выбор OBD2 Cканера
Всем привет хочю купить сканер обд2 с возможностью диагностики систем абс желательно с руским интерфейсом но пока таких не видел.. бюджет до 12000р присматриваюсь к Innova 3160 описании поддержка обд2 и возможность диагностигки абс и также заманчива Innova 3140 он судя из описания читает всех джипов с 1981 года до 1995 по старому протоколу и с 1996 года и выше по обд2 но у него нет возможности диагностики абс вот ниже описание по Innova 3140
Может кто-нибудь что нибудь посоветует?
Features and Benefits
Provides SAE enhanced Live Data - views, records, and plays back live PCM data streams
Designed to retrieve diagnostic codes in all OBD2 (1996 and newer) and some of the most popular OBD1
(1981 to 1995) vehicles
OBD1 (82-95) Coverage GM, Ford, Chrysler/Jeep and Toyota/Lexus
Communicates with all OBD 2 protocols: C.A.N. (Controller Area Network), ISO 9141, J1850PWM,
J1850VPW, KWP 2000 ISO 14230-4
Displays Freeze Frame Data
The Equus line of scan tools provide the most diagnostic data and power for the money than any other line of scan
tools! It's patented "All-in-One" display shows 25 vital pieces of information at one time, and all within 15 seconds.
The 3140 can diagnose all OBD II compliant vehicle and most OBD I vehicles as well. This feature-packed tool and
software kit is designed to meet the needs of professional technicians who desire quick and easy access to
diagnostic data essentials for a wide range of vehicles. Features unique patented all-in-one screen display and
LED display for quick emissions check. Includes Spanish and French Interface and Definitions (selected by a menu
command). Retrieves OBD2 DTCs: Generic Codes (P0, P2, P3, and U0 B0, and C0) / Manufacturer Specific Codes
(P1, P3, and U1). Unit can be flash updated with a standard Windows® PC (OBD-PC Link™ software required /
included with tool). Memory / Battery backup for off-car review and analysis.
OBD1 Coverage: General Motors - 1982 to 1993 and some 1994 to 1995 models excludes Saturn vehicles; Ford,
Lincoln, Mercury - 1983 to 1995 models with EEC-IV Systems
Performs: KOEO, KOER, Timing Check, Cylinder Balance Test, Output State Test, Wiggle Test; Toyota / Lexus -
1991 to 1995.
Most models Chrysler / Dodge / Plymouth/Jeep - 1984 to 1995. Diesel trucks 1992-1995
  • Ответы 98
  • Просмотры 61,7k
  • @*AXL*, сканмастер
  • надо правильно установить программу, тогда всё работает. Смотри инструкцию по правильной установке проги. Scanmaster-ELM:   1. Распаковать архив scanmaster_elm_1.7.rar. 2. Установить ScanMasterELM
Ого! Ну ты у нас теперь крутой будешь инжекторщик!!! Давай осваивай всё, будешь нам потом помогать и с инжекторами. Причем не только на джипах, принципы работы везде одинаковые!
:lol2: :lol2: :lol2: да я спехом разьемы поснимал а с инжектарами че разбиратся в помойку если чего 22 доллара стоят
Лех он ошибки то считывает-стирает?! не пробовал еще?!
@Van777, Сам заглядываюсь на подобные девайсы. В своё время заказал с ебейки ELM-327, но вовремя одумался и сбагрил по себестоимости. На наши дизельки нужно, что-то другое или только родное диллерское.
Если дизель имеет разьем OBD-II - то зря сбагрил. Свою безинку я элмом прекрасно читаю.
Дык, он читал простым софтом...а толку? Скудная инфа... Вин, обороты..и всякая..а по теме работы форс и тд и тп нет софта. Или, что не так делал? Подскажите софт..
стирает конечно!!!
@alekseyv8, какой взял? графики строит на компе? таблицу параметров можно распечатать? давай подробности :lol:
ЗЫ поздравляю! :hands:
А на фуя? Чип-тюнингом должны заниматься специалисты. Для первичной диагностики элма достаточно. А если машина настолько ломучая, что надо постоянно ее диагностировать, может стоит задуматься о смене корыта?
