Чип-тюнинг 3.0 CRD на WK2
Может кто-то подсказать, а какая заводская мощность у дизельных Грандов, предназначенных для продажи в США и в Европе?
667
4 часа назад, Юрко сказал:
У них в сервисной документации указано только: Power 184 kW @ 4,000 rpm
        Torque 570 Nm @ 2,000 rpm
Получается, они у них продаются с мощностью 250 л.с.  Буду думать.
Изменено пользователем Юрко
12 часов назад, Юрко сказал:
Практически все американцы чипуются программой от фирмы GDE  https://www.greendieselengineering.com/PerfCompFCAEcoDiesel.action и получают кучу плюсов
Benefits and Features of the GDE tunes for the EcoDiesel V6s (Ram 1500 and Jeep Grand Cherokee)
  • GDE Combustion Concepts
    • Optimized fuel economy (3-5mpg* improvement) both while driving and at idle
    • Engine longevity increased
    • Transient management of injection timing to reduce combustion noise
  • Better transient engine performance
    • Faster time-to-torque giving elevated customer confidence in the driving experience
    • Required accelerator pedal effort to hold constant speeds is reduced
    • Engine performance is improved over stock from sea level to 12000ft elevation
    • At 5000ft, 0-60mph is 1.5s faster; at 9000ft, 0-60mph is 0.75s faster
  • Refined cruise control operation (only for vehicles without adaptive cruise control)
    • Retuned speed control for improved fuel economy
    • Better gear holding during accelerations and uphill driving
    • Lower possible set speed (15mph instead of 25mph, can resume from 5mph)
    • Faster buttons' response
  • Superior management of grille shutters
    • Shutters will now function in cold ambient temperatures for better warmup performance
    • More expansive criteria for closing the shutters
  • Improved operation of three-way coolant valve to give engine warm-up benefits
  • Two-footing driving is now permissible
  • Eliminated high pressure pump noise for MY15 and newer vehicles
    • Also applicable to MY14 vehicles that have been recently re-flashed
  • More intuitive driver indications
    • "Engine Power Reduced" warning for hot oil temps activated at lower temp
    • Glow plugs indicator will be displayed only when glow plugs are actually on
  • Improved cooling fan control
  • Улучшено управление охлаждающим вентилятором
    • Fan will now run for a certain amount of time after shut-down to cool down the engine and exhaust system                                         После отключения вентилятор будет работать в течение определенного времени, чтобы охладить двигатель и выхлопную систему.
    • Activates if either the regen is still active when the engine is shut off, or if the exhaust temps are above a prescribed limit                       Активируется, если регенерация все еще активна, когда двигатель выключен, или если температуры выхлопных газов превышают предписанный предел
    • Earlier activation based on coolant temp while driving to keep engine and oil cooler        Более ранняя активация на основе температуры охлаждающей жидкости во время движения для поддержания охлаждения двигателя и масла
  • Inducement improvements: torque limitation instead of no-start, activates after one key cycle instead of immediately.
  • Disabled low voltage charging mode in order to properly drive electrical accessories in all conditions
68
Автомобиль: Jeep Grand Cherokee WK 2
2013
CRD
1 час назад, Vietnamez сказал:
С Экотюнер буду экспериментальную прошивку вливать - задача была вентилятор настроить на более ранние температуры. HP тоже говорят что есть что то, но нужно экспериментировать, не эта ли программа у них и имеется, ссылались на то что из США, но мол не ставили ни разу.
667
Спасибо, Павел! Получается, прирост мощности у них не намного. Она только достигается более плавно при увеличении оборотов. У нас прибавляют аж 55 л.с., что может сказаться на ресурсе двигателя и коробки. Или не так?
Да и работа того пресловутого вентилятора у амеров тоже упорядочена! Я там в прошлом сообщении на русском языке прочитал про их программу, конечно, впечатляет, что они не ограничиваются только увеличением мощности, главное в их программе - улучшение эксплуатации авто.
Как дальше развивается Ваш интерес к этой программе?
15 часов назад, Юрко сказал:
дизельные гранды в америке имеют The 3.0-liter EcoDiesel V6 produces 240 horsepower and 420 lb-ft of torque in the Grand Cherokee.  откуда 570 ньютонов? их д
1 час назад, Юрко сказал:
написал им письмо...спросил для российского варианта дизеля ЕВРО-4 с ЕГР,  но без сажевого фильтра и мочевины есть у них вариант тюнинга и имеют ли они контакты с тюнинг-конторами в России...будет ответ  напишу тут
667
Замечательно, буду ждать результаты. Сообщите тогда в личку мне, хорошо?
