выбор OBD2 Cканера
Всем привет хочю купить сканер обд2 с возможностью диагностики систем абс желательно с руским интерфейсом но пока таких не видел.. бюджет до 12000р присматриваюсь к Innova 3160 описании поддержка обд2 и возможность диагностигки абс и также заманчива Innova 3140 он судя из описания читает всех джипов с 1981 года до 1995 по старому протоколу и с 1996 года и выше по обд2 но у него нет возможности диагностики абс вот ниже описание по Innova 3140
Может кто-нибудь что нибудь посоветует?
Features and Benefits
Provides SAE enhanced Live Data - views, records, and plays back live PCM data streams
Designed to retrieve diagnostic codes in all OBD2 (1996 and newer) and some of the most popular OBD1
(1981 to 1995) vehicles
OBD1 (82-95) Coverage GM, Ford, Chrysler/Jeep and Toyota/Lexus
Communicates with all OBD 2 protocols: C.A.N. (Controller Area Network), ISO 9141, J1850PWM,
J1850VPW, KWP 2000 ISO 14230-4
Displays Freeze Frame Data
The Equus line of scan tools provide the most diagnostic data and power for the money than any other line of scan
tools! It's patented "All-in-One" display shows 25 vital pieces of information at one time, and all within 15 seconds.
The 3140 can diagnose all OBD II compliant vehicle and most OBD I vehicles as well. This feature-packed tool and
software kit is designed to meet the needs of professional technicians who desire quick and easy access to
diagnostic data essentials for a wide range of vehicles. Features unique patented all-in-one screen display and
LED display for quick emissions check. Includes Spanish and French Interface and Definitions (selected by a menu
command). Retrieves OBD2 DTCs: Generic Codes (P0, P2, P3, and U0 B0, and C0) / Manufacturer Specific Codes
(P1, P3, and U1). Unit can be flash updated with a standard Windows® PC (OBD-PC Link™ software required /
included with tool). Memory / Battery backup for off-car review and analysis.
OBD1 Coverage: General Motors - 1982 to 1993 and some 1994 to 1995 models excludes Saturn vehicles; Ford,
Lincoln, Mercury - 1983 to 1995 models with EEC-IV Systems
Performs: KOEO, KOER, Timing Check, Cylinder Balance Test, Output State Test, Wiggle Test; Toyota / Lexus -
1991 to 1995.
Most models Chrysler / Dodge / Plymouth/Jeep - 1984 to 1995. Diesel trucks 1992-1995
  • Ответы 98
  • Просмотры 61,8k
  • @*AXL*, сканмастер
  • надо правильно установить программу, тогда всё работает. Смотри инструкцию по правильной установке проги. Scanmaster-ELM:   1. Распаковать архив scanmaster_elm_1.7.rar. 2. Установить ScanMasterELM
WH 3.0 CRD елм327 читает без проблем
подниму тему, может кто знает что под гч Z-ку идет,какая прога и кто что юзал
Рестайл - любой к-лайн адаптер + любая универсальная прога. К примеру, элм + сканмастер.
елм-ка у мну есть но только она не видет абс,да и много чего не видет
Остальное видится только дилерским оборудованием.
понятно,но оно стоит как космолет :crazy::blink:
Диагностика у дилера стоит дешевле.
это точно подмечено
  • 6 месяцев спустя...
Подключил программу ScanMaster-ELM с помощью ELM 327 все что эта прога смогла показать.
http://hkar.ru/udhv
http://hkar.ru/udhw
http://hkar.ru/udhx
Изменено пользователем EvgeniyTV
У меня ЕЛМка в сканмастере видит намного больше. За DRB обращаюсь только по вопросам SRS.
@Поручик Ржевский, При подключении какой протокол связи использовать?  Нужно проверить работоспособность датчиков температуры. Обороты 1500.
А я как- то не обращал внимания, в настройках стоит "автовыбор", там целая пачка. Но вот вчера сканил оверленд 2007года, дизель, и там протокол с поддержкой CAN, это точно помню. А на моем старом KJ вроде 1890.
