Продам CRH550 LOCKPICK
Продам комплект CRH550 LOCKPICK с инструкцией по установке (см. фото).
Комплект пролежал несколько лет в шкафу и ни разу не использовался.
Цена - 15 т.р.
- Activate video out with audio in all capable Apple products and display it on the front screen.
- Activate the iPod OUT function in the iPhone/iTouch/iPad devices (also 6th Gen Nano) for amazing integration.
- Search Playlists, Artists, Albums Songs, Genres, Composers one at a time or alphabetically for long lists.
- Display Album Art, time graphs and more from your favorite songs..
- Play movies from your iPod/iPhone/iTouch/iPad on your radio screen.
- Stream NETFLIX movies and TV shows from your iPhone or iPad directly to your radio.
- Touch screen operation plus steering wheel controls for all functions.
- Automatically activates the camera input on all Mygig radios as well as the VES and the Sat TV mode.
- The interface allows manual and automatic activation of front/rear/left/right cameras and provides standard video inputs for each as well as providing camera power connections.
- AUX inputs for video and audio are also included allowing connections from any type of multimedia device to display on the front screen and the audio to be heard through the sound system.
- Provide outputs for audio and video to external screens or headrests. The output is fully dual zone allowing independent viewing of video and audio from any of the connected sources regardless of what is being viewed on the the front screen.
- Unlock the factory DVD player for use anytime.
- USB upgradeable to keep it current with Lockpick advances and vehicle changes.
- PLUG AND PLAY INSTALLATION - SIMPLE - NO WIRING, SOLDERING OR TAPS - JUST PLUG IT IN!
классная штука! а что это?)
Изменено пользователем Gooodwin
7 часов назад, Gooodwin сказал:
В свое время обсуждали:
10 000 руб.
Заинтересовало предложение.
  • Struboob
  • GTApex
  • Коля78
  1. TRS Motors
    • 271 Запись
    • 168670 Просмотров
    Блок камер и парктроников молчит на шине
    Камеры кругового обзора не показывают картинку, пробег на приборке моргает, плюс горит ошибка по системе старт-стоп. Grand Cherokee (WL) 2023 года, пробег всего 10 тысяч.
    Опрос блоков через MDP в wiTECH показал, что модуль парктроников и камер кругового обзора не выходит на связь. Отсюда сразу две жалобы из трёх, потому что щиток не получает данные по шине и подмигивает одометром.
    Почему сбой оказался в программе, а не в железе
    Обесточили блок, сделали Power Reset. После подачи питания модуль отозвался, камеры заработали, пробег моргать перестал.
    Это и есть главный признак, что железо целое, а зависла программа. Мы в ТРС-Моторс на таких машинах сначала пробуем сброс питания и уже по реакции блока понимаем, куда смотреть дальше.
    Программный сбой блока камер и парктроников на этих машинах известен, производитель выпустил по нему бюллетень и закрывает вопрос актуальным ПО. Эта машина пришла из-за рубежа и дилерского обслуживания до нас не проходила, так что обновления копились и никто их не ставил.
    Прошивка через портал FCA и разряженный малый АКБ
    По камерам и парктроникам заливаем актуальную прошивку. Прописывается она только дилерским сканером с прямым подключением к порталу FCA, домашним Wi-Fi тут не обойтись.
    Ошибка старт-стоп к блоку камер отношения не имеет, причина в низком заряде малого аккумулятора. Машина шла морем два-три месяца и всё это время стояла разряженной, а запуск раз в месяц на стоянке заряд не восстанавливает. Замену малого АКБ по этой машине уже согласовали.
    Моргающий пробег и погасшие камеры на пригнанном WL
    Если пробег на приборке моргает или пропала картинка кругового обзора, не спешите менять блоки. На пригнанных WL это чаще софт, электроника поднимается после сброса питания, а вопрос закрывается прошивкой.
    Когда после Power Reset блок так и молчит, дальше смотрят проводку и сам модуль.
    Проверьте и малый аккумулятор. После дороги морем он почти наверняка разряжен глубоко, а на севшем малом АКБ отваливаются старт-стоп и часть электроники.
    Та же связка накопленных прошивок и разряженного аккумулятора попадается на свежих Wagoneer, платформа и электроника у них близкие.
  2. Обзоры и статьи о машинах.
    • 18 Записей
    • 11857 Просмотров
    • 417748 Просмотров