А это мне спецификацию их сбрасывали. Не могу ее пояснить, самому было интересно узнать, какая там заложена мощность и отсюда оценить запас ресурса. Если он просто рассчитан на 250, а подняли еще на 55 и говорят, что ресурс не страдает - тут что-то не то.
667
30 минут назад, Vietnamez сказал:
Неплохо бы было, если такие бы нашлись у нас или в Белоруссии. Да и в Европе должны быть, в Италии, но там все с экологией.
Mps
552
Автомобиль: WK2
@Vietnamez 420 это фут-фунт. Для перевода в Ньютон-метр используйте множитель 1.35576. Вот вам и 570.
55 минут назад, Юрко сказал:
на  DODGE RAM1500 3.0L EcoDiesel V6 двигатель (4x2)  идет с заводкой прошивкой в 260 л.с. и 480 фунт-футов максимальный крутящий момент (это на минуточку 650 ньютонов!!) и дают заводскую гарантию... так что в теории запас прочности какой-никакой у него есть..
667
9 минут назад, Vietnamez сказал:
Рам должен грузы и прицепы таскать. Конечно, не ограничивается только 250 л.с., но к  их 250-260 не прибавляют же ещё 45-55.  И нужно оценивать все в комплексе, включая коробку, карданные валы и мосты.
У нас погонять только, а они молодцы: чрезмерно не прибавляют, а в комплексе все улучшают для комфортной езды.
3 часа назад, Юрко сказал:
увы....
We do not have tuning for that model of vehicle.  The US version has different software and hardware, so our tunes for the US models will not work on the export market.
Thanks
У нас нет тюнинга под эту модель автомобиля. Американская версия имеет различное программное и аппаратное обеспечение, поэтому наши программы тюнинга  для американских моделей не будут работать на экспортном рынке.
26
Автомобиль: Jeep Grand Cherokee WK2 2011
Парни этот дизель просто супер чудо.  И какой дегенерат его разработал ещё большее чудо.  Не уверен что на него плохо может влиять Чиптюнинг так двигатель сам по себе просто отстой.  Поясню почему.  Лопнул у меня коленвал.  Покупаю контрактный двигатель.  Пробег у контрактника подтверждён 51 тыс.  При покупке осмотрел вкладыши и коленвал.  Всё идеально.  Поставил на него новую турбину, новый маслоохладитель и новый тнвд.  Проехал я на нем 3 тыс.  км. Начала на холостых лампочка давления моргать.  Проверил механическим манометром с давлением всё ок.  Заменил датчик, проблема исчезла.  Проехал 30 км, просто 30 км.  не тысяч.  И опять коленвал пополам.  То есть получается в идеальном состоянии с нормальным маслом и давлением.  Просто берёт и лопается коленвал.  И это двигатель? Избавляйтесь от них! И по моему чем быстрее тем лучше.  Хоть машина и неплохая.
26
Не исключаю.  Только всё что мог проверил. Вкладыши и коленвал в идеале.  И визуально и моторист измерял. Сказал что всё идеально.  Моторист естественно не продавца.  Давление в идеале.  Маслоохладитель новый.  Я что-то упустил что надо было ещё проверить?
Вот я и не понимаю как при таких обстоятельствах может лопнуть коленвал.  Двигатель с битой машины.  Кто-то ей сбоку в зад приехал.  Двигатель не пострадал.  То есть факт китайских и восстановленных коленвалов маловероятен.
43
Overland disel
2 часа назад, Vietnamez сказал:
увы....
Сдается мне, что это писал кто то из отдела продаж, а не технарь. Не должно там быть большой разницы между прошивками для США и России. Это экономически невыгодно разрабатывать свой софт под каждый рынок.
Скорее там отдельные настройки изменены. Так их через Альфа обд поменять можно.
В штатах и другие тюнеры есть для экодизеля, например SFT (Sofa king tuning).
По идее, учитывая что этот дизель сначала появился в Европе, европейские тюнеры должны быть более продвинуты.
226
Автомобиль: W166 теперь.
Вот не перестаю удивляться таким публикациям, в который раз повторяю, проехал ЛИЧНО 220т.км и ниразу не пожалел, был бы сейчас такой же новый, купил бы не задумываясь.
667
3 часа назад, Vietnamez сказал:
увы....
Плохо. Я всго лишь 1 раз связывался с амерами, чтобы купить тормозные диски.  Андей тогда был в отъезде и не подключился.
Думал, они там все деловые, а оказалось, что дибилоиды и вредители. Проклял, что с ними связался. Долго переписывался, пока мне не посоветовали более вменяемого. Несколько раз предупреждал, чтобы указали мой телефон, тк тут их почтовая служба меня будет по нему разыскивать. Не указали и они меня не могли найти, написать тоже! На втором ящике опять их просил не забыть, так они вообще сочинили несуществующий код и номер, опять не могли найти! И это, ещё до всех этих накатов на Россию.
