Всем привет хочю купить сканер обд2 с возможностью диагностики систем абс желательно с руским интерфейсом но пока таких не видел.. бюджет до 12000р присматриваюсь к Innova 3160 описании поддержка обд2 и возможность диагностигки абс и также заманчива Innova 3140 он судя из описания читает всех джипов с 1981 года до 1995 по старому протоколу и с 1996 года и выше по обд2 но у него нет возможности диагностики абс вот ниже описание по Innova 3140
Может кто-нибудь что нибудь посоветует?
Features and Benefits
Provides SAE enhanced Live Data - views, records, and plays back live PCM data streams
Designed to retrieve diagnostic codes in all OBD2 (1996 and newer) and some of the most popular OBD1
(1981 to 1995) vehicles
OBD1 (82-95) Coverage GM, Ford, Chrysler/Jeep and Toyota/Lexus
Communicates with all OBD 2 protocols: C.A.N. (Controller Area Network), ISO 9141, J1850PWM,
J1850VPW, KWP 2000 ISO 14230-4
Displays Freeze Frame Data
The Equus line of scan tools provide the most diagnostic data and power for the money than any other line of scan
tools! It's patented "All-in-One" display shows 25 vital pieces of information at one time, and all within 15 seconds.
The 3140 can diagnose all OBD II compliant vehicle and most OBD I vehicles as well. This feature-packed tool and
software kit is designed to meet the needs of professional technicians who desire quick and easy access to
diagnostic data essentials for a wide range of vehicles. Features unique patented all-in-one screen display and
LED display for quick emissions check. Includes Spanish and French Interface and Definitions (selected by a menu
command). Retrieves OBD2 DTCs: Generic Codes (P0, P2, P3, and U0 B0, and C0) / Manufacturer Specific Codes
(P1, P3, and U1). Unit can be flash updated with a standard Windows® PC (OBD-PC Link™ software required /
included with tool). Memory / Battery backup for off-car review and analysis.
OBD1 Coverage: General Motors - 1982 to 1993 and some 1994 to 1995 models excludes Saturn vehicles; Ford,
Lincoln, Mercury - 1983 to 1995 models with EEC-IV Systems
Performs: KOEO, KOER, Timing Check, Cylinder Balance Test, Output State Test, Wiggle Test; Toyota / Lexus -
1991 to 1995.
Most models Chrysler / Dodge / Plymouth/Jeep - 1984 to 1995. Diesel trucks 1992-1995
