Отзывные (recall) на WK/WH
Pinned posts
65
Вбиваем сюда ВИН https://www.mopar.com/en-us/my-vehicle/recalls/search.html и видим актуальные реколы
Изменено пользователем ruby12
новый линк
Автомобиль: Гранд Чероки WH 3
0CRDI
Уважаемые Соклубники!
Кто, что слышал про реколы на Гранды и командеры 2005-2010
Автомобиль: Пешеход 4х4
Я думаю тут конкретно по vin надо определять. Или впринципе какие реколы бывали?
Автомобиль: Jeep Commander 3.0 CRD Limited 2008; Toyota Camry v70 3
5 Lux 2018
Дык официалу позвонить и узнать, есть ли что. По VINу.
Отзывают: 2005 - 2010 Jeep Grand Cherokee
2006 - 2010 Jeep Commander
Проблема с самовольным переключением передач.
Вот статья:
Chrysler's Jeep recalls nearly 470,000 Grand Cherokees and Commanders.
Chrysler Corporation has announced that they will be recalling over 469,000 of their Jeep SUVs for a potentially hazardous issue. The vehicles affected are:
The main issue is that if the vehicle is started, it may shift into neutral. Neither Chrysler or the NHTSA were clear if the brake pedal had to be depressed, in order for the vehicle to shift into neutral. That being said, Chrysler is stating that the issue can be traced back to finding cracks in the circuit board, which may send the wrong signals to the vehicle's transmission. If the vehicle were to go into neutral, it might move forward, increasing the risk of it being involved in an accident with another vehicle, person(s), or property.
It has been reported that thus far, there has been 26 accidents, and two injuries. Neither companies provided further details into the accidents and injuries.
The investigation began in January 2012, after an owner had filed a complaint stating that the vehicle had rolled away, once the it was started remotely. Moreover, Chrysler also stated that other cracks in the circuit board could affect models equipped with four-wheel drive, which could turn it on and off unexpectedly.
http://www.examiner.com/article/chrysler-s-jeep-recalls-nearly-470-000-grand-cherokees-and-commanders
Автомобиль: Grand Cherokee 2005 (WK) CRD
Уважаемые форумчане!
Пожалуйста, прокомментируйте вот такую ситуацию:
Имеется чипованный Jeep Grand Cherokee 2005 CRD 3.0, отключен EGR.
Неожиданно со мной связался официальный дилер и сообщил, что на машину имеется заводской отзыв.
То есть дилер за свой счет устраняет заводской программный дефект коробки/раздатки.
Внимание вопросы:
  • Слетит ли тюнинговая прошивка блока управления двигателем?
  • Знает ли кто-нибудь в чем проблема с коробкой/раздаткой? Может и так можно жить?
  • Удастся ли уехать своим ходом от дилера, если его прошивка внезапно включит клапан EGR?
  • Другие ценные мысли на эту тему?
Автомобиль: ПатруЛь
Если егр включится, то это не значит что машина сломается.
Проблема с акпп и раздаткой, может избавят от удара при сбросе газа, бывало иногда такое.
Чиптюнинг это зачастую настройка только работы мотора и к акпп не имеет ни какого отношения. Так что слетать ни чего не должно, егр в том числе.
Просто перепрошьют модуль управления полным приводом FDCM - никакой связи с егр не прослеживается. Езжайте и перепрошивайтесь спокойно
Автомобиль: в подписи
От удара при сбросе газа именно этот отзыв не лечит (и да, удар скорее неисправность, чем фича).
Прошивка не слетит, но прошивающий аппарат может отказаться шить (он же идентификацию авто у блока двигателя спрашивает, а тюненый может что-нибудь не то ответить). То есть испортить ничего нельзя, но результат 100% успеха не гарантирован. Плюс дилер может чисто теоретически начать кидать предъявы, что модифицированные машины не подлежать обработке "по отзывам", и т.п., неприятно, но - словоблудие, максимум он может отказаться шить по отзыву на блок управления двигателем или что-то делать по отзывам по мехчасти мотора (а таких не было).
Спасибо всем, кто ответил.
Обновление модуля управления полным приводом FDCM прошло успешно.
Чипованная прошивка двигателя никуда не делась.
Оф. дилер никаких вопросов не задал.
а что поменялось то в движении авто после прошивки?
может тоже им позвонить и спросить - что за прошивка.
Поведение авто не изменилось.
По словами приемщика из сервиса, прошивка устраняет самопроизвольное включенияе нейтрали на раздатке во время движения.
(У меня никогда не случалось).
Удары в коробке при сбросе газа - это не лечит.
Позвонить ближайшему дилеру стоит. Так как они дозвонились не до всех владельцев машин, на которые пришел отзыв.
Отзыв, кстати касается и Commander-a.
Автомобиль: JGC WH 3.0 CRD Overland 2008
Подскажите. Касается определенного года авто или как?
Автомобиль: Jeep Grand Cherokee WH 3.0 CRD Limited
Можешь ехать смело, но куда? Я был два раза в автолайте на сталеваров говорили что есть отзыв, но до них ещё не дошел)))
да, вот тоже интересно, где в МСК можно такую информацию проверить
Проверить наличие отзыва можно не поднимая жопы со стула - на сайте Жип американском есть для владельцев проверка на отзывы.
А вот к кому с этим ехать потом - это уже да, иногда вызывает вопросы.
извиняюсь за свою серость, но можно ссылку на место в нете, где можно проверить, а то на jeep.com я что то как баран на новые ворота смотрю и ничего не вижу.
да проще позвонить по ОД и спросить есть или нет и когда подъехать
История с отзывом получила неожиданное продолжение:
В сервисе я не догадался проверить и включить понижайку. А сегодня догадался и получил "SERVICE 4WD SYSTEM".
Опускаю переговоры с дилером, проблема решилась сбросом ошибок.
Ошибка была "Рычаг привода полного привода" или что-то в этом роде (опубликую, если найду номер).
Будьте внимательны при посещении сервисов.