С ними стрёмно связываться.
Нужно поискать что-то аналогичное в Европе. В Италии много Грандов ездит, посмотрите их форумы.
26
29 минут назад, Алексей Донской сказал:
Ну может кому как повезло.  Мне тоже автомобиль нравиться по всем параметрам.  Но ввиду этих всех событий придётся сменить.  Меня очень не устраивает уровень надежности.   Получается что всё хорошо у него по всем параметрам.  И обслужен и ухожен. И коленвал сломался.  2 раза уже!!!!   И двигатель менял у официалов кстати. Те тоже подтверждали факт что всё супер. Ну как то так.  Я никому не навязываю свою точку зрения.  Она носит чисто характер  моего случая.  Каждый сам делает выводы.  Я просто считаю, что если всё хорошо у машины, то у неё не должен ломаться коленвал.  Коленвал должен лопнуть только в случае конкретного масленного голодания.  А здесь его не было и в помине.   И это не укладывается в мои нормы надежности авто. Я кстати до этих случаев тоже читал подобные сообщения и считал что это происходит только у людей которые по каким-то причинам плохо содержат свой автомобиль.  И думал что у меня такого не случиться никогда.  А сейчас я считаю что нужно было прислушиваться к чужому опыту, а не на своей шкуре всё это проверять.  Как то так.
Пробег у меня 180 000 сейчас.
667
38 минут назад, Алексей Донской сказал:
Ну да, с пробегами в 150-250 тыс. тут встречаются сообщения, удивительно и радостно за них. А вот про такие поломки - совсем уж единичные.
26
Кто спрашивал про прошивки.   На Adact есть все прошивки под все версии софта наших машин.  В основном все stage1 и егр и сажевик отключены.  Что очень хорошо для двигателя, но плохо для экологии.  Но например производителей КамАЗа это вообще не беспокоит.
26
Парни.  Здесь есть тема на форуме.  Про поломку коленвала на дизеле.  Почитайте.  Посчитайте.  А потом говорите о единичных случаях.   Эти случаи далеко не единичные.  Это по моему уже носит массовый характер.
652
13 часов назад, Serg101 сказал:
Пока что  по этому вопросу общество проходит через стадию отрицания, немного позже придет признание и, еще немного позже, смирение.
PS. Я с 2006 на дизельных ЛР езжу. Ну и на форумах ЛР.  Все один в один. Разница только в том, что проблема коленвалов ЛР более раскручена, так как дизельных ЛР было в разы больше продано.
26
У меня уже пришло признание.  Два раза даже.  А на ЛР по моему только дизель 4,4 нормальный.  Остальные не особо
26
Поломка коленвала это реально большой просчёт производителей.   Ну не должен он ломаться если со смазкой всё хорошо.  Вывод он слаб для этого двигателя.  Тут кстати по поводу чипа тоже.  Чип увеличит крутящий момент.  И весьма существенно.  И мне почему-то кажется что риск поломки колена возрастёт.  Особенно при динамичных разгонах.  Кстати в прошивках заводских есть такой параметр как контроль крутящего момента.  А на stage1  контроль этого параметра отключён.  В общем не знаю что да как там точно.  Но на чипованой гораздо интересней ездить.  У меня тоже чипованый
652
1 час назад, Serg101 сказал:
Моторы нормальные, с  точки зрения тяга мощность экономичность  все V6 3.0 common rail одинаковые практически, 250 лс, около 600 нм, вариации одна-две турбины не в счет.  Что VM, что PSA/JLR, что VW.
Вот только если посмотреть на те же LR дизеля, R4 2.2,  V8 3.6, V8 4.4  - коленвалы не ломает, вкладыши резко не умирают.
V6 2.7, V6 3.0 - непредсказуемо  коленвалы, вкладыши.
На рядных  R6 дизелях  такой проблемы тоже нет.
Так может таки очень сложно сделать прочный/ресурсный коленвал на V6 дизель ? В силу особенностей конструкции V6 ?
А если так, то какой там «мощностной« чип тюнинг может быть ?
21 час назад, AlexIV сказал:
У мерса на 642 моторе вроде нет таких проблем. А разрабатывали его те же итальянцы, что и наш мотор.
652
3 часа назад, ALLIGATOR сказал:
Ну да, еще VAG я не слышал, чтобы ломало. 2:2 пока что.
PS. 642 хороший кандидат на свап.
PPS. Заканчиваю, тема не там, просто  реплика была.
