Кнопки открывания ворот/шлагбаума
>>Lexus<<
Автомобиль: wk 5.7 2005 америкос
Господа подскажите как программируются кнопки открывания гаражных ворот?
вроде как сам нашел :to_keep_order:
добавьте в фак чтоли)
First, push and hold the first and third buttons of the Homelink system together for about 30-45 sec. The display on the dash will say "clearing channels".
Then, choosing any one of the three buttons of the system, press and hold it along with the the button of your garage door opener AT THE SAME TIME. Hold your opener up close to the Homelink buttons. The display will say something like "Channel 1 Training" or something to that effect. You will need to hold both button for about 10-20sec. until the display reads "Channel 1 Trained" (the channel number depends on what one of the three buttons of the system you are pressing)
This will conclude the programming.
Important note: If your opener is rather new, say in the last 5 years or so, you will likely have "rolling code" technology. This allows the system to send a different signal to your opener every time you press the button. This prevents theives from coming into neighborhoods and using a garage door opener they stole or found to open people garages and steal their stuff or break into their house.
If the Homelink system works one time after programming and only one time. you will have to check your garage door opener owners manual to see how to overide the rolling code technology if you want to use the car to open your door.
, получилось сделать? тогда добавим
нет еще, пока только описание нашел. вечерком проверю работоспособность)
http://www.wkjeeps.com/wk_homelink.htm
у меня вчера обучить не получилось(((
  • Кто в онлайне   12 пользователей, 0 анонимных, 246 гостей (Посмотреть всех)
    • Ascar252
    • leo1963
    • olegosha
    • СергейВикторович
    • Станислав88
    • Максим279
    • 409882
    • gesha-50
    • Slava52
    • SoloYV
    • Hamman46
      • 13011
