Новая прошивка uConnect
Автомобиль: Jeep Grand Cherokee Trailhawk
3 часа назад, den_ej20 сказал:
да брал оттуда, папка 2018 Panasonic
UCONNECT_8.4_UGQ_IR21.9-WK-MY19.zip - если не ошибаюсь то этот архив
Спасибо!
6 часов назад, den_ej20 сказал:
он только для EU Grand Cherokee 2018 with Panasonic Carplay Uconnect navigation system
EU это без передних крюков?
119
Автомобиль: Jeep GC Limited 2017y / BMW X4 2.8i / Jeep Commander 4.7 Lim
Город: Георгиевск & Архыз, глемпинг "Счастливый Лось"
В 05.11.2020 в 11:17, Vietnamez сказал:
Парни. Чота я не вкурил. После того, как попробовал скачать(впервые на e-Bay). Написали, что не могут доставить в РФ.
Сегодня получил на почту(указал при регистрации), такое вот письмо.
A Uconnect Software Update must be performed before this map update can be purchased and installed. You will not be able to activate your map update, if this software is not installed.
Please read below for further instructions to update your software.
1.    Verification of Software Version
1.
a.  a. To check if you need a software update, please visit: SEE PICTURE NUMBER 3 IN LISTING
b.  b.   Enter your vehicle identification number (VIN) and the web site will determine if your vehicle needs a software update.
c.  c.  If an update is required, please follow the instructions on the website.
d. d. Before installing any map update the software update will have to be completed.
2.     2. After receiving USB with Connect Map Data from us, insert it into USB port and you will see below info:
*see picture number 4 in listing
1.     3. Choose “UPDATE NOW” option and system will show you below screen.
*see picture number 5 in listing
1.    4. Take a picture of this screen and send it to us.
2.    5.  After receiving the code back from us, press “ok” and you will see space to input the code.
3.    6. Input the code received from us, confirm and update will start.
4.    7. System will guide you through the update (follow instructions on the screen).
If you do not have built-in Navigation on your Uconnect® 8.4A system (RA3 sales code), you should order second code to activate navigation function. This product is available on our other listings. Please paste the below item number into ebay search engine and it will take you directly to the correct listing:
 Если кто не владеет аглицкой мовой, вкратце.
Перед заливкой новых карт, нужно обновить головное. Иначе не пойдет. Ссылку дают.
Далее, они пришлют флешку, нужно вставить и отправить скрин экрана.
Кароч.
Устал писать.
Вопрос такой. У вас тоже были все эти танцы с бубном или только мне такая радость досталась?
Может я что не так сделал при регистрации на eBay?
P.S. Интересно то, что в конце написано. Можно активировать карты на тех головах, где они изначально не стояли. Т.е. на RA3.
119
В 11.12.2020 в 11:49, Ser1982 сказал:
Значит модернизация RG3  невозможна и вопрос навигации решится только установкой доп модуля андроид или есть варианты?
Я решил купить на eBay.
Смотрите что там написано в конце. Это они мне на мыло прислали письмо.
if you do not have built-in Navigation on your Uconnect® 8.4A system (RA3 sales code), you should order second code to activate navigation function. This product is available on our other listings. Please paste the below item number into ebay search engine and it will take you directly to the correct listing:
223199061051
- An activation code is needed to unlock the map data (after purchase, you will have to send us on screen code number – we will email you your unique activation code)
Получается, что вы можете активировать навигацию у себя.
Если проблема с переводом, то помогу.
Вкратце. Зайдите на eBay в поисковик и забейте вон тот код: 223199061051
Должна появиться ваша прога для нави, после покупки вы вышлите им скрин экрана и т.д. как в моем посте выше.
Изначально Ходил по этой ссылке:
https://www.ebay.com/i/223199074920?ul_noapp=true
Изменено пользователем Николай Южный
1 104
Автомобиль: Liberty 2.0 CRD
RAM 2500 6.7 тоже дизель
Объясняю.
