16 BSW HP
WDM: WHEELS - 16 X 7.0 LUX ALUM, GOLD
WKB: Matching Spare Wheel
XEU: SKID PLATE - FRONT SUSPENSION
XPB: UNDERCOATING
XPC: INTERIOR PROTECTIVE COVERS
XPF: PROTECTIVE COATING AND REMOVER
YAB: BUILD TO BUX MARKET SPECIFICATIONS
YG6: FUEL - OVERSEAS, NON-BILLABLE GAS
Z6B: GVW/Payload Rating
ZGN: Spring - Left Front
ZJV: Spring - Left Rear
ZVN: Spring - Right Front
ZXV: Spring - Right Rear
964
9 л.
Лада-Веста 2017 г.
Спасибо! Жаль арабы не вносят данные о пробеге. Да, из Катара.
Автомобиль: WK
1J8HCE8MX8Y125205
пожалуйста.
Добрый день, можно мой
1J8GR48K05C529898
Автомобиль: WK
1J8HCE8MX8Y125205
пожалуйста.
уже не актуально(
Автомобиль: Jeep WJ 4
7 Laredo 2000
1J4GW48N2YC303421 Если есть возможность то и мой пробейте.
Заранее благодарен
Автомобиль: WG Limited 4
7 `02
Здравствуйте! Помогите пожалуйста VIN 1J8GWE8N82Y128879.
Спасибо!
VIN-декодер ругается на букву "Е" в 6-й позиции. Т.е. не понятная комплектация.
Смотрю, скоро буду брать.
Изменено пользователем Егор
Автомобиль: jeep cheroke
Андрей, добрый вечер! Посмотрите Vin 1J8GLE85X3W633988
Изменено пользователем define
Автомобиль: WRANGLER 2003 RUBICON 35" и JK 5D
35".
Выручите пожалуйста: 1C4BJWC53CL188225
За ранее благодарен! :)
Изменено пользователем Игорь78
Автомобиль: ауди
а можно мой вариант пробить.... 1j4gw58n01c620612 ..... оч интересует криминал и обременения
пасибо
Изменено пользователем t34
Year/Model: 2012 JEEP WRANGLER RUBICON 4X4 SPORT UTILI
Body Style: JKJS72
Engine: ENS-2.8L I4 Turbo Diesel Engine
Transmission: DEH-6-Speed Manual NSG370 Transmission
Color 1: PX8-Black Clear Coat
Color 2: QX8-Black Clear Coat
Build Date: 12 Январь 2012 г.
продан в Нижнем Новгороде
опции
*A7: Cloth Low-Back Bucket Seats
-X9: Black
0DH: FAM: DH TRACKING: 81015T19 MY:2009
106: Zone 06-Export
21R: Customer Preferred Package 21R
2TR: Customer Preferred Package 2TR
593: Short Wheel Base (SWB)
5IH: JK/5402 Vehicle Family
5MD: 2012 Vehicle Specifications
5ZD: Price Class S
5ZS: Two Door
6EM: European E Mark Label
AAJ: Connectivity Group
APA: Monotone Paint
AWS: Smoker's Group
BAJ: 220 Amp Alternator
BCV: 700 Amp Maintenance Free Battery
BNB: Electronic Stability Control
BNM: Traction Control
BNS: Electronic Roll Mitigation
BPT: Hydraulic Assist Brake Booster
BR6: Anti-Lock 4-Wheel Disc HD Brakes
CAF: Easy Access Driver Seat
CAG: Easy Access Passenger Seat
CDB: Reclining Front Seats
CDH: Driver Height Adjuster Seat
CFM: Rear Folding Seat
CG3: Advanced Multistage Front Air Bags**
CGX: RR Head Restraints Outboard Seating
CKE: Front Seat Area Carpet
CKF: Rear Seat/Wheelhouse/Cargo Carpet
CKL: Cargo Compartment Floor Mat
CLC: Front Floor Mats
CLM: Sport Bar w/Full Padding
CS2: Freedom Panel Storage Bag
CSM: Front Seat Back Map Pockets
CUK: Removable Ash Tray
CUR: Rear Compartment Storage Tray
CUY: Storage Tray
CVC: Chrome/Leather Wrapped Shift Knob
CXH: Steering Column Locking Slip Collar
CXK: Steering Stop Spacer
DBB: All Manual Transmissions
DEH: 6-Speed Manual NSG370 Transmission
DHW: 4:1 Rock-Trac HD Part Time 4WD Sys
DJS: Next Gen. Dana 44 HD Front Axle
DRZ: Next Gen. Dana 44 HD Rear Axle
DSE: Tru-Lok Front & Rear Axles
ENS: 2.8L I4 Turbo Diesel Engine
GCF: Full Metal Doors w/Roll-up Windows
GNA: Rear View Day/Night Mirror
GNU: Sliding SunVisors w/Mirrors
GTP: Manual Mirrors, Fold-Away
JA2: Instrument Cluster w/Tach
JDC: 200 KPH Primary Speedometer
JE8: Manual Locks
JF8: Manual Windows
JFJ: Temperature & Compass Gauge
JJA: Cigar Lighter
JJJ: 12V Auxiliary Power Outlet
JMA: Air Filtering
LAB: Tire Pressure Monitoring Warning LP
LCL: Front Dome w/On/Off Switch Lamp
LMU: Ft Side Marker/Side Repeater Lamp
LNJ: Fog Lamps
LPG: Rear Fog Lamps
LPS: CHMSL Lamp
MB5: Black Rear Bumper
MBA: Painted Front Bumper
MEF: Rock Protection Sill Rails
MFR: Black Front Frame Overlay
MG1: Wrangler Badge
MGQ: Rubicon Badge
MUG: Accent Color Fender Flares
MVC: Jeep Badge
MWW: Common Rail Diesel Badge
MX3: Black 3-Piece Hard Top
MX9: Delete Black Easy Folding Soft Top
NB4: Euro Stage 4 Emission Vehicle
NF3: 17 Gallon Fuel Tank
NHM: Speed Control
PX8: Black Clear Coat
QX8: Black Clear Coat
RC9: 6 Premium Speakers w/Subwoofer
RDD: Fixed Long Mast Antenna
REL: Media Center 135 CD/MP3
RSQ: Uconnect Voice Command w/Bluetooth
RSX: Remote USB Port
SHC: Front and Rear Stabilizer Bars
SHG: Front Disconnecting Stabilizer Bar
TBR: Outside Tire Carrier
TTA: P245/75R17 OWL On/Off Road Tires
WFH: 17X7.0 Aluminum Chrome Wheels
X81: Instrument Panel Parts Module
X83: Front End Parts Module
X86: Complete Chassis Parts Module
X88: Tire & Wheel Parts Module
X8Z: Seat Parts Module
X92: Complete Body in White Parts Module
X94: Complete Painted Body Module
XBU: Stop-Start System
XCT: Coat Hooks
XJC: Locking Lug Nuts
XJF: Tethered Fuel Filler Cap
XKQ: Delete Diesel Particulate Filter
XPF: Protective Coating and Remover
YG3: 3.5 Additional Gallons of Diesel
ZDW: Spring - Left Rear
ZED: Spring - Left Front
ZSW: Spring - Right Rear
ZTD: Spring - Right Front
35".
up6, дай Бог Вам 100 лет счастливой и красивой жизни! :)
  • Кто в онлайне   7 пользователей, 0 анонимных, 234 гостей (Посмотреть всех)
    • RuminBoss
    • Синий KL
    • Yllymah
    • severOK
    • Самара 74
    • Михалыч81
    1. Илья_СХ27
    2. Графит
      • 12704