@TheTERMINATOR, а кто говорил про чип? кто говорил про ломучесть? Я хочу знать полную инфу о состофнии авто. Это кксательнг моей машины. А в переспективе есть собственный бокс в центре города, думаю сделать там ремонт под автоэлектронникц. Посадить туда спеца и наслаждаться:-) :-) :-) :-)
Повторюсь, зачем? Что это конкретно даст?
На основании диагностики можно выдать диагностическую карту авто. При этом меня интересует сканер не только на мой авто.
Думаю пустить на комерческой основе. Так понятней?
@*AXL*, тогда речь о сервисном оборудовании, а не о ODB-сканере. И цена вопроса уже совсем другого порядка.
@TheTERMINATOR, Согласен, но хочу понять.. так как не профи. Каким бюджетным вариантом можно обойтись... да так чтоб и самому пригодилось)))
бюджетным
с
понятия не совместимые.
да таблицу можно распечатать графики да есть чето еше не разбирался так на 5.9 попробывал и все. надо на подключеном проехать а потом смотреть изменения отклонения
Дабы не плодить тем, решу спросить местных гуру тут.... :rolleyes:
Решил вернуть назад купленный год назад на ебейки ELM-327
Для софта решил пользовать старенький ASUS Eee PC 900 под ХР.
Машина у меня в подписи видна...
Вопрос... Кто какой софт пользует? Ибо штатный на диске шняга.
Спасибо за любые советы)))
@*AXL*, сканмастер ;)
Илья, а поподробней плиз...
Поиск рулит..уже читаю)))
Изменено пользователем *AXL*
@*AXL*, ScanMaster-ELM
посмотри на торренте, там много, даже фирменная chrysler есть. я взял bluetooth - подключить заразу не могу. надо было с кабелем брать.
Конкретней, пожалуйста. Сссылку или точное название.
название - Chrysler StarScan diagnostic software
ссылка - http://rutracker.org/forum/viewtopic.php?t=3573422
Судя по описанию, с простым к-лайн его не запустишь. Нужен спецовый адаптер.
добавил в файлы ScanXL_ELM_2.0.7, если кому надо. Сам сейчас хочу заказать wi-fi OBD2 адаптер для i техники (iPhone, iPad и т.д.) и использовать с программой http://www.iphone-gps.ru/2011/06/15/dashcommand-obd-2-diagnostika-avtomobilya-c-iphone/
кстати dashcommand есть и под винду
Изменено пользователем Alex668
я так и не смог проверить, так как не настроил связь компа и elm327.
но прога запускается и пишет "не обнаружен девайс", как и остальные подобные проги.
Scanmaster-ELM:
2. Установить ScanMasterELM_1.7.0.0.exe, программу не запускать, если открылась - закрыть.
3. Переписать ScanMasterELM.exe из распакованного в п.1 архива в папку, куда установили Scanmaster ELM в п.2
4. Зарегистрировать серийным номером LWRDX6N-ZVHA84P-HQUU0W5-WX8044F. Закрыть программу.
5. Содержимое папки ScanMaster_ELM_1.7_ru переписать в папку locale, которая находится внутри пути установки Scanmaster ELM в п.2
6. Выбрать в опциях программы язык интерфейса - русский.
ScanXL
1. Распаковать архив Scanxlpro.rar
2. Установить программу scanxl-pro-setup.exe, закрыть если запустилась.
3. Распаковать файл PPE_scanxlpro_v3.xx_uni.rar туда, куда установили программу в п.2
4. Перейти в папку, куда установили программу в п.2
5. Запустить scanxlpro_v3.xx_unipatch.exe от имени администратора (правой кнопкой мыши нажать на файл - "Запуск от имени администратора")
6. Нажать в открывшемся окне кнопку "Patch", окно не закрывать.
7. Запустить ScanXL pro, и зарегистрировать используя это:
Organization: none
Customer ID: [*88024002*]
Product Code: PS-1234567890
License Key: CAFEAFFF-10EF7677D5968A289E461060
Активированные правильно лицензии подсветятся зеленым.
8. Выбрать в меню язык интерфейса -German....
9. Закрыть программу.
10. Запустить программу
11. Проверить в меню язык интерфейса -German....
12. Закрыть программу.
13. Архивный файл руссификатор_scanxl.zip распаковать в каталог lang (он в папке установленной в п2 программы).
