Установка сабвуфера в WH\WK
Автомобиль: в подписи
1: Manufactured By DaimlerChrysler Corporation
J: Jeep
8: Multipurpose Passenger Vehicle With Side Air Bags
G: 5001-6000# (2268-2721 KG) GVWR & Hyd. Brakes
R: Grand Cherokee (4x4)
4: Grand Cherokee LAREDO (US, Canada, Mexico)
8: Hatchback/Tall/Sport/Quad Cab
K: 3.7L V6 CYL Gasoline
0: Check digit
5: 2005 Model Year
C: Jefferson North Assembly
Код модели кузова: WKJH74
Двигатель: EKG 3.7L V6 Engine
Коробка передач: DGE All 5-Speed Automatic Transmissions
Модельный год: 2005
Дата производства: 12.10.2004
*A7:  Cloth Low-Back Bucket Seats
-D5:  Med Slate Gray
135S: Zone 35-Washington
1APS: U.S. Fleet Purchase
26E:  Customer Preferred Package 26E
2TEA: Customer Preferred Package 2TE
3AH:  Price Protection - Code H
3GCA: Fleet Incentive Waiver
3GDA: Delete Group Funds-Fleet
4EAA: Sold Vehicle
4FMA: Fleet Option Editor
4FT:  Fleet Sales Order
4HF:  Special Scheduling Condition VI
4KYA: Dealer Fleet
4UR:  Automotive Rentals Inc
51Q:  Fleet Matching System
57N:  Drift
594S: Vehicle Order Tracking
5I4S: Four Wheel Drive (4WD)/(4X4)
5I8S: Left Hand Drive (LHD)
5XA:  All Inclusive VIP Program
5XP:  Volume Incentive Program Tracking
5YCS: WK-Vehicle Family
5ZBS: Price Class H
606S: Colorado State Code
6USS: Label - U.S. Specifications
931S: New Jersey State Code
A88P: 3.7L Eng (EKG)/5Spd A/T W5A580 (DGJ)
APAS: Monotone Paint
AWF:  Cargo Convenience Group
BABS: 160 Amp Alternator
BCNS: 730 Amp Maintenance Free Battery
BNRS: Four Wheel Traction Control
BRYS: Anti-Lock 4-Wheel Disc Brakes
CACS: Low Back Bucket Seats
CDUS: Manual Driver & Pass Lumbar Adjust
CF4S: Child Seat Upper Tether Anchorages
CFNS: Rear 60/40 Folding Seat
CG3S: Advanced Multistage Front Air Bags**
CG6S: Center Rear 3-Point Seat Belt
CGS:  Supplemental Side Air Bags
CGUS: Child Seat Anchor System-LATCH Ready
CHBS: Cloth Covered Headliner
CJ2P: Supp. Side Curtain Frt/Rr Air Bags
CKDS: Floor Carpet
CKNS: Cargo Compartment Carpet
CKTS: Cargo Tie Down Loops
CL5S: Reversible/Waterproof Cargo Storage
CLES: Front & Rear Floor Mats
CLHS: Cargo Trim Panel w/Storage Net
CSCP: Cargo Compartment Cover
CSRS: Passenger Assist Handles
CTLS: Base Door Trim Panel
CUFS: Full Length Floor Console
CUNS: Overhead Console
DGES: All 5-Speed Automatic Transmissions
DGJ:  5-Speed Auto W5A580 Transmission
DHAS: Lock-Up Torque Converter
DHZS: Quadra-Trac I Full-Time 4WD
DJAS: 200MM Front Axle
DMMS: 3.07 Axle Ratio
DRSS: 213MM Rear Axle
DS7S: Conventional Differential Frt Axle
DS8S: Conventional Differential Rear Axle
EKG:  3.7L V6 Engine
GBBS: Tinted Windshield Glass
GCBS: Front Door Tinted Glass
GEGS: Deep Tint Sunscreen Glass
GEPS: Flipper Liftgate Glass
