Код к магнитоле
1111Ольга
Здравствуйте! Подскажите пожалуйста, как узнать код от магнитолы? 1C4NJDCB9CD655245
16
Автомобиль: Jeep Grand Cherokee WK2 Overland
@1111Ольга Залезть через Альфу и посмотреть.
129
@Сергей778  а куда через альфу залезть, я стесняюсь спросить? Вы с ключом не путаете случаем?
16
@URRI 39 пин код магнитолы вытягивается Альфой. Но у автора другая проблема, судя по другому посту.
129
Пункт в альфе  укажите
16
 @URRI 39
Wireless Control Module (WCM). Еще вопросы есть?
129
И вопросы конечно есть, если учесть чем этот блок управляет, но как видно не вытягиванием кода  магнитолы.
A Wireless Control Module (WCM) is an electronic device that integrates wireless communication and enables remote control of systems or devices. It can be used in various applications, including keyless entry systems, lighting control, and even in vehicles.
Key Concepts:
Wireless Communication:
WCMs use wireless signals (like radio waves) to transmit and receive data or control commands, eliminating the need for physical wires.
Remote Control:
WCMs allow users to control systems or devices from a distance using a remote control device or a smartphone application.
Applications:
Keyless Entry: WCMs can be part of keyless entry systems, enabling doors to be locked and unlocked without the need for a physical key.
Lighting Control: WCMs can be used to control lighting fixtures, allowing users to turn lights on and off or adjust brightness.
Vehicle Systems: In vehicles, WCMs can be part of tire pressure monitoring systems (TPMS) and other systems that need to communicate wirelessly.
Integration:
WCMs often integrate with other electronic systems and sensors to provide a comprehensive control solution.
How it Works:
Signal Transmission: The WCM transmits data or control signals wirelessly using radio waves.
Reception: The receiver device (e.g., a car door lock, a lighting fixture) receives the signal.
Execution: The receiver device performs the action requested by the signal (e.g., unlocks the door, turns on the light).
Examples:
Keyless Entry:
A WCM in a car can receive signals from a remote key fob and unlock the doors.
Lighting Control:
A WCM can receive signals from a smartphone app and dim or brighten a lighting fixture.
Tire Pressure Monitoring:
A WCM in a vehicle can receive tire pressure data from sensors in the wheels and display it on the dashboard.
In essence, a WCM is a versatile device that enables wireless control and communication between different systems and devices.
315
Автомобиль: Compass
в wcm - так называемый пин код
в radio - антитефт код
Абсолютно разные коды, но оба четырехзначные, отсюда и путаница
И тот и другой можно вытащить по кан шине, введя блок в "диагностический режим" только это в альфе походу не реализовано или я бы сказал преднамеренно вырезано.
Касательно магнитолы - судя по партномеру, это майгиг rb2, производство митцу, на сколько мне известно, для них нет алгоритма подбора, так что увы  не подскажу.
Но, можно отключить запрос антитефт кода.
С другой стороны не раскрыт вопрос: с какого "лешего" гу запросило код?
129
@Gosudar вот и я об этом. Здесь уже столько товарищей побывало, поголовно верящих во всемогучесть альфы, что даже уже не хочется их переубеждать и что то объяснять. Но с пенкой у рта пытающихся выдать то, что никогда не делали, но типа слышали, или увидели нечто похожее в меню альфы.
  • Кто в онлайне   2 пользователя, 0 анонимных, 125 гостей (Посмотреть всех)
    • MikeGCh
    • jeep_DV
    1. AG
    2. Jeep Wrangler 2008 года — это настоящий символ американского внедорожного духа. Особенно в комплектации с мотором 3.8 литра и четырёхступенчатой автоматической коробкой передач. Такие автомобили до сих пор пользуются уважением у ценителей надёжности и классического дизайна. Однако даже самый выносливый Wrangler не вечен, особенно если на одометре уже перевалило за 300 000 километров. Именно с таким «ветераном» недавно обратился клиент в TRS Motors. Несмотря на то, что двигатель работал безупречно — тихо, ровно, без посторонних шумов и провалов, — сам автомобиль уже начал «напоминать» о возрасте. Основная жалоба касалась коробки передач: при переключении на третью скорость возникало ощущение пробуксовки. Такой симптом — типичный признак износа фрикционов АКПП, особенно если за всё время эксплуатации трансмиссия ни разу не вскрывалась для профилактики. Именно поэтому владельцы Wrangler с пробегом выше 250 000 км должны быть особенно внимательны к поведению коробки. В нашем случае диагностика это подтвердила: третья передача действительно «проскальзывала», а компьютерная проверка выявила характерные отклонения в параметрах гидроблока и давления в магистрали. Решение было однозначным — снимать коробку и отправлять её в профессиональный ремонт с заменой изношенных компонентов.
      Что ещё требует внимания на таком пробеге?
      Когда автомобиль проходит отметку в 300 тысяч километров, особенно если речь идёт о внедорожнике, который регулярно эксплуатировался в жёстких условиях, невозможно ограничиться только одной проблемой. Во время осмотра в TRS Motors наши специалисты обратили внимание на целый ряд сопутствующих износов. Прежде всего — стартер. Он не только ни разу не обслуживался, но и покрылся зелёным налётом от коррозии и слоем грязи, что говорит о длительном игнорировании подкапотного пространства. Такой стартер может подвести в любой момент, особенно в холодное время года, поэтому его решили полностью перебрать и установить с новыми втулками и щётками. Передняя подвеска находилась в критическом состоянии: верхние рычаги, а также их сайлентблоки и «уши» на мосту и лонжеронах — всё требовало замены. Это не только вопрос комфорта, но и безопасности: изношенные рычаги могут привести к потере управляемости на скорости. Также были замечены изношенные крестовины на приводных валах — их заменили на новые с тавотницами, чтобы в будущем можно было легко обслуживать узел без полной замены. Четыре шаровые опоры также отправились под замену — их износ был неравномерным, что часто приводит к биению руля и ускоренному износу шин.
      Тормоза, рулевое и итоги комплексного подхода
      Ещё один важный аспект, который нельзя игнорировать на таком пробеге — тормозная система. В данном случае она была изношена «в круг»: как колодки, так и диски превысили допустимый предел износа. Это особенно опасно для внедорожника, который часто используется для движения по бездорожью или с прицепом. Мы заменили весь комплект на передней оси, подобрав качественные аналоги, рекомендованные именно для Jeep. Отдельного внимания заслуживает рулевой редуктор, который начал подтекать по сошке. Утечка масла из этого узла — частая проблема на старых Wrangler, и если её не устранить вовремя, можно столкнуться с заклиниванием руля или необходимостью полной замены редуктора, что обойдётся значительно дороже. В рамках текущего ремонта мы провели его ревизию и заменили сальники. Именно такой комплексный подход — от коробки до тормозов — позволяет не просто «залатать дыры», а вернуть автомобилю вторую молодость и гарантировать безопасную эксплуатацию на следующие десятки тысяч километров.
    3. Илья_СХ27
