Отзывные (recall) на WK/WH
Pinned posts
65
Вбиваем сюда ВИН https://www.mopar.com/en-us/my-vehicle/recalls/search.html и видим актуальные реколы
Изменено пользователем ruby12
новый линк
Автомобиль: Гранд Чероки WH 3
0CRDI
Уважаемые Соклубники!
Кто, что слышал про реколы на Гранды и командеры 2005-2010
Автомобиль: Пешеход 4х4
Я думаю тут конкретно по vin надо определять. Или впринципе какие реколы бывали?
Автомобиль: Jeep Commander 3.0 CRD Limited 2008; Toyota Camry v70 3
5 Lux 2018
Дык официалу позвонить и узнать, есть ли что. По VINу.
Отзывают: 2005 - 2010 Jeep Grand Cherokee
2006 - 2010 Jeep Commander
Проблема с самовольным переключением передач.
Вот статья:
Chrysler's Jeep recalls nearly 470,000 Grand Cherokees and Commanders.
Chrysler Corporation has announced that they will be recalling over 469,000 of their Jeep SUVs for a potentially hazardous issue. The vehicles affected are:
The main issue is that if the vehicle is started, it may shift into neutral. Neither Chrysler or the NHTSA were clear if the brake pedal had to be depressed, in order for the vehicle to shift into neutral. That being said, Chrysler is stating that the issue can be traced back to finding cracks in the circuit board, which may send the wrong signals to the vehicle's transmission. If the vehicle were to go into neutral, it might move forward, increasing the risk of it being involved in an accident with another vehicle, person(s), or property.
It has been reported that thus far, there has been 26 accidents, and two injuries. Neither companies provided further details into the accidents and injuries.
The investigation began in January 2012, after an owner had filed a complaint stating that the vehicle had rolled away, once the it was started remotely. Moreover, Chrysler also stated that other cracks in the circuit board could affect models equipped with four-wheel drive, which could turn it on and off unexpectedly.
http://www.examiner.com/article/chrysler-s-jeep-recalls-nearly-470-000-grand-cherokees-and-commanders
Автомобиль: Grand Cherokee 2005 (WK) CRD
Уважаемые форумчане!
Пожалуйста, прокомментируйте вот такую ситуацию:
Имеется чипованный Jeep Grand Cherokee 2005 CRD 3.0, отключен EGR.
Неожиданно со мной связался официальный дилер и сообщил, что на машину имеется заводской отзыв.
То есть дилер за свой счет устраняет заводской программный дефект коробки/раздатки.
Внимание вопросы:
  • Слетит ли тюнинговая прошивка блока управления двигателем?
  • Знает ли кто-нибудь в чем проблема с коробкой/раздаткой? Может и так можно жить?
  • Удастся ли уехать своим ходом от дилера, если его прошивка внезапно включит клапан EGR?
  • Другие ценные мысли на эту тему?
Автомобиль: ПатруЛь
Если егр включится, то это не значит что машина сломается.
Проблема с акпп и раздаткой, может избавят от удара при сбросе газа, бывало иногда такое.
Чиптюнинг это зачастую настройка только работы мотора и к акпп не имеет ни какого отношения. Так что слетать ни чего не должно, егр в том числе.
Просто перепрошьют модуль управления полным приводом FDCM - никакой связи с егр не прослеживается. Езжайте и перепрошивайтесь спокойно
Автомобиль: в подписи
От удара при сбросе газа именно этот отзыв не лечит (и да, удар скорее неисправность, чем фича).
Прошивка не слетит, но прошивающий аппарат может отказаться шить (он же идентификацию авто у блока двигателя спрашивает, а тюненый может что-нибудь не то ответить). То есть испортить ничего нельзя, но результат 100% успеха не гарантирован. Плюс дилер может чисто теоретически начать кидать предъявы, что модифицированные машины не подлежать обработке "по отзывам", и т.п., неприятно, но - словоблудие, максимум он может отказаться шить по отзыву на блок управления двигателем или что-то делать по отзывам по мехчасти мотора (а таких не было).
Спасибо всем, кто ответил.
Обновление модуля управления полным приводом FDCM прошло успешно.
Чипованная прошивка двигателя никуда не делась.
Оф. дилер никаких вопросов не задал.
а что поменялось то в движении авто после прошивки?
может тоже им позвонить и спросить - что за прошивка.
Поведение авто не изменилось.
По словами приемщика из сервиса, прошивка устраняет самопроизвольное включенияе нейтрали на раздатке во время движения.
(У меня никогда не случалось).
Удары в коробке при сбросе газа - это не лечит.
Позвонить ближайшему дилеру стоит. Так как они дозвонились не до всех владельцев машин, на которые пришел отзыв.
Отзыв, кстати касается и Commander-a.
Автомобиль: JGC WH 3.0 CRD Overland 2008
Подскажите. Касается определенного года авто или как?
Автомобиль: Jeep Grand Cherokee WH 3.0 CRD Limited
Можешь ехать смело, но куда? Я был два раза в автолайте на сталеваров говорили что есть отзыв, но до них ещё не дошел)))
да, вот тоже интересно, где в МСК можно такую информацию проверить
Проверить наличие отзыва можно не поднимая жопы со стула - на сайте Жип американском есть для владельцев проверка на отзывы.
А вот к кому с этим ехать потом - это уже да, иногда вызывает вопросы.
извиняюсь за свою серость, но можно ссылку на место в нете, где можно проверить, а то на jeep.com я что то как баран на новые ворота смотрю и ничего не вижу.