В бюллетене по производству работ в явном виде написано "обнулить все ошибки по всем модулям после перепрошивки". Походу не сделали...
  • 7 месяцев спустя...
Автомобиль: Jeep Grand Cherokee CRD3.0 WH
Сегодня позвонили со Сталеваров и сообщили о заводском отзыве, CRD 2008г.
Такая же хрень, типа коробка самопроизвольно переключается на нейтралку.
Кто там хотел перепрошиваться - велкам.
Я не поеду, ибо ни разу такого переключения не было..
Автомобиль: Jeep Commander 3.0 CRD Overland 2009
В соседней ветке правильные рецепты излечения этой проблемы: у дилера и самостоятельно http://jeep4x4club.ru/forums/topic/33018-esli-service-4wd-system-posle-n23-to/
Автомобиль: Grand Cherokee WH III
У меня на диллере такое было. МНе сказали, что завод на мой вин прислал исправления. Это нифига не стоит и ни на что не влияет. ВОт в целом все.
W124/300E
Мне тоже был звонок из "Автолайта"
У меня такой проблемы не было, стоит ли вообще прошиваться?
хозяин-барин, но у всех поголовно после этого рекола пониженая перестает включаться, официалы потом проблему за денежку решают, если не разведут на моторчик раздатки, или потом манипуляциями самому эту ошибку скидывать, на форуме есть инфа.... я уже 3 раза скидывал за пол года.
Не соглашусь пожалуй.
я сделал себе и ничем хорошим это не закончилось. Хотя может мне и не повезло как обычно)))
  • Кто в онлайне   14 пользователей, 1 анонимный, 273 гостя (Посмотреть всех)
    • Clerk25
    • BIG-JEEP
    • vnchester
    • Иван Ерема
    • biker
    • miron-777
    • Owl
    • xmo97
    • Priot
    • Егор Пятигорск
    • Pavelvernik
    1. Надежный список онлайн-казино (Online Casino) на реальные деньги в  2025 году.
      Рейтинг лучших ТОП 10+ онлайн Казино ( Casino Online ) для игры на реальные деньги по выплатам. Официальный рейтинг Казино с игрой на деньги в России и Снг представляет платформы, с которых деньги выводятся быстро и с минимальной комиссией.
      Наши обзоры и рейтинги помогут вам выбрать лучшие сайты казино с реальными деньгами с хорошей репутацией в России, Украины ,Казахстана и Беларуси в 2025 году, чтобы у игроков был доступ к самым лучшим онлайн-развлечениям.
      На всех сайтах казино действует промокод BONUSFS
      ПОЛНЫЙ РЕЙТИНГ КАЗИНО С БОНУСАМИ  ТОП 120 ЖМИ ТУТ https://t.me/megawintv/1578
      Arkada Casino Казино Аркада — новое онлайн-казино с приветственным бонусом до 15 000 рублей и выбором более 7000 слотов и игровых автоматов. Официальный промокод для регистрации BONUSFS
      IRWIN CASINO - Казино Ирвин онлайн с 2025 года встречает новичков роскошными бонусами на первые три депозита — 225% + 400 фриспинов по промокоду BONUSFS .Топ рейтинга казино онлайн (online casino) на реальные деньги в 2025 году.
      Vavada casino  -Vavada Casino (Вавада Казино) — это официальный сайт онлайн-казино, предлагающий широкий выбор лучших игровых слотов. Исследуйте захватывающие игры, получайте щедрые бездепозитные бонусы и наслаждайтесь моментальными выплатами!
      BANDA CASINO— сайт-ресурс с завораживающими игровыми слотами. Бонус +300% и 100 фриспинов при входе по промокоду BONUSFS через рабочее зеркало банда  Казино .  Banda Casino – топ российское онлайн-казино с бездепозитными  бонусами и слотами на любой вкус. Банда казино зеркало доступно каждый день. Забери бонус +250% и 100FS к первому депозиту в Банда Казино!
      BABOSS KAZINO(Бабосс Казино) Официальный сайт казино Baboss Casino работает с 2025 года и получил лицензию Кюрасао. Бонус +500% и 350 фриспинов по промокоду BONUSFS .  Baboss Casino –самое выигрышное казино в интернете и топ онлайн казино на реальные деньги по выплатам.
      PINCO CASINO — сайт с дающими игровыми слотами. Бонус +150% и 250 фриспинов  по промокоду VINBONUS через рабочее зеркало пинко  Казино .  Pinco Casino – топ казино с бездепозитными  бонусами и слотами на любой вкус. Pinco казино зеркало доступно каждый день. Забери бонус +150% и 250FS к  депозиту в Пинко Казино!
      HONEYMONEY НОВИНКА декабря 2025 . Удобные платежи: СБП, карты, Piastrix, криптовалюты. Для новых игроков действуют сладкие велком-паки для золотых выигрышей: 375% до ₽90 000 + 150 ФС
      Gizbo Casino СУПЕР НОВИНКА № 1 Казино gizbo — Welcome Pack 300% + 100 FS: Начинай свой путь с крутым бездеп бонусом по промокоду BONUSFS ! Лучшие игровые автоматы на реальные деньги
      № 2. LEX казино— Лекс Казино: Надежное Казино-Онлайн на реальные деньги по промокоду BONUSFS Лучшее казино России в целом
      № 2++. PIN-UP Kz — ПИНАП Казино: Надежное Казино Казахстана Онлайн на реальные деньги по промокоду VINBONUS Лучшее казино в Казахстане в целом.
