Отзывные (recall) на WK/WH
Pinned posts
65
Вбиваем сюда ВИН https://www.mopar.com/en-us/my-vehicle/recalls/search.html и видим актуальные реколы
Изменено пользователем ruby12
новый линк
Автомобиль: Гранд Чероки WH 3
0CRDI
Уважаемые Соклубники!
Кто, что слышал про реколы на Гранды и командеры 2005-2010
Автомобиль: Пешеход 4х4
Я думаю тут конкретно по vin надо определять. Или впринципе какие реколы бывали?
Автомобиль: Jeep Commander 3.0 CRD Limited 2008; Toyota Camry v70 3
5 Lux 2018
Дык официалу позвонить и узнать, есть ли что. По VINу.
Отзывают: 2005 - 2010 Jeep Grand Cherokee
2006 - 2010 Jeep Commander
Проблема с самовольным переключением передач.
Вот статья:
Chrysler's Jeep recalls nearly 470,000 Grand Cherokees and Commanders.
Chrysler Corporation has announced that they will be recalling over 469,000 of their Jeep SUVs for a potentially hazardous issue. The vehicles affected are:
The main issue is that if the vehicle is started, it may shift into neutral. Neither Chrysler or the NHTSA were clear if the brake pedal had to be depressed, in order for the vehicle to shift into neutral. That being said, Chrysler is stating that the issue can be traced back to finding cracks in the circuit board, which may send the wrong signals to the vehicle's transmission. If the vehicle were to go into neutral, it might move forward, increasing the risk of it being involved in an accident with another vehicle, person(s), or property.
It has been reported that thus far, there has been 26 accidents, and two injuries. Neither companies provided further details into the accidents and injuries.
The investigation began in January 2012, after an owner had filed a complaint stating that the vehicle had rolled away, once the it was started remotely. Moreover, Chrysler also stated that other cracks in the circuit board could affect models equipped with four-wheel drive, which could turn it on and off unexpectedly.
http://www.examiner.com/article/chrysler-s-jeep-recalls-nearly-470-000-grand-cherokees-and-commanders
Автомобиль: Grand Cherokee 2005 (WK) CRD
Уважаемые форумчане!
Пожалуйста, прокомментируйте вот такую ситуацию:
Имеется чипованный Jeep Grand Cherokee 2005 CRD 3.0, отключен EGR.
Неожиданно со мной связался официальный дилер и сообщил, что на машину имеется заводской отзыв.
То есть дилер за свой счет устраняет заводской программный дефект коробки/раздатки.
Внимание вопросы:
  • Слетит ли тюнинговая прошивка блока управления двигателем?
  • Знает ли кто-нибудь в чем проблема с коробкой/раздаткой? Может и так можно жить?
  • Удастся ли уехать своим ходом от дилера, если его прошивка внезапно включит клапан EGR?
  • Другие ценные мысли на эту тему?
Автомобиль: ПатруЛь
Если егр включится, то это не значит что машина сломается.
Проблема с акпп и раздаткой, может избавят от удара при сбросе газа, бывало иногда такое.
Чиптюнинг это зачастую настройка только работы мотора и к акпп не имеет ни какого отношения. Так что слетать ни чего не должно, егр в том числе.
Просто перепрошьют модуль управления полным приводом FDCM - никакой связи с егр не прослеживается. Езжайте и перепрошивайтесь спокойно
Автомобиль: в подписи
От удара при сбросе газа именно этот отзыв не лечит (и да, удар скорее неисправность, чем фича).
Прошивка не слетит, но прошивающий аппарат может отказаться шить (он же идентификацию авто у блока двигателя спрашивает, а тюненый может что-нибудь не то ответить). То есть испортить ничего нельзя, но результат 100% успеха не гарантирован. Плюс дилер может чисто теоретически начать кидать предъявы, что модифицированные машины не подлежать обработке "по отзывам", и т.п., неприятно, но - словоблудие, максимум он может отказаться шить по отзыву на блок управления двигателем или что-то делать по отзывам по мехчасти мотора (а таких не было).
Спасибо всем, кто ответил.
Обновление модуля управления полным приводом FDCM прошло успешно.
Чипованная прошивка двигателя никуда не делась.
Оф. дилер никаких вопросов не задал.
а что поменялось то в движении авто после прошивки?
может тоже им позвонить и спросить - что за прошивка.
  В 05.09.2013 в 05:26, Avtor сказал:
Поведение авто не изменилось.
По словами приемщика из сервиса, прошивка устраняет самопроизвольное включенияе нейтрали на раздатке во время движения.
(У меня никогда не случалось).
Удары в коробке при сбросе газа - это не лечит.
Позвонить ближайшему дилеру стоит. Так как они дозвонились не до всех владельцев машин, на которые пришел отзыв.
Отзыв, кстати касается и Commander-a.
Автомобиль: JGC WH 3.0 CRD Overland 2008
  В 05.09.2013 в 05:39, aum сказал:
Подскажите. Касается определенного года авто или как?
Автомобиль: Jeep Grand Cherokee WH 3.0 CRD Limited
  В 05.09.2013 в 05:51, BlackSerge сказал:
Можешь ехать смело, но куда? Я был два раза в автолайте на сталеваров говорили что есть отзыв, но до них ещё не дошел)))
  В 05.09.2013 в 06:01, CCCP_HUNTER сказал:
да, вот тоже интересно, где в МСК можно такую информацию проверить
Проверить наличие отзыва можно не поднимая жопы со стула - на сайте Жип американском есть для владельцев проверка на отзывы.
А вот к кому с этим ехать потом - это уже да, иногда вызывает вопросы.
  В 05.09.2013 в 12:27, Николай Пименов сказал:
извиняюсь за свою серость, но можно ссылку на место в нете, где можно проверить, а то на jeep.com я что то как баран на новые ворота смотрю и ничего не вижу.