Это продажа европейских карт на американские головы RA3 и RA4( то есть для машин, которые продаются для региона NAFTA- Северная Америка, Канада и Мексика).
Смысла покупать их для европейских голов RG3 и RG4, кмк, нет.
17
Автомобиль: Jeep Grand Cherokee 2017 Trailhawk
7 часов назад, Dobromyslov сказал:
у меня с крюками
В 16.12.2020 в 13:50, den_ej20 сказал:
там идет описание к архиву со строчкой Russian language enhancements
This bulletin applies to vehicles built on or after July 24, 2017 (MDH 0724XX) and on or before August 28, 2018 (MDH 0828XX) equipped with a Uconnect 8.4 navigation radio (Sales Codes UGQ)
Скачиваю архив,  а он не открывается. Ошибку выдает.
Может быть у кого-нибудь есть возможность загрузить эту версию?
59 минут назад, Dobromyslov сказал:
Разобрался, вопрос снят
17
10 часов назад, Dobromyslov сказал:
Установил?
2 часа назад, den_ej20 сказал:
Установил?
Еще нет, пока просто скачал
Обновился, вроде бы пока норм все.
78
Автомобиль: jeep wk2 TRAILHAWK 3.6
В 15.12.2020 в 11:10, Dobromyslov сказал:
Подскажите, какая последняя версия прошивки на Trailhawk 2017 года.
1C4RJFLG8JC146906
Имею ввиду на ресурсе mydrive
Спасибо
RG4 17.46.01 это самая новая и наверное последняя  на этот модельный год MY17
10 часов назад, FISH сказал:
У меня 18-й модельный год, Панасоник
Автомобиль: Dodge Durango
Приветствую.
Подскажите пожалуйста
У меня американская машина 2014 года, там такая магнитола:
Цитата
8.4-in. touchscreen (RA4) Uconnect Access Via Mobile
AM/FM/CD/HDD/MP3/ SiriusXM Radio with voice recognition navigation
С mydrive я могу установить какую-то "русскую" прошивку на свою магнитолу?
Спасибо.
78
В 05.01.2021 в 14:11, f2d сказал:
Приветствую.
Спасибо.
надо пробовать , но скорее всего не получится, т.к Uconnect зашит под конкретный регион.  Но могу ошибаться
Автомобиль: Dodge Ram 1500 2014
@FISH
приветствую! подскажите пожалуйста:
пытаюсь обновить uconnect 8.4 на ram 2013 (модельный год 2014) стоит 13.чето там версия прошивки, оф сайт предлагает
uconnect 8.4A_15_26_1_MY14_RJ13, но скачать не дает,
на https://www.mydrive.ch в папке RJ13 с меткой MY14 есть 2 файла это
Uconnect_8.4A_RJ3_16.13.13_MY14.zip
и
MY14_RJ3_ROW_15_26_1.exe
второе, судя по всему, то самое что рекомендует офф сайт, (разве что смущает метка ROW что это?) ставить ее или можно попробовать первый вариант, всетаки 16 повыше прошивка, должна встать? или рисковано?
мой vin 1C6RR7JT1DS697517
спасибо большое!
Изменено пользователем arti24n
1 104
UCONNECT® 8.4A_15_26_1_MY14_RJ3
это Ваша прошивка
ROW- в переводе, весь остальной мир.
Обычно, машины, выпущенные для Казахстана, попадают в эту категорию.
РS.  И я не ошибся.
8G6 Kazakhstan Country Code
Автомобиль: GrandCherokeeWK2
Доброго дня!
Подскажите пожалуйста, какую посленюю прошивку можно установить на магнитолу?
Машина: GC WK 2 Laredo 2013
ГУ: 8,4
Версия программного обеспечения: 14.22.13
VIN: 1C4RJFAM2EC235336
Без нави
Изменено пользователем mcmolotka
56
Автомобиль: ока
Задумался о том, чтобы сделать  апгрейд прошивки, но прежде чем начинать, хочу понять какие преимущества дает новая прошивка по сравнению со старой? Исправление мелких ошибок ПО - это понятно, пробежавшись по списку ничего полезного для себя не увидел, кроме исправления ошибки по времени и часовым поясам. Но даже это - мелочь.