      № 3. DRIP КАЗИНО— Дрип Казино: Популярное онлайн Казино предлагает хорошие бонусы и фриспины для своих игроков по промокоду BONUSFS Новое Первоклассное казино
      № 4. Starda казино — Старда Казино: Казино с высоким рейтингом среди игроков России и СНГ по промокоду BONUSFS .ТОП Азартных игр в России
      № 5. 1GO CASINO Новинка Бонус Казино 150 % встречай новинку с лучшими игровыми слотами онлайн и выигрывай реальные деньги по промокоду BONUSFS. Самый Высокий - Приветственный бонус
      № 1.  KOMETA казино —  Комета  Казино: Топ 1 Казино онлайн на реальные деньги 2025 без пополнения по промокоду BONUSFS. Отличные Мобильные слоты
      № 2. R7 казино — Р7 Казино: Одно из самых лучших онлайн-Казино с быстрыми выплатами в игровых слотах. Лучший сайт для Азартных игр в целом
      № 3. KENT казино — Кент Казино: Лучшие игровые слоты на деньги и слоты в Казино-онлайн 2025
      MONRO КАЗИНО (Монро Казино ) — Лучшие игровые автоматы с хорошим приветственным бонусом, (Welcome Pack — 325% бонус до 1200 EUR + 100 FS) по промокоду BONUSFS
      IZZI казино: Казино онлайн с хорошей репутацией в России 2024 году (приветственный пакет 100% + 100 FS на депозит по промокоду BONUSFS )
      № 4.  VOLNA казино— Волна Казино: Казино онлайн с мобильной версией и ставками на спорт (игры на деньги).
      2.  LEGZO казино ( ЛЕГЗО Казино ) — Они предоставляют высокий уровень безопасности и большой выбор игр, включая прогрессивные джекпоты с игровыми слотами онлайн на деньги
      FRESH казино - Лучшее Казино с бонусом на депозит в 200% и 100ФС по промокоду BONUSFS
      ROX КАЗИНО - Самое свежее Казино с бонусом 200% по промокоду BONUSFS
      GAMA казино – новое российское онлайн-казино с щедрыми бонусами и слотами на любой вкус. ГАМА казино зеркало доступно каждый день. Забери бонус +250% и 100FS к первому депозиту в GAMA Казино по промокоду BONUSFS !
      Vovan Casino ( Вован Казино онлайн ) — Лидер среди онлайн Казино в России и Снг. Они имеют отличную репутацию и предоставляют многочисленные игровые автоматы и настольные игры. бонус 200%.Фриспины при регистрации
      № 4.  RIOBET Casino — Риобет Казино: Лучшие новое Казино онлайн в 2025
      № 5.  RAMENBET Casino — Раменбет: Казино с лучшими бонусами а также с бездепозитным бонусом 2025
      Лучший список онлайн-казино на реальные деньги в 2025 году
      Мы рады представить вам ТОП-рейтинг онлайн-казино для игры на реальные деньги в 2025 году. Ознакомьтесь с нашим обновленным списком лучших платформ, где вы сможете насладиться захватывающими играми и выгодными предложениями!
      7KCASINO это лучшее казино: ! 2000+ лучших слотов, ! RTP 98+% ! 200% бонус к депозиту ✓ 24/7 поддержка!
      POPERLO Casino Новинка Поперло Казино — На первый депозит игрокам доступен бонус 200% до 10 000 рублей
      1WIN Casino ( Ван вин Казино) — Это одна из самых надежных площадок для азартных игр в России и СНГ. Они предлагают большой выбор слотов, а также живые дилеры для настольных игр и фриспины по промокоду BONUSFS .
      NewRetroCasino — надежное Казино с быстрыми выплатами и высоким уровнем обслуживания Новое Казино с высокими шансами на выигрыш.
      6.VODKA ( Казино Водка ) — Это новое Казино, которое уже завоевало популярность благодаря своему разнообразному выбору игр и щедрым бонусам.
      8. Cryptoboss ( Казино Криптобосс )— Они предлагают широкий выбор игровых автоматов от ведущих провайдеров, а также живые дилеры для настольных игр.
      9. KAKTUZ Casino ( Кактуз Казино ) — Их основное преимущество заключается в том, что они предоставляют возможность делать ставки на спорт вместе с традиционными Казино-играми.
      10. БОЛЛИВУД (Болливуд казино) Проверенные временем слоты с приветственным бонусом 400%+100FS
      11. Goldcasino  (Голд казино) это ваш портал в будущее азартных игр. Новое GOLD Casino официальный сайт - Приветственный Бонус +150% и 2000FS
      12. LEVCASINO (Лев казино)- Лучшие игровые автоматы на реальные деньги
      13. ELDORADO (Эльдорадо казино)- Самый Рейтинговый Сайт для Азартных игр в России и Казахстане
      14. CLUBNIKA (Клубника казино) - Самое выигрышное казино в интернете
      15. CATCASINO(КЭТ казино)- казино в которым реально можно выиграть деньги и вывести их на карточку
      16.DADDY - Регистрация с Бонусом 65000₽ + 150 FS! Заходи и выигрывай в Дадди Казино с бонусом на первый депозит!
      17.LEEBET -казино с бонусом за регистрацию 100 фриспинов.
      18.CAZINO-X- заслужило доверие многочисленных игроков благодаря своему официальному сайту, рабочему зеркалу и популярным слотам
      19.JOYCAZINO - преимуществом Joycasino является наличие мобильной версии сайта и приложений для iOS и Android, что позволяет играть в любимые игры даже в пути
      20.VIPCASINO - VIP Casino – это интернет-казино для Украины, вся информация на сайте подаётся на русском языке
      21.METELITSA - интернет-казино с хорошей репутацией по отзывам
      Надежный список онлайн-казино (Online Casino) на реальные деньги в 2024 - 2025 году.
      Начнем с описания уникальных особенностей каждого из сайтов в нашем списке Топ-10:
      Gama Casino — этот сайт предлагает своим пользователям привлекательную бонусную программу, включающую 300% к депозиту и 100 фриспинов. Уникальной чертой Gama Casino является эксклюзивная коллекция игровых автоматов, а также специальные промокоды, которые добавляют дополнительную ценность к опыту игры.
      LEGZO Casino — сайт, который заслуживает внимания благодаря своей репутации надежного партнера. В 2024 году они укрепляют свои позиции, предоставляя своим клиентам быстрые выплаты и честную игру, что делает их платформу одной из самых доверительных на рынке.