да проще позвонить по ОД и спросить есть или нет и когда подъехать
История с отзывом получила неожиданное продолжение:
В сервисе я не догадался проверить и включить понижайку. А сегодня догадался и получил "SERVICE 4WD SYSTEM".
Опускаю переговоры с дилером, проблема решилась сбросом ошибок.
Ошибка была "Рычаг привода полного привода" или что-то в этом роде (опубликую, если найду номер).
Будьте внимательны при посещении сервисов.
В бюллетене по производству работ в явном виде написано "обнулить все ошибки по всем модулям после перепрошивки". Походу не сделали...
  • 7 месяцев спустя...
Автомобиль: Jeep Grand Cherokee CRD3.0 WH
Сегодня позвонили со Сталеваров и сообщили о заводском отзыве, CRD 2008г.
Такая же хрень, типа коробка самопроизвольно переключается на нейтралку.
Кто там хотел перепрошиваться - велкам.
Я не поеду, ибо ни разу такого переключения не было..
Автомобиль: Jeep Commander 3.0 CRD Overland 2009
В соседней ветке правильные рецепты излечения этой проблемы: у дилера и самостоятельно http://jeep4x4club.ru/forums/topic/33018-esli-service-4wd-system-posle-n23-to/
Автомобиль: Grand Cherokee WH III
У меня на диллере такое было. МНе сказали, что завод на мой вин прислал исправления. Это нифига не стоит и ни на что не влияет. ВОт в целом все.
W124/300E
Мне тоже был звонок из "Автолайта"
У меня такой проблемы не было, стоит ли вообще прошиваться?
хозяин-барин, но у всех поголовно после этого рекола пониженая перестает включаться, официалы потом проблему за денежку решают, если не разведут на моторчик раздатки, или потом манипуляциями самому эту ошибку скидывать, на форуме есть инфа.... я уже 3 раза скидывал за пол года.
Не соглашусь пожалуй.
я сделал себе и ничем хорошим это не закончилось. Хотя может мне и не повезло как обычно)))
  • Кто в онлайне   13 пользователей, 1 анонимный, 166 гостей (Посмотреть всех)
    • Серёга 18
    • Alex 49
    • Skipper82rus
    • miha89
    • Vitales
    • brat-kondrat
    • MP40
    • Павел_З
    • зуза
    • FinSPb
    • kupr_vi
    1. Jeep Grand Cherokee 2022-2025 года предлагает разнообразные музыкальные системы, которые варьируются в зависимости от комплектации: Laredo, Altitude, Limited, Overland и Summit. Каждая из них имеет свои особенности, от базового звука до премиального аудио, разработанного для исключительного качества. В этой статье мы разберём, какие аудиосистемы установлены в каждой комплектации, их ключевые отличия и особенности звучания.
      Особенности:
      Особенности:
      Jeep Grand Cherokee Limited
      Особенности:
      • Звучание:
      Jeep Grand Cherokee Overland
      Особенности:
      • Звучание:
      Особенности:
      Комплектация
      Аудиосистема
      Мощность
      Особенности звучания
      Кому подойдёт
      Laredo/Laredo X
      6 динамиков, ANC
      Не указана
      Altitude/Altitude X
      6 динамиков, ANC
      Не указана
      506 Вт (Alpine)
      Баланс цены и качества звука
      506/950 Вт
      Summit/Summit Reserve
      950 Вт
      Аудиофилы, ценители роскоши
      Ключевые отличия:
    2. Владелец Jeep Grand Cherokee 2014 года с бензиновым двигателем 3.0 и пробегом 260 тысяч километров обратился в наш сервис TRS Motors с жалобами на вибрацию двигателя на холостом ходу и подозрениями на пропуски зажигания. Кроме этого, клиент попросил провести комплексную диагностику автомобиля и проверить состояние всех технических жидкостей. Такие симптомы часто указывают на необходимость комплексного обслуживания для автомобилей с большим пробегом.
      Что выявила диагностика в TRS Motors
      При детальной проверке наши специалисты обнаружили несколько важных моментов, требующих внимания. Во-первых, требовалась замена масла в обоих редукторах и раздаточной коробке. Во-вторых, был выявлен износ заднего сальника раздатки - небольшой, но критически важной детали, для замены которой приходится демонтировать значительную часть узлов трансмиссии. Масло в автоматической коробке передач решили не менять, так как его замена производилась всего 45 тысяч километров назад.
      Какие работы были выполнены
      Помимо замены технических жидкостей и сальника, наши мастера заменили свечи зажигания - зазоры на старых свечах составляли 1.5 мм при норме 1.1 мм, что могло быть одной из причин пропусков зажигания. Также были заменены передние подкрылки, которые находились в аварийном состоянии - по выражению нашего механика Сергея, "в них могла пролезть голова". Все работы были выполнены качественно и в сжатые сроки, несмотря на сложность доступа к некоторым узлам.
      Почему важно своевременно обслуживать Jeep с большим пробегом
      Данный случай наглядно показывает, как важно регулярно обслуживать автомобили с солидным пробегом. Jeep Grand Cherokee - надежный внедорожник, но после 200 тысяч километров пробега требует особого внимания к ходовой части и двигателю. Своевременная замена изношенных деталей и технических жидкостей позволяет избежать более серьезных и дорогостоящих поломок в будущем. После проведенного в TRS Motors обслуживания автомобиль полностью готов к дальнейшей эксплуатации и новым путешествиям.
