выбор OBD2 Cканера
Всем привет хочю купить сканер обд2 с возможностью диагностики систем абс желательно с руским интерфейсом но пока таких не видел.. бюджет до 12000р присматриваюсь к Innova 3160 описании поддержка обд2 и возможность диагностигки абс и также заманчива Innova 3140 он судя из описания читает всех джипов с 1981 года до 1995 по старому протоколу и с 1996 года и выше по обд2 но у него нет возможности диагностики абс вот ниже описание по Innova 3140
Может кто-нибудь что нибудь посоветует?
Features and Benefits
Provides SAE enhanced Live Data - views, records, and plays back live PCM data streams
Designed to retrieve diagnostic codes in all OBD2 (1996 and newer) and some of the most popular OBD1
(1981 to 1995) vehicles
OBD1 (82-95) Coverage GM, Ford, Chrysler/Jeep and Toyota/Lexus
Communicates with all OBD 2 protocols: C.A.N. (Controller Area Network), ISO 9141, J1850PWM,
J1850VPW, KWP 2000 ISO 14230-4
Displays Freeze Frame Data
The Equus line of scan tools provide the most diagnostic data and power for the money than any other line of scan
tools! It's patented "All-in-One" display shows 25 vital pieces of information at one time, and all within 15 seconds.
The 3140 can diagnose all OBD II compliant vehicle and most OBD I vehicles as well. This feature-packed tool and
software kit is designed to meet the needs of professional technicians who desire quick and easy access to
diagnostic data essentials for a wide range of vehicles. Features unique patented all-in-one screen display and
LED display for quick emissions check. Includes Spanish and French Interface and Definitions (selected by a menu
command). Retrieves OBD2 DTCs: Generic Codes (P0, P2, P3, and U0 B0, and C0) / Manufacturer Specific Codes
(P1, P3, and U1). Unit can be flash updated with a standard Windows® PC (OBD-PC Link™ software required /
included with tool). Memory / Battery backup for off-car review and analysis.
OBD1 Coverage: General Motors - 1982 to 1993 and some 1994 to 1995 models excludes Saturn vehicles; Ford,
Lincoln, Mercury - 1983 to 1995 models with EEC-IV Systems
Performs: KOEO, KOER, Timing Check, Cylinder Balance Test, Output State Test, Wiggle Test; Toyota / Lexus -
1991 to 1995.
Most models Chrysler / Dodge / Plymouth/Jeep - 1984 to 1995. Diesel trucks 1992-1995
  • Ответы 98
  • Просмотры 61,6k
  • @*AXL*, сканмастер
  • надо правильно установить программу, тогда всё работает. Смотри инструкцию по правильной установке проги. Scanmaster-ELM:   1. Распаковать архив scanmaster_elm_1.7.rar. 2. Установить ScanMasterELM
Launch iDiag (адаптер. бывает для Андроида и для Iphone). Смартфон или планшет, пофиг.
В яндекс вбейте just launch. *кинуть ссыль - боюс что забанят за рекламу ;)
Сегодня убили два часа на гугль (как показалось, с пользой) и три часа на попытки заставить эту дрянь увидеть ЭБУ (как оказалось, без всякой пользы).
Соединяли с iPhone 4s, iOS 9.2.3. по Wi-Fi. Cвязь с айфончиком прекрасная, с ЭБУ через сей девайс соединиться не удалось( Может мы дураки?)
Ни одна из скаченных в эплсторе прога не смогла соединить этот ELM 327 v1,5 c мозгами машинки..
Вот он фашист ... Кто знает, как его правильно пытать?)
ELM 327
использовал такую игрушку (проводную и беспроводную) на 2 разных джипах, на андроиде и на windows7. Работала. Правда читает она немного, но иногда бывает полезна (когда ключем зажигания крутить не хочется))))))
У меня с программой ScanMaster работает. Там два протокола ISO 9141/14230 и еще какой-то,- пробуйте по очереди. И еще скорость работы виртуального порта СОМ должна быть 38400 baud (смотрите инструкцию по установке программы).