      CAT Casino — привлекает многочисленных пользователей своим впечатляющим бонусом в размере 200% и пакетом из 150 фриспинов. Игроки отмечают широкий выбор слотов от ведущих разработчиков, что значительно повышает увлекательность игрового процесса.
      STARDA Casino — зарекомендовало себя как надежная платформа, предлагающая разнообразные традиционные казино-игры, которые удовлетворяют различные предпочтения игроков. Это делает STARDA Casino привлекательным для широкой аудитории.
      FRESH Casino — получило признание за свою скорость выплат и положительные отзывы от пользователей. Это делает сайт отличным выбором для игроков, которые ценят оперативность и надежность.
      SOL Casino — платформа, придающая особое значение безопасности пользовательских данных. SOL Casino гарантирует комфорт и защиту каждому своему клиенту, что создает атмосферу уверенности и доверия на протяжении всего игрового процесса.
      Актуальность онлайн-казино в 2025 году продолжает расти, и выбор лучших платформ становится всё более важным для игроков.
      С ростом популярности онлайн-казино в 2025 году, этот сегмент индустрии развлечений продолжает набирать обороты благодаря сочетанию доступности и удобства. Главными факторами, способствующими притяжению новых клиентов, являются привлекательные бонусные предложения, ясность игровых правил и оперативная поддержка пользователей.
      Выбор надежного онлайн-казино для игры на реальные деньги требует внимательного подхода. Важно обратить внимание на несколько ключевых аспектов: наличие лицензии, положительные отзывы от игроков, разнообразие игр в каталоге, а также скорость и комфортность проведения финансовых операций.
      Таким образом, топ-10 легальных онлайн-казино 2025 года представляет собой разнообразие платформ, которые предлагают множество услуг для любителей азартных игр на реальные деньги. Эти казино создают безопасную и комфортную игровую среду, соответствуя современным требованиям индустрии развлечений и обеспечивая своим пользователям качественный опыт.
      ТОП НОВЫХ ЛУЧШИХ ОНЛАЙН-КАЗИНО 2025 ГОДА
      Бонусы и программа лояльности
      Бонусы играют важную роль в мире онлайн-казино, предоставляя игрокам различные поощрения и привилегии. Они могут принимать разные формы и варьироваться по количеству, включая приветственные бонусы за регистрацию и дополнительные награды за последующие депозиты. Одним из ключевых аспектов программы лояльности является наличие кешбека, который способствует возвращению части проигранных средств игрокам.
      На платформе онлайн-казино также критически важно наличие большого числа провайдеров и разнообразных игр, что позволяет игрокам находить именно те развлечения, которые им нравятся. Кроме того, удобные способы ввода и вывода средств, а также разумные лимиты на снятие выигрышей имеют огромное значение для общей удовлетворенности игроков.
      Давайте рассмотрим, какие казино вошли в ТОП на начало 2025 года и конец 2024.
      MONRO Casino (225% + 100 фриспинов) — это новое онлайн-казино с быстрыми выплатами, которое впервые вошло в наш рейтинг. Оно уже успело завоевать репутацию лучшего казино для игры на реальные деньги в 2025 году.
      DADDY Casino (200% на первый депозит + 100 фриспинов) занимает второе место. Это новый проект, который привлек внимание благодаря щедрым предложениям и 2000 рублей за регистрацию без депозита.
      DRIP Casino (225% + 325 фри-спинов) находится на третьем месте в нашем рейтинге. Это еще одно новое казино от Royal-Partners, предлагающее игрокам 1000 рублей за регистрацию.
      Gama Casino (425% + 200 фри-спинов) уверенно занимает четвертую позицию. Это казино стало лидером в России и известно своим высококачественным сервисом и масштабными бонусами. промокод BONUSFS
      LEGZO Casino — надежное и проверенное онлайн-казино, замыкающее пятерку лучших казино России в 2024 году.
      Завершает наш список CAT Casino (375% + 150 фри-спинов), которое становится все более популярным среди игроков благодаря своим выгодным предложениям и впечатляющему выбору игр.  промокод BONUSFS
      Таким образом, в 2025 году на игроков ждут многие интересные возможности в мире онлайн-казино. Выбирайте казино по душе и наслаждайтесь увлекательными играми и щедрыми бонусами!
      КАЗИНО ГДЕ ИГРАТЬ НА ДЕНЬГИ ОНЛАЙН В 2025
      Каждый игрок, решивший попробовать себя в онлайн Казино, стремится найти не только увлекательные игры, но и надежную платформу для ставок. Основными критериями выбора являются лицензия, ассортимент игр, бонусы, качество обслуживания клиентов и удобство платежных операций.
      В 2025 году многие онлайн Казино на деньги предлагают обширный выбор слотов, настольных игр, игр с живыми дилерами и других развлечений от ведущих разработчиков игрового софта. Привлекательность таких сайтов усиливается прозрачными и быстрыми финансовыми операциями, а также высоким уровнем защиты личных данных игроков.
      ЛУЧШИЕ САЙТЫ КАЗИНО С ЛИЦЕНЗИЕЙ ДЛЯ ИГРОКОВ
      Лицензия является основным признаком надежности и безопасности казино. Она подтверждает, что платформа регулярно проходит проверки со стороны регулирующих органов, что гарантирует игрокам честность и прозрачность игровых процессов. Для игроков из России и стран СНГ наиболее распространены лицензии, выданные в  Кюрасао, Мальты, Великобритании и других авторитетных юрисдикциях.
      ТОП-10 КАЗИНО НА РЕАЛЬНЫЕ ДЕНЬГИ
      Чтобы упростить ваш выбор и сэкономить время, мы составили список онлайн-казино, на которые стоит обратить внимание в 2025 году:
      1. Казино X - это заведение славится своей обширной коллекцией игр и щедрыми бонусными предложениями.
      2. Банда - привлекает внимание игроков возможностью заработка на реальных ставках и постоянными интересными акциями.
