Климат-контроль WJ/WG
graff-15
Автомобиль: .
01 = IR thermister circuit open
02 = IR thermister circuit shorted
03 = Fan pot shorted
04 = Fan pot open
05 = Mode pot shorted
06 = Mode pot open
07 = IR sensor delta too large
08 = Reserved
09 = Reserved
10 = One of four motor drivers has drive "A" shorted to ground
11 = Engine air intake temperature bus message missing
12 = Country code bus message missing
System faults
13 = Mode motor not responding
14 = AI (Recirc) motor not responding
15 = Left temperature door not responding
16 = Right temperature door not responding
17 = Mode door travel range too small
18 = Mode door travel range too large
19 = AI (Recirc) door travel too small
20 = AI (Recirc) door travel too large
21 = Left temperature door travel too small
22 = Left temperature door travel too large
23 = Right temperature door travel too small
24 = Right temperature door travel too large
25 = Calibration check sum error
26 = Engine coolant temp bus message missing
27 = Vehicle speed bus message missing
28 = Engine RPM bus message missing
29 = OAT bus message missing
30 = Display intensity bus message missing
31 = VIN number bus message missing
32 = Raw OAT buss message missing
Input faults
33 = IR thermister circuit was open
34 = IR thermister circuit was shorted
35 = Fan pot was shorted
36 = Fan pot was open
37 = Mode pot was shorted
38 = Mode pot was open
39 = IR sensor delta was too large
40 = Reserved
41 = Reserved
42 = One of four motor drivers had drive 9A9 shorted to ground
43 = Engine air intake temperature bus message missing
44 = Country code buss message missing
System faults
45 = Mode motor was not responding
46 = AI (Recirc) motor was not responding
47 = Left temperature door was not responding
48 = Right temperature door was not responding
49 = Mode door travel range too small
50 = Mode door travel range too large
51 = AI (Recirc) door travel range too small
52 = AI (Recirc) door travel range too large
53 = Left temperature door travel too small
54 = Left temperature door travel too large
55 = Right temperature door travel too small
56 = Right temperature door travel too large
57 = Calibration check sum error
58 = Engine coolant temp bus message missing
59 = Vehicle speed bus message missing
60 = Engine RPM bus message missing
61 = OAT bus message missing
62 = Display intensity bus message missing
63 = VIN number bus message missing
64 = Raw OAT bus message was missing
65 = Reserved
66 = Reserved
67 = Reserved
Автомобиль: jeep grand cherokee wj 4.7
Сегодня снял блок климат контроля почистил контакты и на актуаторе почистил. Пока все гуд но выдает ошибку 56 это правая сторона думаю ее тоже надо почистить и все будет гуд. П.С. Контакты это болезнь походу дела, сталкиваюсь не первый раз
31
Автомобиль: Chevrolet Tahoe Gmt 900
Да хрен ты правую почистишь....не долести ваще!!!
Время губит и окисляет контактики не болезнь это а старость :(
Я завтра буду испаритель менять так что долезу!
31
Ну тогда долезеш конечно..советую заодно и радиатор печки промыть!!!
174
Автомобиль: Grand Cherokee 2
7CRD 2002г. лифт +3 см
Ну тогда долезеш конечно..советую заодно и радиатор печки промыть!!! :hands:
@mamyka135, зимой вспомнишь добрым словом :ok:
Радиатор печки уже поменяный. Все равно спасибо. Поменял сегодня испаритель, нусразу заслонки, и почистил все контакты так каждый по отдельности все смазал прикрутил отрегулировал и собрал все гуд. Tomas был прав что проблема в контактах ( респект). На все ушло около 4х часов. Осталось тока заправить кондер. Кто где заправлялся и скока денег.
Изменено пользователем mamyka135
Народ подскажите скока хладогента должно быть залито в кондер???
31
Сколько влезет столько и надо... :rolleyes:
28
Автомобиль: GC 99г 4.7 +2
5'' 99г.КМ2(31") GC 94г 4.0(сток)
кажется 780гр.поищи табличку на капоте с изнанки
Нету таблички на 4.7 посмотрите у кого есть буду ощень благодарен.
Сегодня кондей заправил а потом верхний шланг рванул думаю мож перелили
Автомобиль: JEEP Grand Cherokee Overland
Может кто подскажет, машина WG 4.7. Сегодня печка стала дуть только на максимуме, на регулятор скорости не реагирует. На заглушеном авто и вытащеном ключе, печка молотит на максимуме и переключается на внутреннюю циркуляцию. Чего делать? :blink: Пока только предохранитель снял чтоб вентилятор не дул
28
780гр.
Автомобиль: TRX 6.2
Климат превратился в духовку!
Вчера глюк вылез 2й раз! Первый после мойки.
Заправился, сажусь а, мне комп говорит, что на улице -38С! И меня кипятком минут сорок обдувало! Я реально думал яйца сварятся в пробке, крутилки даже на минимуме не справлялись!! Потом температура на компе поползла к нормальной до + 25С. С стал дуть холодный воздух.
Это уже 2й раз, такой глюк.... как лечится?
12
Автомобиль: 2008 Jeep Grand Cherokee WK Overland 3.0 CRD
такая проблема. Собственно перестаёт иногда дуть вентилятор климата. Иногда помогает включить и выключить мотор, иногда не помогает... ошибок самодиагностика климата не показала. Думаю либо разъём на вентиляторе... либо может на блоке управления, или нет? Сталкивался кто? И может подскажете где находятся разъём вентилятора, и блок управления?