GFAS: Rear Window Defroster
GNAS: Rear View Day/Night Mirror
GNVS: Sun Visors w/Vanity Mirror
GTNS: Power Mirrors, Fold-Away
GXMS: Remote Keyless Entry
GXXS: Sentry Key Theft Deterrent System
HAAS: Air Conditioning
HGAS: Hood Insulation
HGDS: Deluxe Insulation Group
I24S: Route 24 - UP, Rolla, CO
JAPS: Instrument Panel
JAYS: Instrument Cluster w/Tach
JCES: 140 MPH Primary Speedometer
JHAS: Var Intermittent Windshield Wipers
JHBS: Rear Window Wiper/Washer
JJBS: Dual Note Electric Horns
JKAS: Locking Glove Box
JKPS: 12V Auxiliary Power Outlet
JKYS: Power Accessory Delay
JPBS: Power Locks
JPDS: Power Windows, Driver One-Touch
JPRS: Power 8-Way Driver Seat
K1XS: STRIPE/BADGE/MOLDING/COLOR
K5XS: STRIPE/BADGE/MOLDING/COLOR
LABS: Tire Pressure Monitoring Warning LP
LACS: Illuminated Entry
LAGS: Warning Chime
LAZP: Vehicle Information Center
LBBS: Courtesy Lamps
LBCS: Glove Box Lamp
LCES: Rear Courtesy/Reading Lamps
LDBS: Cargo Compartment Lamp
LETP: Traveler/Mini Trip Computer
LMBS: Halogen Headlamps
LPSS: CHMSL Lamp
LSES: Enhanced Accident Response System
MDAS: Front License Plate Bracket
MFNS: Body Color Grille
MHAS: Black Windshield Moldings
MLAS: Body Color Fascias
MMGS: Belt Moldings
MNSS: Accent Color License Plate Brow
MVCS: Jeep Badge
MWES: Side Roof Rails
MWFP: Adjustable Roof Rail Crossbars
MWTS: 4X4 Badge
MXRS: Rear Spoiler
MZKS: Laredo Badge
NAS:  50 State Emissions
NB5P: Federal Tier 2, Bin 5 Emissions
NBHP: High Altitude Emissions Tracking
NFPS: 20.5 Gallon Fuel Tank
NHFS: Power Steering Cooler
NHK:  Engine Block Heater
NHMS: Speed Control
NMBP: Standard Duty Engine Cooling
PXR:  Brilliant Black Crystal Pearl Coat
QXRS: Brilliant Black Crystal Pearl Coat
RCGS: 6 Speakers
RDDS: Fixed Long Mast Antenna
REFS: AM/FM Compact Disc Radio
SBAS: Power Rack and Pinion Steering
SCAS: Steering Wheel
SDAS: Normal Duty Suspension
SUAS: Tilt Steering Column
TBWS: Full Size Matching Whl Spare Tire
TCCS: P235/65R17 BSW All Season Tires
TZAP: Goodyear Brand Tires
WFJS: 17" Aluminum Wheels
WLZC: All Aluminum Wheels
XA8S: Non Adjustable Pedals
XCAS: Occupant Classification System
XPFS: Protective Coating and Remover
YAAS: Build To U S Market Specifications
YG1A: 7.5 Additional Gallons of Gas
Z6AS: GVW/Payload Rating
ZHCP: Spring - Left Front
ZHRP: Spring - Left Rear
ZWAP: Spring - Right Front
ZWYP: Spring - Right Rear
Выделено - бостона нет, значит нет и усилителя. Если очень хочется поменять совсем всё - это сделать достаточно легко, легче чем когда бостон таки есть.
Подробнее - skype pilotsamara63
  • 9 месяцев спустя...
667
Блин, я не силён в выражениях "мост" и всё такое.... Объясните на пальцах, как подключить саб или лучше может активный саб к усилку (Бостон)?