      3. Вавада - предлагает широкий ассортимент слотов и настольных игр, отличающихся высокой графикой и увлекательным игровым процессом.
      4. КЕНТ Casino - располагает лицензией Мальты и предоставляет поддержку своим клиентам круглые сутки.
      5. Joy Casino - интерфейс этого казино отличается интуитивной простотой и удобством для пользователей.
      6. 1ГО Casino - обращает особое внимание на безопасность и приватность своих игроков, что делает его надежным выбором.
      7. КЕНТ Casino - настоящий рай для поклонников слотов и живых игр, предлагающий разнообразные развлечения.
      8. Иззи казино - активно оперирует на российском рынке и предлагает привлекательные условия для своих клиентов.
      9. Водка Casino - это заведение сочетает в себе как традиционные, так и современные игры, создавая уникальную атмосферу.
      10. Эльдорадо Casino - это имя давно зарекомендовало себя в индустрии и предлагает широкий ассортимент игр на любой вкус.
      Эти казино обеспечивают высокий уровень обслуживания и интересные возможности для азартных игроков в 2025 году.
      ВЫБОР ОНЛАЙН КАЗИНО
      При выборе онлайн-казино важно учитывать ваши личные предпочтения, чтобы обеспечить максимально комфортный игровой процесс. Обратите внимание на типы предлагаемых игр, наличие ваших любимых слотов и удобство интерфейса, а также на доступные методы внесения и вывода средств. Все эти факторы играют значительную роль в создании положительного опыта.
      Кроме этого, стоит ознакомиться с рейтингами казино, так как они часто отражают реальные отзывы и впечатления других игроков. Это поможет вам определить, какие заведения заслуживают доверия и имеют хорошую репутацию на рынке.
      В заключение, онлайн-игры в 2025 году открывают перед игроками из России и СНГ множество новых возможностей. Список лучших онлайн-казино позволит вам выбирать только те площадки, которые гарантируют честность и безопасность игрового процесса. Желаем вам удачи в ваших приключениях!
      На этом наш обзор и рейтинг лучших онлайн-казино для игры на реальные деньги подходит к концу. Мы представили ТОП новых казино 2025 года, каждое из которых отличается надежностью, опытом работы на рынке и положительными отзывами со стороны пользователей. Все эти заведения зарекомендовали себя как надежные и с ними не возникало проблем с выплатами!
      НАС НАХОДЯТ
      топ 10 лучших казино
      лучшие казино на 2025
      лучшие казино на реальные деньги
      лучшие сайты онлайн казино
      топ 10 казино на деньги
      top casino online
      рейтинг лучших онлайн казино
      рейтинг лучших казино
      10 лучших казино онлайн
      популярные онлайн казино
      top 10 best online casinos
      best online casino for real money
      top 10 online casino sites
      топ 10 рейтинг лучших казино
      Проверенные онлайн казино с выводом денег
      Игры на деньги с выводом на карту без вложений
      Казино онлайн Росии
      Онлайн казино с выводом денег на карту
      Онлайн игры на деньги с выводом на карту
      лучшие онлайн-казино
      Онлайн казино без верификации
      топ казино в россии онлайн
      обзор и рейтинг казино
      1000 рублей за регистрацию вывод сразу без вложений в казино
      самые популярные казино в мире
      какое онлайн казино на сегодняшний день является самым честным
      официальные казино в россии
      рейтинг казино на реальные деньги
      казино в котором реально можно выиграть деньги и вывести
      вавада казино официальный сайт
      игровые автоматы где реально можно выиграть и вывести деньги
      в каком казино реально выиграть и вывести деньги
      какие казино реально выплачивают выигрыши в россии отзывы
      казино в котором реально можно выиграть деньги и вывести скачать
      казино в которых реально можно выиграть деньги и вывести их на карточку
      онлайн казино без вложений с выводом денег
      реально ли выиграть в казино вулкан в интернете отзывы проверенные
      бонусы казино без депозита
      бонусы казино бездеп
      в каком казино дают деньги за регистрацию без депозита
      бонусы казино за регистрацию
      бонусы без отыгрыша за регистрацию
      покупные бонусы в казино
      Бездепозитные бонусы казино
      Свежие бездепозитные бонусы казино за регистрацию
      Все казино с бонусом без депозита с выводом
      Бездепозитный бонус за простую регистрацию сразу на счет с выводом
      Лучшие бездепозитные бонусы казино
      1000 за регистрацию без депозита казино
      Казино с бонусом за регистрацию без депозита
      Бездепозитный бонус за регистрацию по номеру
    2. В мире азартных игр онлайн-казино заняли прочное место, предлагая широкий спектр развлечений для любителей азарта. К 2025 году рынок онлайн-казино в России и странах СНГ значительно развился, представив игрокам более совершенные и безопасные платформы. Среди многообразия сайтов особенно выделяются те, которые не только предлагают впечатляющий ассортимент игр, но и гарантируют честность проведения игр и защиту данных пользователей.
      Casino Bollywood. 100% + 35FS + 35FS. 77% + 35FS. Все фриспины в игровом слоте Rainbow Gold.
      Казино Лев — фриспины, бездепы · 100% бонус для новичков до 20 000 + 50 FS · Бонус до 20 000 · Бонус до 150 FS
      Казино Эльдорадо. Попурярные бонусы: за депозит от +100% и бездепозитный бонус за регистрацию.
      Clubnika Casino · Первый Депозит: 150% бонус при пополнении от 300 или 125% до 10 000 при пополнении от 100. · Второй Депозит: 75% бонус
      Казино Голд » Переходи на оригинальный сайт Gold Casino и получай бонус новым игрокам 200FS + 777% при регистрации
      IRWIN Casino новый проект Welcome pack для игроков 225% + до 400FS Высокий RTP в слотах (96,6%)
      Gizbo Casino.  Первый бонус 150% до 30 000
      Kometa Casino онлайн-казино с уникальными играми и щедрыми бонусами: получите +255% и 500 фриспинов при регистрации
      LEX casino Welcome Package Ваши первые подарки Начните игру с побед ДО 225% И ДО 400 FS Первый депозит 150% Второй депозитДо 400 FS Третий депозит 75%
      R7 casino новое крито-казино в России. Приветственный бонус +300% и 225 фриспинов уже ждут новых игроков!
