Uconnect Update
Автомобиль: Grand cherokee 3.0 v6 250cv 2016
Ciao ragazzi, so che è un argomento trattato mille volte, ma ho bisogno di aiuto, qualcuno può fornirmi il firmware ( - UCONNECT_8.4AN_RG4_17.46.01_MY14_EMEA - oppure - UCONNECT_8.4AN_RG4_17.46.01_MY15_EMEA - il modello della mia jeep è un my15 ) non riesco a trovare il download da nessuna parte, neanche a pagamento, ho cercato da per tutto, ho trovato solo quello usa ma che ovviamente non me lo installa perchè mi dice che la mia vettura ha bisogno di quello europeo.
Davvero ve ne sarei infinitamente grato se mi dite dove poterlo recuperare. Grazie a tutti
Hi guys, I know this is a topic covered a thousand times, but I need help, can someone provide me with the firmware ( - UCONNECT_8.4AN_RG4_17.46.01_MY14_EMEA - or - UCONNECT_8.4AN_RG4_17.46.01_MY15_EMEA - the model of my jeep is a my15 ) I can't find the download anywhere, not even a paid one, I've searched everywhere, I only found the US one but it obviously doesn't install it because it tells me that my car needs the European one.
I would really be infinitely grateful if you tell me where I can get it. Thank you all
  • Кто в онлайне   16 пользователей, 0 анонимных, 157 гостей (Посмотреть всех)
    • RockMANN
    • Tumbal
    • Юрко
    • Djmrak
    • matrixgreen
    • Олег Щербаков
    • Monar4
    • dimitr
    • Desert Fox
    • serg102
    • Intrepid
    • MikeGCh
    • Vovangrand
    • Сергей Фед.
    • kapitalist
      Что оказалось причиной утечки
    2. Введение.
      Вариации двигателя
      1. Standard Output (S.O.):
      2. High Output (H.O.):
      Применение в моделях
      RAM 1500
      Другие модели
      Положительные отзывы
      Критика
      Мнения со всего мира
      Сравнение с конкурентами
    popovjury.92
    popovjury.92
    • Andy013
      Andy013  »  Лунный пчел
    • WEST  URAL
      WEST URAL  »  Лунный пчел
    • Dibosh4х4
      Dibosh4х4  »  up6
      · 1 ответ