Изменено пользователем Поручик Ржевский
http://elm327.su/52-jeep.html Описание протоколов подключения.
Купил себе Launch iDiag для андроида.
Все читает. Активировал закрытие замков в движении. Глубоко еще не лазил все на Инглишь.
Расстроило, что не работает тест равномерности цилиндров, тест компресии и еще какой то RPM тест ;(
Сколько стоит Launch iDiag?
4-5т. За 4 сказали ждите, скоро будут. За 5 было рядом с домом, там и взял.
Далее или лицензия по маркам, по 66$, или по 300р за марку на Juste. Ессно выбрал второй вариант ;)
Изменено пользователем BerkutMsk
Я за год владения, с учетом потери двух комплектов чипованных ключей последовательно, за несколько встреч с DRB ещё пятерку не потратил. А тут ещё андроидное устройство надо докупить... ХЗ, господа, ХЗ.
Смартфон то был, к нему и покупал. На IPhone такой тоже есть.
К тому же он универсален. И себе ошибки посмотреть, отцу, жене, приятелям.
@BerkutMsk,  Я вот тоже думаю чего взять. Меня интересует датчики парковки, он их видит?
Сам блок парктроников точно видит. Датчики на память не помню, надо проверять.
@BerkutMsk, Уже хорошо. Меня просто интересует, может ли он определять, когда один из датчиков сдох?
Если сдохнет один любой, то ошибка будет, почти уверен.
Далее если в блоке заложено (скорее всего) определять какой именно датчик чудит, то выдаст код.
Далее, Лаунч либо тупо код даст, либо укажет его расшифровку.
Вообще тестить надо.
На WK хорошо совтина работает, а на MB W211 02г, сама менюшка кривая, хрен кнопки нажмешь. Может если на планшете, то ровная будет.
У Вас датчик сдох какой то?
@BerkutMsk,   Пару раз уже было такое. Не охота каждый раз отдавать за диагностику. Я пытаюсь до чего могу добраться сам чинить, вот на это случай хочу завести. Хочу найти чтоб побольше читала именно дизельную машинку.
я позавчера ездил на диагностику (ошибки по абс посмотреть). У мужичка былприбор, который считал все, говорит название triscan, мол они и дешевые и видят весь джип. Никто не сталкивался?
По использованию ELM 327 и Андроид
@Creoman,  Надо будет поинтересоваться про такой сканер.
Launch, почему.
Один из лучших проф мультимарочников. Jeep мой читает. Если когда то авто другое будет, скорее всего и его читать будет.
В общем мой выбор - Лаунч.
@BerkutMsk,Не будет-ли любезен, достопочтимый джин... Подсказочку необходимо, что такое Juste? Как устанавливать программулину. Уточнить можно ещё, как точно называется моделька лаунча?
Изменено пользователем Motoborg
Ну да.тоже интересно
Приобрел сей девайс у китаезов,спланшетом соединяется,а вот с авто нет,наверное брак,цена 280рупий.post-23749-0-45036800-1408265080_thumb.jpg
  • sewerok
  • Voldemarych
  • Владимир 4х4
  • Wurik
    • 22 Записи
    • 22 Комментария
    • 30941 Просмотр
    Привет, однокклубники!
    Долгое время на американском рынке и в нашем сообществе велись споры: вернет ли Stellantis старый добрый 5.7L V8 HEMI на свежие поколения Jeep Grand Cherokee? Чуда не произошло — индустрия заставила легенду уйти на покой. Однако взамен инженеры выкатили агрегат, который заставляет по-новому взглянуть на динамику современного SUV. Встречайте — рядный шестицилиндровый двигатель 3.0L Hurricane Twin-Turbo.
    Давайте разберем по косточкам, что это за зверь, почему инженерам пришлось попотеть, чтобы «запихнуть» его под капот Grand Cherokee WL, и чего нам ждать в плане надежности и тюнинга.
    Технический базис: Что такое Hurricane I6?