      1GoCasino Welcome Package225% + до 400 FS На первый депозит Стартуй с бонусами без условий по Max Win!
      CASINO ‎KENT ‎ бонусы Сумма депозита Бонус Максимальный бонус На 1-й депозит от 500 RUB 50% + 50 FS15 000 RUB На 1-й депозит от 2000 RUB 100% + 75 FS30 000 RUB На 1-й депозит от 5000 RUB150% + 100 FS 40 000 RUB
      GAMA‏ ‎CASINO(Гама‏ ‎Казино)‏ ‎— ‎Gama ‎casino: ‎казино‏ ‎онлайн ‎с‏ ‎хорошей ‎репутацией‏ ‎в‏ ‎России ‎дарит ‎приветственный‏ ‎пакет ‎200%‏ ‎+ ‎200 ‎fs ‎на‏ ‎депозит
      VOVAN‏ ‎CASINO ( Вован‏ ‎казино)‏ ‎— ‎Другой ‎лидер ‎среди‏ ‎онлайн ‎казино‏ ‎в ‎России.‏ ‎Они‏ ‎имеют ‎отличную ‎репутацию‏ ‎и ‎предоставляют‏ ‎многочисленные ‎игровые ‎автоматы ‎и‏ ‎настольные‏ ‎игры.‏ ‎бонус ‎100%
      1. VAVADA ( Вавада‏ ‎) ‎–‏ ‎Это ‎одно‏ ‎из ‎самых ‎популярных‏ ‎онлайн‏ ‎казино‏ ‎России. ‎Они‏ ‎предлагают ‎широкий‏ ‎выбор ‎игр,‏ ‎высокие‏ ‎бонусы ‎и‏ ‎быстрые ‎выплаты. ‎бонус ‎100% ‎+‏ ‎100 ‎фриспинов
      2. VODKA‏ ‎CASINO ( казино ‎Водка) ‎–‏ ‎Новый ‎проект‏ ‎для‏ ‎самых‏ ‎азартных ‎игроков‏ ‎Бонус ‎100% ‎на ‎первый‏ ‎депозит ‎каждому‏ ‎новому‏ ‎игроку
      3. Poperlo Casino  (Поперло Казино ‎— ‎Известный‏ ‎своими ‎высокими ‎коэффициентами ‎выплат‏ ‎и‏ ‎качественными‏ ‎слотами
      4. RIOBET‏ ‎  Давно‏ ‎зарекомендовавший‏ ‎себя ‎бренд‏ ‎на ‎рынке ‎онлайн‏ ‎казино ‎России‏ ‎–‏ ‎RIOBET‏ ‎ ( Риобет ‎).‏ ‎Здесь ‎предлагается ‎широкий ‎выбор‏ ‎игровых ‎автоматов‏ ‎и‏ ‎других‏ ‎азартных ‎игр, ‎включая ‎блэкджек‏ ‎и ‎рулетку.
      5. Казино‏ ‎MONRO ‎ ( Монро ‎казино ‎)–‏ ‎это ‎онлайн-казино‏ ‎с ‎лицензией,‏ ‎которое‏ ‎предлагает ‎большой ‎выбор‏ ‎игровых ‎автоматов‏ ‎и ‎живые ‎дилерские ‎игры.‏ ‎MONRO‏ ‎Casino‏ ‎с ‎привлекательными‏ ‎быстрыми ‎выплатами‏ ‎и ‎бонусом‏ ‎в ‎225% ‎+‏ ‎400ФС
      6. PLAY‏ ‎FORTUNA ( Плей‏ ‎Фортуна ‎)‏ ‎– ‎Они‏ ‎предлагают ‎большой‏ ‎выбор‏ ‎слотов ‎от‏ ‎ведущих ‎провайдеров ‎и ‎щедрые ‎бонусы‏ ‎для ‎новых‏ ‎игроков.
      7. BOOI‏ ‎CASINO ( Буи ‎казино ‎) ‎–‏ ‎Это ‎казино‏ ‎с ‎хорошей ‎репутацией, ‎которое‏ ‎предоставляет‏ ‎множество ‎разнообразных ‎игровых‏ ‎опций ‎и‏ ‎высокий ‎уровень ‎безопасности. ‎200%‏ ‎бонусом
      8. POKERDOM( Покердом‏ ‎) ‎– ‎Это ‎казино‏ ‎предлагает‏ ‎большой‏ ‎выбор ‎игр‏ ‎и ‎регулярные‏ ‎турниры ‎для‏ ‎игроков ‎бонус ‎150%.‏ ‎Покер
      9. Twin‏ ‎Casino( Твин‏ ‎Казино ‎)‏ ‎это ‎казино,‏ ‎которое ‎предлагает‏ ‎большой‏ ‎бонус ‎на‏ ‎первые ‎депозиты, ‎Успей ‎забрать ‎все‏ ‎до ‎300%
      10. JOY‏ ‎CASINOСамое‏ ‎дающее ‎в ‎октябре ‎онлайн-казино‏ ‎на ‎реальные‏ ‎деньги.
      11. Starda ‎casino: казино ‎онлайн ‎с‏ ‎хорошей‏ ‎репутацией ‎в ‎россии‏ ‎2023 ‎году‏ ‎(приветственный ‎пакет ‎200% ‎+‏ ‎200‏ ‎fs‏ ‎на ‎депозит).‏ ‎
      2. GONZO ‎CASINO (Гонзо ‎казино)‏ ‎— ‎Другой‏ ‎лидер‏ ‎среди‏ ‎онлайн ‎казино‏ ‎в ‎России. ‎Они ‎имеют‏ ‎отличную ‎репутацию‏ ‎и‏ ‎предоставляют‏ ‎многочисленные ‎игровые ‎автоматы ‎и‏ ‎настольные ‎игры.‏ ‎бонус ‎100%‏ ‎
      3. KAKTUZ‏ ‎CASINO(Кактуз ‎Казино) ‎—‏ ‎Это ‎одна‏ ‎из ‎самых ‎надежных ‎площадок‏ ‎для‏ ‎азартных‏ ‎игр ‎в‏ ‎России. ‎Они‏ ‎предлагают ‎большой‏ ‎выбор ‎слотов, ‎а‏ ‎также‏ ‎живые‏ ‎дилеры ‎для‏ ‎настольных ‎игр.
