Р0463 трындец
Скорость 120 на м4 въехал в лужу и заглох. Ошибка р0463 и не заводится. Не гидроудар!!! Но стрелка топлива легла на 0 и походу не качает бенз. У кого была похожая проблема и как лечится?
Нашел на забугорном сайте, может поможет инфа
here is the trouble shooting for that cose from the FSM
1 Ignition on, engine not running.
With the DRBIII
t, read DTCs and record the related Freeze Frame data.
With the DRBIII
t, read the Fuel Level Sensor voltage.
Is the Fuel Level Sensor voltage above 4.9 volts?
All
Yes
! Go To 2
No
! Refer to the INTERMITTENT CONDITION Symptom (Diagnostic
Procedure).
Perform POWERTRAIN VERIFICATION TEST VER - 2.
2 Turn the ignition off.
Disconnect the Fuel Pump Module electrical harness connector.
Connect a jumper wire between the (K226) Fuel Level Sensor Signal circuit and the
(K4) Sensor ground circuit at the Fuel Pump Module harness connector.
With the DRBIII
Did the Fuel Level Sensor voltage change from above 4.8 volts to below 0.4 of a volt?
All
Yes
! Replace the Fuel Level Sensor.
No
! Go To 3
NOTE: Remove the jumper wire before continuing.TEST ACTION APPLICABILITY
3 Turn the ignition off.
Disconnect the PCM harness connectors.
Measure the voltage on the (K226) Fuel Sensor Signal circuit at the Fuel Pump
harness connector.
Is the voltage above 10.0 volts?
All
Yes
! Repair the short to voltage in the (K226) Fuel Level Sensor Signal
circuit.
No
! Go To 4
4 Turn the ignition off.
Note: Check connectors - It is critical that the connector is free from any
signs of corrosion or deformities - Clean/repair as necessary.
Measure the resistance of the (K226) Fuel Level Sensor Signal circuit from the PCM
harness connector to the Fuel Pump Module harness connector.
Is the resistance below 5.0 ohms?
All
Yes
! Go To 5
No
! Repair the open in the (K226) Fuel Level Sensor Signal circuit.
5 Measure the resistance of the (K4) Sensor ground circuit from the PCM harness
All
Yes
! Go To 6
No
! Repair the open in the (K4) Sensor ground circuit.
NOTE: Before continuing, check the PCM harness connectors for corrosion,
damage, or terminal push out. Repair as necessary.
Using the schematics as a guide, inspect the wire harness and connectors. Pay
particular attention to all Power and Ground circuits.
If there are no possible causes remaining, view repair.
All
Repair
Replace and program the Powertrain Control Module per Service
Information.
Смотри разъем над задним мостом в районе топливного фильтра. Может его напором разъединило или проводку оорвало.
@origin,ОК, вполне возможно
"не заводится" разделяется на 2 категории:
1.стартер крутит коленвал с нормальными оборотами
2.стартер крутит коленвал медленно или не крутит совсем
Трындец в какой категории?:)
Сделай поиск по своему коду и запостай описание, я поиск за тебя делать не буду.
Парни, чем парить то? 2 варианта при крутящем стартере:1 давление в рампе,2 искра. А дальше :насос, дкв.
Изменено пользователем Рыбак
так и получилось что разъём разошёлся ))
стопор сломан поставил хомут
Всем спасибо! Проблема решена
@car5car, Вот любишь ты всё усложнять, явно в автосервисе работаешь.  :D (без обид)
@Mak s,
Ну вот и славно) Мне на одном из Фестов в топливный фильтр бревнышко прилетело, тоже знатно его раскурочило. С тех пор там прижилась защита из стали трешки. Закрывает и разъем, и фильтр, от вот таких напастей.
  • Ник77
  • JefFly
  • Mira_beta
  • ЯР_
  • Prohor 2010
  • Poland
  • Olet
  • shon73
  • Vlad&Mir Aс
  • Lih0y
  • iverson13
    • 22 Комментария
    • 36055 Просмотров
    • 29 Комментариев
    • 202720 Просмотров
    • 445058 Просмотров