32
Автомобиль: WK2 3.6 LIMITED
http://www.wjjeeps.com/blower_motor.htm
в ногах у пассажира
Автомобиль: audi a6 allroad 2008 3.0 tdi
Спрошу здесь.
Кто что делал с муфтой включения компрессора кондея? У меня её подклинивает иногда, молоточком стукнешь или рукой крутанешь, заработает, потом через некоторое время опять может встать...
12
в ногах у пассажира
вот как может быть, спасибо большое, буду смотреть
Автомобиль: Jeep Grand Cherokee OVERLAND 2.7CRD
Сегодня заправил кондиционер, эффект не тот который я ожидал, заправщик сказал, что всё заправил под завязку. Компрессор работает какими то щелчками,это нормально? Система под давлением, всё вроде бы о.к., но воздух дует какой то не о.к. Может кто что подскажет по этому поводу?
31
Кондей должен работать так..что бы ты его не слышал ваще..он сам по себе..
звуки разные это неисправности!!! и что значит воздух дует как то не ок..поясни!!! :rolleyes:
Изменено пользователем tomas
Воздух не холодный, а больше прохладный. Вчера на улице была температура +32 градуса, кондиционер не справлялся
46
Автомобиль: Был (WJ) 4
7L стал (WH) 4
7L :)
Если щелчки идут из под капота, то это скорее всего компрессор щелкает когда включается и это норма, а то что плохо охлаждается воздух это трабл(
Спрошу здесь.
А на мой вопрос никто не ответит? Хоть кто-то её снимал?
28
найди другую точку по кондюкам,тебе его недозаправили,отсюда хреновое охлаждение и щелчки
да там вобще ничего военного,стопор сними да посмотри чего она клинит Изменено пользователем Dorognik
Dorognik ты так думаешь или уверен? А как проверить полностью ли они заправили кондиционер?
Изменено пользователем BORIS-BLR
28
проверить можно замерив давление в низком и высоком контуре в низком должно быть2.5-3.5атм в высоком 10-15атм,а влазит его 780гр,щелкает постоянно у тебя муфта,пытаясь нагнать давление..а уверен процентов на80 :rolleyes:
давление в норме, кондей заправлен, трубка на входе холодная, компрессор при заправке заработал на давлении в 4.5, включается при давлении 5.5 и выключается при 7.0, но воздух холодный не поступает в салон, а только еле-еле прохладный, заслонки работают, подскажите что не так?
28
паскудный вариант- в испарителе засирается дроссель....или радиатор кондея засран конкретно
  • Кто в онлайне   7 пользователей, 0 анонимных, 209 гостей (Посмотреть всех)
    • alexeysh
    • al_ch
    • Mclaren32
    • Aiden31
    • mixelson
    1. Илья_СХ27
    2. Графит
      • 71028
    3. Течи из-под АКПП на Grand Cherokee WL 2023 года
      Под Jeep Grand Cherokee (WL) 2023 года натекло масло, пробег всего 115 тысяч. Когда машину пригнали в ТРС-Моторс, стало ясно: капает сразу с нескольких мест АКПП ZF, а со стороны мотора к этому добавился текущий задний сальник коленвала.
      Коробку сняли, чтобы разобраться со всеми источниками разом. Течь шла по сальнику входного вала, по резиновому кольцу, которое уплотняет стык на самом валу, и, что нехарактерно, через болты крепления масляного насоса: из тринадцати штук масло пробивалось через шесть.
      Почему масло идёт через болты насоса на ZF 8HP
      На третьем поколении ZF 8HP колодцы под болты сделаны сквозными, а сам крепёж идёт с интегрированными резиновыми шайбами. От температурных циклов эта резина дубеет и трескается, после чего ATF поднимается по резьбе наружу.
      Обычно течь по входному валу и по болтам насоса ловят на агрегатах с пробегом под 250–300 тысяч, которым уже светит капиталка. Здесь всё проявилось вдвое раньше, и причина, судя по всему, в качестве резинотехнических деталей нового поколения.
      Chrysler коробки сам не делает, а ставит готовые агрегаты от ZF. Ранний износ уплотнений похож на общую тенденцию: расходники даже у именитых брендов ходят меньше, чем раньше. Это первый WL в нашей практике с течью именно по такой схеме, станет ли болячка массовой — покажет время.
      Чем закончили ремонт коробки
      Раз коробка снята, доступ открылся ко всем точкам сразу. Поставили новый сальник входного вала, свежее резиновое кольцо на ступицу масляного насоса и заменили весь комплект крепёжных болтов: они одноразовые и идут в сборе со своими резиновыми юбками.
      Заодно поменяли задний сальник коленвала со стороны двигателя. Добираться до него отдельным заходом означало бы второй раз снимать коробку, поэтому закрыли все течи за один визит.
      Что замечать владельцу WL до критической стадии
      Свежие пятна масла под коробкой — повод заглянуть глубже, а не списывать на случайные капли. На WL даже при небольшом пробеге уплотнения коробки и задний сальник коленвала стоит держать в поле зрения.
      Если смазка закапала на асфальт, после стоянки пошёл запах гари или упал уровень в моторе, пора на осмотр: при полной потере герметичности масло начинает капать через нижние дренажные отверстия колокола. Заодно имеет смысл проверить сальники редукторов и раздатки — узлы соседние. А вот гул или вибрация в движении говорят уже о механическом износе подшипников или шестерён, а не о течи уплотнений.