      7. КАЗИНО ‎DADDY(Дедди ‎Казино)‏ ‎—‏ ‎новый ‎проект ‎от‏ ‎котов ‎с‏ ‎бонусом ‎в ‎200% ‎на‏ ‎первый‏ ‎депозит
      8. LEON‏ ‎CASINO(Леон ‎Казино)‏ ‎— ‎Они ‎предлагают‏ ‎широкий ‎выбор‏ ‎игр‏ ‎и‏ ‎быстрые ‎выплаты,‏ ‎а ‎также ‎доступны ‎на‏ ‎различных ‎устройствах.
      9.GAMA‏ ‎CASINO(Гама‏ ‎Казино)‏ ‎— ‎Gama ‎casino: ‎казино‏ ‎онлайн ‎с‏ ‎хорошей ‎репутацией‏ ‎в‏ ‎России ‎дарит ‎приветственный‏ ‎пакет ‎200%‏ ‎+ ‎200 ‎fs ‎на‏ ‎депозит
      10. CAT‏ ‎CASINO(Кэт‏ ‎Казино) ‎—‏ ‎соблазняет ‎игроков‏ ‎выгодным ‎предложением‏ ‎375%+150 ‎ФРИСПИНОВ ‎на‏ ‎игру‏ ‎на‏ ‎реальные ‎деньги
      11. IZZI‏ ‎CASINO(Иззи ‎Казино)‏ ‎— ‎Их‏ ‎основное‏ ‎преимущество ‎заключается‏ ‎в ‎том, ‎что ‎они ‎предоставляют‏ ‎возможность ‎делать‏ ‎ставки‏ ‎в ‎криптовалютах.
      12. NEW ‎RETRO ‎CASINO‏ ‎(Казино ‎Сукааа)‏ ‎— ‎Они ‎известны ‎своим‏ ‎богатым‏ ‎выбором ‎слотов ‎и‏ ‎быстрыми ‎выплатами.
      13. DRIP‏ ‎CASINO(Дрип ‎Казино) ‎— ‎Они‏ ‎предоставляют‏ ‎широкий‏ ‎выбор ‎игровых‏ ‎автоматов ‎и ‎настольных‏ ‎игр, ‎а‏ ‎также‏ ‎привлекательные‏ ‎бонусы.
      14.VOLNA ‎(Казино‏ ‎Волна) ‎— ‎Это ‎новое‏ ‎казино, ‎которое‏ ‎уже‏ ‎завоевало‏ ‎популярность ‎благодаря ‎своему ‎разнообразному‏ ‎выбору ‎игр‏ ‎и ‎щедрым‏ ‎бонусам.
      16. 1Xslots ‎(Казино‏ ‎1Икслотс)– ‎Они‏ ‎предлагают ‎широкий‏ ‎выбор ‎игровых ‎автоматов‏ ‎от‏ ‎ведущих‏ ‎провайдеров, ‎а‏ ‎также ‎живые‏ ‎дилеры ‎для‏ ‎настольных‏ ‎игр.
      17. SPINBETTER ‎(Спинбеттер‏ ‎Казино) ‎— ‎Их ‎основное ‎преимущество‏ ‎заключается ‎в‏ ‎том,‏ ‎что ‎они ‎предоставляют ‎возможность‏ ‎делать ‎ставки‏ ‎на ‎спорт ‎вместе ‎с‏ ‎традиционными‏ ‎казино-играми.
      20. JET ‎CASINO(Джет ‎Казино)‏ ‎— ‎Они‏ ‎предоставляют ‎высокий ‎уровень ‎безопасности‏ ‎и‏ ‎большой‏ ‎выбор ‎игр,‏ ‎включая ‎прогрессивные ‎джекпоты.
      Выбор надежного онлайн-казино — задача не из легких, учитывая многообразие предложений на рынке. В этой статье мы сосредоточимся на 10+ проверенных сайтах онлайн-казино для игроков из РФ и СНГ, которые выделяются своей надежностью, качеством обслуживания и щедрыми бонусами. Мы провели тщательный анализ, чтобы вы могли насладиться игрой, не беспокоясь о своей безопасности и справедливости игрового процесса.
      Введение в мир онлайн казино 2025
      К 2025 году мир онлайн казино претерпел революционные изменения, существенно повысившие качество и доступность игрового процесса для пользователей из РФ и стран СНГ. Технологический прогресс и повышенные требования к безопасности обеспечили появление передовых платформ, где геймеры могут погрузиться в мир азарта, наслаждаясь широким спектром игр: от классических слотов до инновационных VR развлечений. За последние годы в этой области произошло множество изменений, начиная от методов обработки платежей, включая криптовалюты для анонимности и безопасности транзакций, и заканчивая использованием искусственного интеллекта для персонализации игрового процесса и улучшения поддержки пользователей. В этом динамично развивающемся мире выбор надежного казино становится ключевой задачей для любителей азартных игр. Список 10+ подтвержденных сайтов 2025 года в России и СНГ представлен в этой статье, чтобы обеспечить читателю исключительно положительный игровой опыт на прозрачных и честных платформах.