34
Автомобиль: Jeep Commander
6 часов назад, ALLIGATOR сказал:
А с каких пор итальянцы поселились в Штутгарте? Может я чего не знаю, но мне казалось, что OM642 - чистокровный немец.
2 часа назад, amon сказал:
Он был создан еще тогда, когда vm motory имела отношение к мерсу.
  • Кто в онлайне   0 пользователей, 0 анонимных, 143 гостя (Посмотреть всех)
    1. К нам в автосервис TRS Motors поступил интересный экземпляр — Jeep Wrangler JL 2022 года выпуска с пробегом всего 17 000 километров. История у этого автомобиля довольно запутанная: изначально он был предназначен для рынка Ирака, затем через Объединенные Арабские Эмираты попал в Россию, а сейчас его владелец из Чебоксары привез его к нам для комплексного ремонта. Такая схема перепродажи автомобилей, особенно американских марок, через аукционы Дубая стала довольно распространенной. Однако у этих, казалось бы, новых машин часто всплывает целый букет специфических проблем, связанных с региональными настройками, условиями эксплуатации и транспортировки. Владелец этого Wrangler сознательно выбрал наш сервис, долгое время следя за нашей работой по видео, и приехал с четким списком неисправностей, которые мешали комфортной эксплуатации автомобиля. Это яркий пример того, как важно доверять сложные случаи, особенно с иномарками с нестандартной историей, специалистам, которые разбираются в тонкостях конкретных брендов, таких как Jeep.
      С каким списком проблем столкнулся владелец Wrangler
      Перечень задач, который поставил перед нами клиент, был обширным и затрагивал несколько ключевых систем автомобиля. Во-первых, владельца беспокоили неясные проблемы с электрикой, включая неработающий автозапуск двигателя. Во-вторых, требовалась проверка ходовой части на предмет посторонних шумов или нештатного поведения. В-третьих, была необходимость в обновлении программного обеспечения мультимедийной системы и карт навигации, которые для российских регионов часто оказываются устаревшими или некорректными. Отдельным пунктом шла диагностика возможных токов утечки в бортовой сети, которые могли привести к разряду аккумулятора. Но самой интересной и характерной именно для азиатских и ближневосточных версий была просьба отключить звуковое предупреждение, срабатывавшее при достижении скорости 120 км/ч. Эта «фича», раздражающая водителя на трассе, является обязательным требованием для некоторых рынков и глубоко интегрирована в программное обеспечение автомобиля.
      План диагностики и ремонта в TRS Motors
      Наши специалисты разработали четкий поэтапный план работ. Первым шагом стала комплексная компьютерная диагностика всех электронных систем автомобиля. Мы проверили состояние аккумуляторной батареи, измерили реальные токи утечки, что особенно важно для автомобилей со сложной электроникой. Особое внимание уделили системе иммобилайзера и блоку управления двигателем, так как именно они часто являются причиной отказа штатного автозапуска. Параллельно мы подключились к мультимедийному блоку для анализа текущих версий прошивок и карт, а также для изучения конфигурации региональных настроек, чтобы понять, как отключить звуковой сигнал ограничителя скорости. После электронной части автомобиль был поднят на подъемник для тщательного визуального и механического осмотра ходовой части, тормозной системы и элементов подвески на предмет износа, повреждений или неправильной сборки после возможных предыдущих вмешательств.
      Важность профессионального подхода к автомобилям с «историей»
      Данный случай с Jeep Wrangler наглядно демонстрирует, что даже практически новый автомобиль с минимальным пробегом может требовать серьезного внимания специалистов. Покупка машин из-за рубежа, особенно с рынков, отличающихся от российского, всегда сопряжена с рисками. Региональные программные ограничения, неадаптированное навигационное обеспечение, различия в климатических условиях эксплуатации — все это может вылиться в проблемы для нового владельца. Своевременная и квалифицированная диагностика в специализированном сервисе, таком как TRS Motors, позволяет не просто устранить очевидные неисправности из списка, но и провести профилактический осмотр, выявить потенциальные слабые места. Это инвестиция в долгую и беспроблемную эксплуатацию вашего внедорожника, которая избавит от неожиданных поломок и дорогостоящего ремонта в будущем. Мы рекомендуем владельцам автомобилей с нестандартной историей ввода в эксплуатацию обязательно проходить полную адаптационную проверку.
      623
    kirilenkoap
    kirilenkoap
    • Valethaus
      Valethaus  »  Лунный пчел
      Здравствуйте.
    • Wag0807
      Wag0807  »  Лунный пчел
    • kupr_vi
      kupr_vi  »  Loone
      Добрый вечер!