  В 06.09.2013 в 06:10, Avtor сказал:
да проще позвонить по ОД и спросить есть или нет и когда подъехать
История с отзывом получила неожиданное продолжение:
В сервисе я не догадался проверить и включить понижайку. А сегодня догадался и получил "SERVICE 4WD SYSTEM".
Опускаю переговоры с дилером, проблема решилась сбросом ошибок.
Ошибка была "Рычаг привода полного привода" или что-то в этом роде (опубликую, если найду номер).
Будьте внимательны при посещении сервисов.
В бюллетене по производству работ в явном виде написано "обнулить все ошибки по всем модулям после перепрошивки". Походу не сделали...
  • 7 месяцев спустя...
Автомобиль: Jeep Grand Cherokee CRD3.0 WH
Сегодня позвонили со Сталеваров и сообщили о заводском отзыве, CRD 2008г.
Такая же хрень, типа коробка самопроизвольно переключается на нейтралку.
Кто там хотел перепрошиваться - велкам.
Я не поеду, ибо ни разу такого переключения не было..
Автомобиль: Jeep Commander 3.0 CRD Overland 2009
В соседней ветке правильные рецепты излечения этой проблемы: у дилера и самостоятельно http://jeep4x4club.ru/forums/topic/33018-esli-service-4wd-system-posle-n23-to/
Автомобиль: Grand Cherokee WH III
У меня на диллере такое было. МНе сказали, что завод на мой вин прислал исправления. Это нифига не стоит и ни на что не влияет. ВОт в целом все.
W124/300E
Мне тоже был звонок из "Автолайта"
У меня такой проблемы не было, стоит ли вообще прошиваться?
  В 07.07.2014 в 21:47, E_Gun сказал:
хозяин-барин, но у всех поголовно после этого рекола пониженая перестает включаться, официалы потом проблему за денежку решают, если не разведут на моторчик раздатки, или потом манипуляциями самому эту ошибку скидывать, на форуме есть инфа.... я уже 3 раза скидывал за пол года.
  В 29.07.2014 в 07:22, up6 сказал:
Не соглашусь пожалуй.
я сделал себе и ничем хорошим это не закончилось. Хотя может мне и не повезло как обычно)))
  • Кто в онлайне   3 пользователя, 0 анонимных, 103 гостя (Посмотреть всех)
    • Vitbb
    • Андрюха 70
    • Gosudar
    1. В TRS Motors поступил на ремонт Jeep Compass 2018 года выпуска с относительно небольшим пробегом, но серьезной проблемой - вышел из строя вакуумный усилитель тормозов. Владелец автомобиля обратил внимание, что при нажатии на педаль тормоза воздух начал выходить в салон, а эффективность торможения значительно снизилась. Это классические симптомы неисправности вакуумного усилителя, однако такая поломка крайне нетипична для Jeep Compass, особенно с небольшим пробегом. В России подобные случаи встречаются редко, что создало дополнительные сложности с поиском необходимой запчасти. Особенностью ситуации стало то, что в отличие от автомобилей VAG-группы, где масло часто попадает в усилитель через вакуумные трубки, в данном случае масла внутри не оказалось, что сделало причину поломки еще более загадочной.
      Как специалисты TRS Motors устранили проблему
      Несмотря на редкость поломки и отсутствие необходимой детали у поставщиков, мастера TRS Motors оперативно организовали заказ вакуумного усилителя тормозов. Ожидание запчасти заняло менее полутора месяцев - достаточно быстро для такой редкой детали. После получения нового усилителя специалисты выполнили комплекс работ: демонтировали неисправный узел, установили новый вакуумный усилитель, провели сборку и тщательную проверку работоспособности всей тормозной системы. Особое внимание уделили диагностике возможных причин поломки, однако явных предпосылок к выходу узла из строя обнаружено не было. Старый усилитель был сохранен для последующего разбора и изучения, что позволит лучше понять природу этой нехарактерной для Jeep Compass поломки и возможно, предотвратить подобные случаи в будущем.
      Почему важно своевременно реагировать на проблемы с тормозной системой
      Этот случай наглядно демонстрирует, что даже на относительно новых автомобилях, таких как Jeep Compass 2018 года, могут возникать неожиданные и редкие неисправности критически важных систем. Тормозная система - это основа безопасности водителя и пассажиров, поэтому любые изменения в ее работе требуют немедленного внимания. Специалисты TRS Motors рекомендуют владельцам Jeep Compass обращать внимание на следующие признаки возможных проблем с вакуумным усилителем: появление посторонних шумов при торможении, изменение усилия на педали, снижение эффективности торможения или, как в данном случае, попадание воздуха в салон. Даже если автомобиль новый или с небольшим пробегом, не стоит игнорировать эти симптомы - своевременное обращение в сервис может предотвратить опасные ситуации на дороге.
      Технические характеристики
      Применение в Jeep Wrangler JL
      Преимущества и недостатки
      Однако есть и нюансы:
      Спасибо за прочтение, друзья!
      Джип Клуб на связи!
    vangokh
    vangokh
    • КОГ52
      КОГ52  »  up6
      · 3 ответа
    • Yurank
      Yurank  »  up6
      Здравствуйте, интересует стоимость и наличие: подушки двигателя и АКПП оригинальные (идет дрожь на кузов, если там есть еще какие то опоры, подскажите) на Jeep GH WK2 SRT8 VIN 1C4RJFDJ5JC212662.
      · 3 ответа
    • gora0503
      gora0503  »  up6
      Здравствуйте помогите с пин кодом для прописки ключей. jeep compass 2007 vin 1J8FFF7W57D199760 (есть файлы) Если есть возможность с отключением тоже рассмотрю вариант.