2 376
А так и подключается - активный саб к выходу усилка (обычно на левую переднюю мидбас).
667
Что это такое?  :lol2:
2 376
динамик левый передний который в двери.
667
Ааа, запитываются к усилку к выходам на левый передний динамик? Правильно?
п.4.9 Правил
667
Ребят!!! А если ставить не активный? Наш усик потянет? И какой максимум ватт можно ставить?
2 376
Неактивный не прокатит, даже не думаем.
Про подключение всё верно (только пусть в вашем авто это делает тот, кто умеет, ну пожалуйста).
667
Коль, да я сумею...., только разобраться нужно.... Питание как я понимаю нужно на аккум бросать?
Автомобиль: TLC 200 4.5 D
Хотелось бы сделать, красиво инсталлировать в крыло, ящик в багажнике не гуд.
2 376
Красиво инсталлировать - это к мастерам, что так делают.
Для питания активного саба там в коробках под капотом есть специальные методы (см. инструкцию по имплантации родного саба http://jeepdex.com/pdfs/77kick23.pdf, он как раз активный).
667
Коль на фото только образно видно, да и вообще хрен разберёшь чего...., а панели снять я и сам разберусь... Вопрос вот в чём... Можно ли от + на усилке, запитать саб?
2 376
Текст прочтите. Текст.
Ответ на вопрос - нет, сгорит.
667
Ага..., через полгодика постараюсь...., английский только подучу....  :lol2:
2 376
А что, рядом полный вакуум людской и вообще никто ни в зуб ногой?
667
Да есть парень..., только что то поймать не могу.... Мне нужно только от куда плюс взять и что там ещё нужно для этого?
п.4.9 Правил
2 376
Плюс и управляющий провод для включения уся саба.
667
Так куда кидать-то?  :lol2:
п.4.9 Правил
2 376
Боже, как тяжко по телефону чинить проводку...
667
Я чувствую, что этой секретной информации мне не добиться.....  "...Урий...!!! Где у него кнопка....!!!???"....    :lol2:  :lol2:  :lol2:
п.4.9 Правил
2 376
Это не секретная инфа, просто там показывать надо, а у меня материала мало для показа по телефону.
528
Автомобиль: 2012 WK2 SRT8
WH 4.7 2006 Limited Был
WH SRT8 2008 Был
+ на активный саб или усилитель (в случае пассивного) надо брать напрямую от аккумулятора или коробки предохранителей под капотом.
- от любого болта в багажнике, под фальшполом их полно.
управляющий провод включения брать от прикуривателя, который отключается при выключении зажигания (левый, который без заглушки). Это если стоковая магнитола, если магнитола не сток, то у нее есть свой управляющий провод, цепляться соответственно к нему.
2 376
Не от аккумулятора в джипе, от коробки предов ближней к салону. А вот откуда там конкретно - мы и ищем.
667
Ну на конец то!!! Спасибо братцы!!! Николай, а долго ещё искать будете?
А тут нет чего полезного? http://www.wkjeeps.com/wk_audio_pinouts.htm (внизу ссыль на проводку...)
528
WH SRT8 2008 Был
А от аккумулятора чем не так, в чем разница?
667
Вот и я не пойму, что за феншуй такой?
2 376
Весь учебник ТОЭ пересказать или только часть?
(ТОЭ - теоретические основы электротехники)
667
Не, весь не нужно..., а вот краткость - сестра таланта....
2 376
Катко: в машине есть "болт глобального плюса" - вот оттуда и брать питание на усь через предохранитель.
А вот где он точно геометрически расположен - это сложнее.
  • Кто в онлайне   7 пользователей, 1 анонимный, 774 гостей (Посмотреть всех)
    • Артем А
    • xaba_king
    • Lih0y
    • Watson
    • habit
    • Vladimir_
    2. Графит
      • 7
      • 990