А у меня не работает. Нет связи с ЭБУ( Ни, в KJ 2007, ни в KJ 2005. Сунули в какую-то рухлядь от мицубиши - сразу всё увидел. Воткнули в тойоту - пожалуйста. В режиме автоматического выбора протокола. А у нас не работает ни в режиме автоматического выбора, ни при указании на ISO 9141-2, ни, на
ISO 14230... Хнык
А с визуальным портом разобрались? Если порт не тот связи не будет. У меня при запуске программы сначала СОМ 1, а потом когда связь осуществляется- СОМ 3. Надо выбрать свободный порт, где скорость 38400.
п.4.9 Правил
как это, как это, как это?)))
Я работаю через USB с ноутбуком, так вот при установке проги на ноут устанавливаются драйвера адаптера ELM. После успешной установки драйвера, проверяется номер виртуального СОМ- порта к которому подключен адаптер. Это проверяется в меню: Панель управления\Система\Диспетчер устройств\Порты СОМ и LPT. Запомните или запишите номер СОМ- порта.
Андрей, лучше посмотри ветку форума KJ технический раздел, тема "Диагностика при Check engine", там есть ссылка по ELM.
Изменено пользователем КОГ52
  • МаксимЯкут
  • Sergey 161
  • Rusich
  • barm
  • hekse
  • Ploutos
  1. TRS Motors
    • 275 Записей
    • 174633 Просмотра
    На подъёмнике подвеска молчала
    Владелец жалуется: по передку глухо стукает на крупных ямах и лежачих полицейских, а на ровном асфальте тишина. Grand Cherokee (WK2), удар одиночный, дробью не сыпет.
    Осмотр на весу ничего не дал, все шарниры казались плотными. Такой стук на подъёмнике не ищется, и это не признак того, что подвеска в порядке.
    Почему разгруженная подвеска скрывает зазор
    Стойки стабилизатора это короткие тяги с шарнирами по краям, они связывают стабилизатор поперечной устойчивости с рычагами и передают на него крены кузова. Когда машина висит, подвеска разгружена и вес деталей прижимает шарнир, зазор закрывается и люфта не поймать.
    Мы в ТРС-Моторс нагружали подвеску руками: раскачивали кузов, пока стук не проявился. Источником оказался начальный люфт в шарнире стойки стабилизатора.
    Задубевший пыльник и уходящая смазка
    Пыльник с возрастом теряет эластичность и перестаёт держать герметичность, смазка из шарнира уходит, в паре появляется сухое трение. Дальше шарик разбивает корпус и начинает болтаться в нём.
    Пока зазор небольшой, стойка отзывается только на резких ходах подвески, то есть на крупных ямах и лежачих полицейских. На мелких неровностях ход слишком короткий, чтобы шарнир успел стукнуть, поэтому по городу машина едет тихо.
    Заменили парой, пока посадочное место целое
    Стойка на этой машине ещё не разбита, люфт начальный, так что работа простая и по деньгам недорогая. Меняли обе стороны сразу, чтобы левая и правая тяга держали нагрузку одинаково и стабилизатор работал симметрично.
    Глухой одиночный стук по передку и тишина на ровном
    Глухой одиночный удар на крупной неровности при полной тишине на ровной дороге появляется раньше всего. На этой стадии стойка ещё живая, и замена обходится дешевле, чем после разбитого посадочного.
    Такой люфт часто находится рукой. Возьмитесь за тягу и покачайте её вверх-вниз, ощутимый ход в шарнире чувствуется сразу; как он выглядит при покачивании, показали на видео.
    Когда стук стал звонким и повторяется на любой мелкой кочке, шарнир уже разбит, дальше тянуть дорого.
    Раз машина всё равно на осмотре, посмотрите сайлентблоки рычагов и рулевые наконечники. Они работают в тех же условиях, реагенты и перепады температур сушат резину по всей подвеске одновременно.
  2. Обзоры и статьи о машинах.
    • 18 Записей
    • 16906 Просмотров
    • 422420 Просмотров