А что еще из удобств есть в новой версии прошивки?
Сейчас стоит прошивка  14.25.5., что изменится, если установить 17.46.01. ?
Машина конца 2013 года, с навигацией.
Изменено пользователем Needle
358
@Needle Можно рабочий стол меню настраивать по своему, обои менять
56
Автомобиль: ока
3 часа назад, Boosel сказал:
А что-то реально полезное есть? Ну это все "рюшечки", по большому счету мне на них наплевать. Может быть появляется какой-то дополнительный функционал?
ЗЫ: я вот на картинках в инструкции по апгрейду вижу меню APP, у меня такого нет сейчас.  Там что-то интересное есть? У меня, кстати, на этом месте иконка "установки"
ЗЫЫ: перепрошил. НО теперь в разделе радио постоянно висит надпись "invalid destination code". Поиском что-то ничего не ищется, кто-нибудь сталкивался?  Ресет сделал, не помогает. Или надо несколько раз ресетить?
Автомобиль: Grand Cherokee (WK2) overland 2011
Всем добрый день!
читал читал, так и не понял как мне правильно поступить и где взять файлы прошивки
хочу избавиться от синей темы
говорят на новых прошивках звук получше
вот фото версии ПО что у меня  установлено
Помогите пожалуйста, дайте ссылку на ветку где пошагово расписано
Спасибо!
358
14 часов назад, Самара 74 сказал:
Всем добрый день!
Спасибо!
с таким ГУ, вам в другую тему
может там и ответы найдутся :up:
В 21.01.2021 в 10:21, mcmolotka сказал:
Доброго дня!
ГУ: 8,4
Без нави
Есть ли эксперты в данной области? или как-то самому можно это узнать?
78
В 25.01.2021 в 10:19, Boosel сказал:
В 24.01.2021 в 20:07, Самара 74 сказал:
Всем добрый день!
Спасибо!
С полной ответственностью заявляю ,что у Вас самая последняя прошивка . Для RB2 новее прошивок нет в принципе. Если вы даже накачали прошивки 30.хх.хх , 50.xx.xx , то установить их не получится , к сожалению.
2 минуты назад, FISH сказал:
да, согласен. перелопатил соседнюю ветку, понял что это конец эволюции))
В 22.01.2021 в 18:03, Needle сказал:
У меня так было. Я скидывал до заводских настроек а затем обновлял, помогло
56
Автомобиль: ока
38 минут назад, Роман 5 сказал:
Я ресет делал, не помогло, но на другой день само собой прошло.
Автомобиль: Jeep
Такой вопрос Гранд 2018 года, Панасоник голова с андроид авто. Машина с США, поменял через обд код региона с США на Россию. Голова подтянулась на русский, но пропал звук с радио и автозаводка машины. Могу ли я залить новую версию прошивки Uconnect и карты Европы. Потому как штатный навигатор уже видит мое реальное местоположение, но на пустой карте?
Спасибо
Автомобиль: Jeep
2 часа назад, Alexpmr сказал:
Спасибо
  • Кто в онлайне   4 пользователя, 0 анонимных, 192 гостя (Посмотреть всех)
    • brat-kondrat
    • Roger
    • betuci
    1. В наш сервис TRS Motors обратился владелец Jeep Grand Cherokee 2012 года с пробегом 188 тысяч километров. Основной жалобой было появление сигнала 'Check Engine' на приборной панели, что всегда вызывает беспокойство у водителей. Загоревшаяся лампочка не просто информирует о неисправности, но и может сигнализировать о серьезных проблемах с двигателем, которые требуют немедленного вмешательства. Владелец автомобиля вовремя отреагировал на предупреждающий сигнал и привез машину на профессиональную диагностику, что в дальнейшем помогло избежать более сложных и дорогостоящих ремонтов. Для автомобилей Jeep с подобным пробегом проблемы с системой EGR не являются редкостью, особенно если ранее не проводилось ее плановое обслуживание. Современные diesel и бензиновые двигатели чрезвычайно чувствительны к состоянию системы рециркуляции отработавших газов, и ее неисправность может привести к ухудшению динамических характеристик автомобиля, повышенному расходу топлива и даже повреждению сопутствующих систем двигателя.