      Тенденции и инновации в индустрии азартных игр
      В 2025 году индустрия азартных игр претерпела значительные изменения, оказавшие влияние на рейтинг лучших казино онлайн в России и СНГ. Среди ключевых трендов особенно выделяются внедрение искусственного интеллекта (ИИ) и расширенной реальности (AR), что сделало онлайн-казино более интерактивными и захватывающими. ИИ используется для персонализации игрового процесса, предлагая пользователям игры, которые идеально соответствуют их предпочтениям. Также ИИ помогает в обеспечении безопасности и справедливости игр, анализируя поведение игроков и отслеживая подозрительные действия.
      Внедрение технологий AR создает полностью погружаемые виртуальные казино, позволяя игрокам испытать атмосферу реального казино из комфорта своего дома. Кроме того, увеличение популярности криптовалют привело к появлению большего числа казино, принимающих биткойны и другие цифровые валюты, обеспечивая анонимность и безопасность транзакций.
      Ещё одной значительной инновацией стало появление игровых платформ, работающих на основе блокчейн-технологий, гарантирующих прозрачность и справедливость всех игровых операций. Эти платформы предлагают пользователям новый уровень доверия благодаря неизменным записям о всех ставках и выплатах.
      Таким образом, индустрия азартных игр в 2025 году предстает взволнованной инновациями, которые делают игровой процесс не только увлекательнее и реалистичнее, но и более безопасным и справедливым для игроков из РФ и СНГ.
      Топ-10 проверенных онлайн казино в РФ и СНГ
      В сфере онлайн-гемблинга внимание стоит уделять только проверенным площадкам, гарантирующим честную игру, быстрые выплаты и качественный сервис. Список топ-10 онлайн казино в РФ и странах СНГ в 2025 году объединяет платформы с безупречной репутацией:
      1. **Casino Empire**: Обеспечивает превосходный выбор игр от ведущих разработчиков, включая живые дилеры и VR-игры, а также высокие стандарты безопасности. 2. **Royal Wins**: Известно своими щедрыми бонусами для новичков и постоянных игроков, а также мгновенными выплатами через широкий спектр платежных систем. 3. **Gold Fortune Casino**: Предлагает уникальную программу лояльности, эксклюзивные игры, и поддержку криптовалют для совершения ставок и вывода выигрышей. 4. **Prestige Spin**: Отличается внимателем к деталям интерфейсом, обширным ассортиментом игр и профессиональной поддержкой клиентов на русском языке. 5. **Luxe Casino**: Имеет лицензию от известного регулятора и славится своим VIP-обслуживанием, включая персонализированные бонусы и призы. 6. **Cyber Spin**: Предоставляет высокотехнологичный игровой опыт с использованием последних инноваций в области онлайн слотов и таблиц лидеров. 7. **NovaBet**: Выделяется на фоне конкурентов своим безопасным и прозрачным подходом к игре, а также быстрым верификационным процессом. 8. **UltraPlay**: Известно своими турнирами с большими призовыми фондами и возможностью играть на мобильных устройствах без ущерба для качества. 9. **Eclipse Casino**: Гарантирует абсолютную конфиденциальность и защиту данных игроков, наряду с эксклюзивными игровыми автоматами. 10. **BetMaster**: Предлагает широкий выбор спортивных ставок и казино игр с живыми дилерами, поддерживая при этом многочисленные платежные опции.
      Эти онлайн казино были отобраны на основе отзывов пользователей, независимых аудитов, безопасности и предложенного разнообразия игр. Они представляют собой лучший выбор для игроков из РФ и СНГ в 2025 году.
      Критерии выбора надежного игрового сайта
      Выбор надежного онлайн казино — ключевой момент для безопасной и увлекательной игры. В 2025 году, среди множества доступных платформ, особо выделяются те, что соответствуют строгим критериям. Лицензирование является первым и основным фактором; лицензия от надежного регулятора, как UKGC или MGA, удостоверяет законность и прозрачность работы казино. Вторым по важности является наличие сертифицированного генератора случайных чисел (RNG), гарантирующего честность игрового процесса.
      Безопасность и защита данных также играют ключевую роль. Ведущие платформы применяют передовые технологии шифрования, такие как SSL, для защиты личной информации и финансовых транзакций пользователей. В дополнение, качественная клиентская поддержка, доступная 24/7, обеспечивает надежную помощь в любой ситуации.
      Не менее важен и выбор игр; лучшие казино предлагают широкий ассортимент от ведущих разработчиков софта. Помимо этого, привлекательные бонусы и программы лояльности справедливыми условиями ставок способствуют улучшению игрового опыта.
      В сумме, учитывая вышеупомянутые факторы, игроки могут без труда выбрать надежное казино, гарантирующее безопасную и прибыльную игру в 2025 году.
      Безопасность и ответственная игра в онлайн казино 2025
      В сфере онлайн гемблинга 2025 года, безопасность пользователей и принципы ответственной игры заняли центральное место. Ведущие операторы казино, представленные в РФ и СНГ, демонстрируют высокий уровень ответственности, используя передовые технологии шифрования для защиты личных и финансовых данных своих клиентов.
      Также, в целях предотвращения зависимости от азартных игр, внедрены инструменты самоограничения. Игроки могут самостоятельно устанавливать пределы ставок, временные рамки игры и даже запросить самоисключение на определенный период. Системы распознавания законов поведения игроков анализируют активность на предмет потенциальной игровой зависимости и предлагают ресурсы помощи.
      К тому же, лицензионные казино обязаны следовать строгим правилам регулирующих органов, что еще больше подтверждает их приверженность обеспечению безопасной игровой среды. Эти меры, комбинированные с обучением пользователей основам ответственной игры, направлены на создание здоровой и безопасной атмосферы в онлайн-казино 2025 года, где игроки могут наслаждаться азартными играми без негативных последствий для себя и окружающих.
    ЗАХАР123654
    ЗАХАР123654
  • Ремонт и обслуживание Jeep
    • Yurgen15
      Yurgen15  »  up6
      · 3 ответа
    • Jeep Spot
      Jeep Spot  »  AG
      Всем привет! 👋
    • ROKO
      ROKO  »  Лунный пчел