14. Запустить программу - интерфейс должен быть рускоязычным...
С уважением.
  • 10 месяцев спустя...
Scanmaster-ELM
ScanXL
Народ подскажите, сеня поставил эти проги и подключил ЕЛМ, пишет что видит трансмиссию и двигатель. В итоге только увидел обороты движка и процент открытия заслонки. Что нужно сделать чтобы видеть остальные параметры?!
Кстати ошибок не нашел, но ключом я две вижу, это как понять!? Они конеш ни к двигу ни к трансмиссии не относятся, знач так и должно быть!? Или дрова новые нужны, ставил те что с диском пришли.
Ну так что, у всех такая же шняга по сбору данных или просто прогу или дрова другие надо?!
У меня вроде дрова все встали правильно. В сканмастере отображаются обороты, температура охлаждайки, и еще некоторые неинтересные параметры (штук 10 всего, не больше). Ошибки не видит, хотя они есть. Пишет, что не подключиться в ECU.
Там есть протоколы, которые можно вручную поперебирать. Но и это не помогает... Неужели у нас протокол, которого нет в списке?
Как с этим бороться? Хоть кто-нибудь победил дизель с помощью ELM327?
Изменено пользователем Zero
    • 26973 Просмотра
    • 287 Записей
    • 185995 Просмотров
    Свист слева при запуске, к прогреву стихает
    Владелец жалуется на посторонний звук из моторного отсека, сразу после пуска отчётливо свистит с левой стороны, а через пару минут звук почти уходит. Grand Cherokee SRT (WK2) 2014 года, мотор 6.4 HEMI, пробег 138 тысяч.
    По характеру звука причина понятна ещё до разборки. Так ведёт себя выпуск, когда в коллекторе появилась щель, и на этих моторах с пробегом за сотню такое встречается регулярно.
    Почему выпускной коллектор 6.4 HEMI перестаёт держать стык
    Выпускной тракт такого мощного двигателя работает в постоянной экстремальной термонагрузке. За годы металл ведёт, появляется зазор, и в первые минуты после старта выхлоп прожигает прокладку в этом месте.
    Когда металл прогревается и расширяется, щель частично закрывается, поэтому на горячую свист почти не слышен. Прошлифовать такой коллектор и вернуть плоскость уже не получится, деталь идёт под замену.
    Гул справа, сгоревшая муфта и оторванные сайлентблоки
    Гул спереди-справа при движении подтвердил первую гипотезу: правая передняя ступица сильно изношена, новая заказана.
    Кондиционер не работает, у компрессора сгорела муфта, это заметно по внешним признакам. Компрессор разбираем и смотрим, ушла ли металлическая пыль по контуру, от этого зависит, придётся ли промывать трубки и менять осушитель.
    Тормозные диски с завода не менялись ни разу, износ большой, по поверхности пошли микротрещины. Сзади при вращении колёс скребёт с обеих сторон в районе стояночного тормоза, точную причину увидим после разборки механизма.
    Передние сайлентблоки заднего подрамника практически оторвались. Опоры заднего редуктора кто-то менял до нас на неоригинальные, поставим те, что положены этой машине.
    Новый коллектор, крепёж и промывка радиаторов
    Коллектор сняли, поставили новый, крепёж обновили целиком: старые шпильки на таком пробеге обламываются прямо при демонтаже. Ступицу и диски меняем с ревизией суппортов, сайлентблоки ставим оригинальные.
    У нас в ТРС-Моторс машины этой серии на подобном пробеге приходят примерно с таким же набором работ. Тем же заходом чистим радиаторы, соты забиты и теплоотдача упала, отсюда и перегрев; один из четырёх уже течёт и будет заменён. Как выглядят соты до чистки, показали на видео.
    Прогар слышно на холодном пуске, а не на прогретом моторе
    Подсвистывание из-под капота в первые секунды после запуска, стихающее по мере прогрева, — самая ранняя стадия прогара. Дальше щель растёт, и звук держится дольше.
    Гул со стороны переднего колеса, который усиливается со скоростью, отрабатывайте по ступице.
    Скрежет при медленном вращении заднего колеса на подъёмнике указывает на механизм стояночного тормоза, а не на рабочие колодки.
    • 430780 Просмотров