    В отличие от классических V-образных «шестерок» (вроде нашего привычного Pentastar 3.6), Hurricane — это рядный мотор (Inline-6). Из курса физики и мотористики мы знаем: рядная шестерка обладает идеальной естественной сбалансированностью. Здесь нет вибраций, требующих тяжелых балансировочных валов. Мотор работает плавно, «как электромотор», но при этом обладает взрывным характером благодаря двум малоинерционным турбинам.
    Для Grand Cherokee заявлена модификация Standard Output (S/O). Не спешите расстраиваться, что это не High Output на 540 сил от Wagoneer: базовых цифр «Урагана» хватает за глаза.
    Сухие цифры для сравнения:
    • Мощность: 420 л.с. (против 357–360 л.с. у старого 5.7 HEMI).
    • Крутящий момент: 634–636 Нм доступен уже с 3500 об/мин (у HEMI было 529 Нм при более высоких оборотах).
    • Трансмиссия: Проверенный и усиленный 8-ступенчатый автомат ZF (TorqueFlite 8).
    Инженерная драма: Как его уместили?
    Долгое время официальные лица Jeep заявляли, что Hurricane физически не помещается под капот текущего поколения Grand Cherokee WL. Рядный шестицилиндровый мотор очень длинный, и моторный отсек «Гранда» требовал серьезной компоновочной хирургии. [8, 9]
    Однако на закрытых инженерных тестах (SRT Day) инженеры продемонстрировали прототип Grand Cherokee с этим мотором и электрическим компрессором eBoost, доказав скептикам — если перекомпоновать радиаторы и навесное, то I6 встает как родной! В итоге к 2028 модельному году этот мотор официально расширяет гамму Grand Cherokee.
    Плюсы для джипера
    1. Тяга на низах: Две турбины с электронным управлением вестгейтами практически полностью убирают турбояму. Плотный подхват начинается уже с 2300 об/мин. На бездорожье и в горах это компенсирует отсутствие огромного объема V8.
    2. Возврат буксировочных возможностей: С уходом V8 владельцы Grand Cherokee жаловались на снижение массы прицепа. Hurricane возвращает «Гранду» былую славу — буксировочная способность вырастает, позволяя без труда таскать тяжелые катера, автодома и прицепы.
    3. Расход топлива: На трассе благодаря современной системе непосредственного впрыска и умному управлению фазами двигатель может укладываться в адекватные 10–11 литров на сотню (около 24 MPG), что для 420-сильного полноприводного внедорожника — отличный результат.
    Обратная сторона медали: Технологические сложности
    Мы в JEEP4X4CLUB ценим машины за ремонтопригодность. Hurricane — это высокотехнологичный продукт, который не потерпит обслуживания «в гараже на коленке». На что стоит обратить внимание:
    • Плазменное напыление цилиндров (PTWA): Вместо классических чугунных гильз в алюминиевом блоке применено тончайшее износостойкое напыление. Это снижает трение и вес, но делает блок практически неремонтопригодным методами классической расточки.
    • Сложная система охлаждения: Мотор термонагружен. Здесь используется водно-воздушный интеркулер с собственным независимым контуром циркуляции антифриза. Чистота радиаторов — залог жизни турбин. [3]
    • Качество масла и топлива: Забудьте про дешевую минералку и сомнительный бензин. Только качественная синтетика 0W-20 (объем системы около 7 литров) и строго высокооктановый бензин (АИ-98/100), особенно в летнюю жару или при нагрузке. Турбины делят масло с ДВС, и любой шлам убьет подшипники за считанные тысячи километров.
    Итог
    3.0 Twin Turbo Hurricane — это неизбежное, но очень качественное будущее Jeep. Да, мы будем скучать по породистому бубнежу V8 HEMI. Но по динамике, эластичности и возможностям тюнинга (турбомоторы отлично шьются!) новый I6 оставляет старые атмосферники далеко позади.
    А что думаете вы? Готовы пересесть с атмосферных V6 и V8 на высокотехнологичный твин-турбо, или «раньше было лучше»? Обсуждаем в комментариях!
    • 194068 Просмотров
    • 436673 Просмотра