      Что показала диагностика системы EGR
      После подключения профессионального диагностического оборудования наши специалисты считали ошибки электронной системы управления двигателем. Диагностика четко указала на проблемы в системе рециркуляции отработавших газов (EGR). Эта система предназначена для снижения выбросов оксидов азота путем возврата части отработавших газов обратно во впускной коллектор. Однако со временем клапан EGR и сопутствующие элементы забиваются продуктами сгорания, что приводит к некорректной работе всей системы. При визуальном осмотре было обнаружено, что не только клапан EGR, но и радиаторы системы были значительно загрязнены. Такое состояние элементов системы EGR характерно для автомобилей с пробегом свыше 150 тысяч километров, особенно если автомобиль часто эксплуатируется в городском цикле с частыми остановками и небольшими пробегами. Накопление сажевых отложений нарушает нормальную циркуляцию газов и может привести к неправильной работе всей системы управления двигателем.
      Процесс ремонта и очистки системы EGR
      Наши специалисты приняли решение о необходимости полной разборки системы EGR для тщательной очистки всех компонентов. Этот процесс включает демонтаж клапана EGR, патрубков и связанных с системой радиаторов. Очистка проводилась с использованием специальных средств, эффективно удаляющих углеродистые отложения и нагар. Особое внимание было уделено радиаторам системы, которые выполняют важную функцию охлаждения отработавших газов перед их подачей обратно в цилиндры двигателя. Сильно загрязненные радиаторы не только снижают эффективность работы системы EGR, но и могут привести к перегреву и повышенному износу двигателя. После механической и химической очистки всех компонентов система была собрана и проверена на герметичность. Качество очистки подтвердилось отсутствием ошибок при повторной диагностике и стабильной работой двигателя на различных режимах эксплуатации.
      Дополнительный ремонт форсунок по инициативе клиента
      После успешного ремонта системы EGR и тест-драйва, который подтвердил устранение ошибки 'Check Engine', владелец Jeep Grand Cherokee принял решение о проведении дополнительных работ по ремонту топливных форсунок. Это разумное решение, учитывая пробег автомобиля и важность правильной работы системы впрыска для современных двигателей. Наши специалисты демонтировали все шесть форсунок и отправили их на специализированный ремонт. Диагностика показала, что три из шести форсунок требовали восстановления. После профессионального ремонта форсунки были установлены на место, прописаны в электронной системе управления двигателем и выполнена процедура сброса адаптаций. Такой комплексный подход обеспечил не только решение текущей проблемы с EGR, но и профилактику возможных будущих неисправностей, связанных с системой топливоподачи.
      Важность своевременного обслуживания системы EGR
      Регулярное обслуживание системы EGR критически важно для поддержания оптимальных характеристик двигателя и соблюдения экологических норм. Загрязненная система EGR приводит к нарушению состава топливно-воздушной смеси, потере мощности, повышенному расходу топлива и увеличению вредных выбросов. В запущенных случаях это может привести к повреждению каталитического нейтрализатора, ремонт которого обходится значительно дороже профилактической очистки EGR. Для владельцев автомобилей Jeep с пробегом более 150 тысяч километров мы рекомендуем включать диагностику системы EGR в перечень регулярного технического обслуживания. Своевременное обнаружение и устранение проблем позволяет избежать более серьезных последствий и продлевает срок службы двигателя. В нашем сервисе TRS Motors мы используем профессиональное оборудование и оригинальные подходы к решению подобных проблем.
    2. Рестайлинг Jeep Grand Cherokee 2026: Новинки и изменения для энтузиастов off-road
      Комплектации
