выбор OBD2 Cканера
Всем привет хочю купить сканер обд2 с возможностью диагностики систем абс желательно с руским интерфейсом но пока таких не видел.. бюджет до 12000р присматриваюсь к Innova 3160 описании поддержка обд2 и возможность диагностигки абс и также заманчива Innova 3140 он судя из описания читает всех джипов с 1981 года до 1995 по старому протоколу и с 1996 года и выше по обд2 но у него нет возможности диагностики абс вот ниже описание по Innova 3140
Может кто-нибудь что нибудь посоветует?
Features and Benefits
Provides SAE enhanced Live Data - views, records, and plays back live PCM data streams
Designed to retrieve diagnostic codes in all OBD2 (1996 and newer) and some of the most popular OBD1
(1981 to 1995) vehicles
OBD1 (82-95) Coverage GM, Ford, Chrysler/Jeep and Toyota/Lexus
Communicates with all OBD 2 protocols: C.A.N. (Controller Area Network), ISO 9141, J1850PWM,
J1850VPW, KWP 2000 ISO 14230-4
Displays Freeze Frame Data
The Equus line of scan tools provide the most diagnostic data and power for the money than any other line of scan
tools! It's patented "All-in-One" display shows 25 vital pieces of information at one time, and all within 15 seconds.
The 3140 can diagnose all OBD II compliant vehicle and most OBD I vehicles as well. This feature-packed tool and
software kit is designed to meet the needs of professional technicians who desire quick and easy access to
diagnostic data essentials for a wide range of vehicles. Features unique patented all-in-one screen display and
LED display for quick emissions check. Includes Spanish and French Interface and Definitions (selected by a menu
command). Retrieves OBD2 DTCs: Generic Codes (P0, P2, P3, and U0 B0, and C0) / Manufacturer Specific Codes
(P1, P3, and U1). Unit can be flash updated with a standard Windows® PC (OBD-PC Link™ software required /
included with tool). Memory / Battery backup for off-car review and analysis.
OBD1 Coverage: General Motors - 1982 to 1993 and some 1994 to 1995 models excludes Saturn vehicles; Ford,
Lincoln, Mercury - 1983 to 1995 models with EEC-IV Systems
Performs: KOEO, KOER, Timing Check, Cylinder Balance Test, Output State Test, Wiggle Test; Toyota / Lexus -
1991 to 1995.
Most models Chrysler / Dodge / Plymouth/Jeep - 1984 to 1995. Diesel trucks 1992-1995
  • Ответы 98
  • Просмотры 62,1k
  • @*AXL*, сканмастер
  • надо правильно установить программу, тогда всё работает. Смотри инструкцию по правильной установке проги. Scanmaster-ELM:   1. Распаковать архив scanmaster_elm_1.7.rar. 2. Установить ScanMasterELM
WH 3.0 CRD елм327 читает без проблем
подниму тему, может кто знает что под гч Z-ку идет,какая прога и кто что юзал
Рестайл - любой к-лайн адаптер + любая универсальная прога. К примеру, элм + сканмастер.
елм-ка у мну есть но только она не видет абс,да и много чего не видет
Остальное видится только дилерским оборудованием.
понятно,но оно стоит как космолет :crazy::blink:
Диагностика у дилера стоит дешевле.
это точно подмечено
  • 6 месяцев спустя...
Подключил программу ScanMaster-ELM с помощью ELM 327 все что эта прога смогла показать.
http://hkar.ru/udhv
http://hkar.ru/udhw
http://hkar.ru/udhx
Изменено пользователем EvgeniyTV
У меня ЕЛМка в сканмастере видит намного больше. За DRB обращаюсь только по вопросам SRS.
@Поручик Ржевский, При подключении какой протокол связи использовать?  Нужно проверить работоспособность датчиков температуры. Обороты 1500.
А я как- то не обращал внимания, в настройках стоит "автовыбор", там целая пачка. Но вот вчера сканил оверленд 2007года, дизель, и там протокол с поддержкой CAN, это точно помню. А на моем старом KJ вроде 1890.
http://elm327.su/52-jeep.html Описание протоколов подключения.
Купил себе Launch iDiag для андроида.
Все читает. Активировал закрытие замков в движении. Глубоко еще не лазил все на Инглишь.
Расстроило, что не работает тест равномерности цилиндров, тест компресии и еще какой то RPM тест ;(
Сколько стоит Launch iDiag?
4-5т. За 4 сказали ждите, скоро будут. За 5 было рядом с домом, там и взял.
Далее или лицензия по маркам, по 66$, или по 300р за марку на Juste. Ессно выбрал второй вариант ;)
Изменено пользователем BerkutMsk
Я за год владения, с учетом потери двух комплектов чипованных ключей последовательно, за несколько встреч с DRB ещё пятерку не потратил. А тут ещё андроидное устройство надо докупить... ХЗ, господа, ХЗ.
Смартфон то был, к нему и покупал. На IPhone такой тоже есть.
К тому же он универсален. И себе ошибки посмотреть, отцу, жене, приятелям.
@BerkutMsk,  Я вот тоже думаю чего взять. Меня интересует датчики парковки, он их видит?
Сам блок парктроников точно видит. Датчики на память не помню, надо проверять.
@BerkutMsk, Уже хорошо. Меня просто интересует, может ли он определять, когда один из датчиков сдох?
Если сдохнет один любой, то ошибка будет, почти уверен.
Далее если в блоке заложено (скорее всего) определять какой именно датчик чудит, то выдаст код.
Далее, Лаунч либо тупо код даст, либо укажет его расшифровку.
Вообще тестить надо.
На WK хорошо совтина работает, а на MB W211 02г, сама менюшка кривая, хрен кнопки нажмешь. Может если на планшете, то ровная будет.
У Вас датчик сдох какой то?
@BerkutMsk,   Пару раз уже было такое. Не охота каждый раз отдавать за диагностику. Я пытаюсь до чего могу добраться сам чинить, вот на это случай хочу завести. Хочу найти чтоб побольше читала именно дизельную машинку.
я позавчера ездил на диагностику (ошибки по абс посмотреть). У мужичка былприбор, который считал все, говорит название triscan, мол они и дешевые и видят весь джип. Никто не сталкивался?
По использованию ELM 327 и Андроид
@Creoman,  Надо будет поинтересоваться про такой сканер.
Launch, почему.
Один из лучших проф мультимарочников. Jeep мой читает. Если когда то авто другое будет, скорее всего и его читать будет.
В общем мой выбор - Лаунч.
@BerkutMsk,Не будет-ли любезен, достопочтимый джин... Подсказочку необходимо, что такое Juste? Как устанавливать программулину. Уточнить можно ещё, как точно называется моделька лаунча?
Изменено пользователем Motoborg
Ну да.тоже интересно
Приобрел сей девайс у китаезов,спланшетом соединяется,а вот с авто нет,наверное брак,цена 280рупий.post-23749-0-45036800-1408265080_thumb.jpg
  • serg102
  • Я Геннадий
  • зампоспец
  • Feofanoff
  • Константин_
  • Егор Пятигорск
    • 53 Записи
    • 461813 Просмотров
    Снимаем коробку.
  2. Обзоры и статьи о машинах.
    • 24 Записи
    • 48005 Просмотров
    1. Что ПРИНЦИПИАЛЬНО нового?
    2. Моторы и трансмиссия
  3. TRS Motors
    • 306 Записей
    • 31 Комментарий
    • 220843 Просмотра
